Intake Replacement
Old Apr 9, 2002 | 03:02 PM
Nismo1997
Intake Replacement
This is the best forum I'm glad to be part of the maxima org.I will really appreciate if someone can help me. I did replace regular air filter for the HI PERFORMANCE INTAKE, however the black box where the original air filter was had a sensor inside, once the box is removed and the intake is put in its place, there is no way to connected this sensor to the INTAKE. All these makes an amber light on in the dash board. Please help!!!!!!!! thanks again
my e-mail is speedlight10@aol.com
Cecibel
Old Apr 9, 2002 | 03:39 PM
soundmike's Avatar
Very sound, Mike
Re: Intake Replacement
Which intake?
I think you're talking about the MAF sensor. You need that dude.
Old Apr 9, 2002 | 04:00 PM
JAIMECBR900's Avatar
I think he is talking about the temp. sensor. Which intake did you get? If it is Place Racing, there is already a pre-made hole(s) just for the sensor and make sure you follow the instructions exactly to avoid loosing a piece and accidentaly sucking it up into the TB. If it is not a PR CAI, then you may have to drill a hole on the intake itself, before the MAF, and put it in yourself. I bet if you pull the codes off the ECU it will tell you that it is the temp sensor too.
vingodine
45
May 21, 2016 12:46 PM
Maxboy23
Aug 21, 2015 11:02 AM
MaximaDrvr
Aug 19, 2015 08:20 PM
Maxboy23
Aug 11, 2015 11:59 AM
