View Poll Results: Have you had a problem with the flex section of your Cattman Y-pipe?
Y-pipe inspected. Problem in flex section
30.23%
Y-pipe inspected: No problem in flex section.
16.28%
Y-pipe not inspected: Possible problem in flex section.
18.60%
Y-pipe not inspected: Flex section seems to be OK so far.
34.88%
Voters: 43. You may not vote on this poll
Let's get real: Cattman Y-pipe flex section issues
Originally posted by Victim64
OMG and yours was just like 2 weeks old?? dang
Thanks for bringing VeeTec's comments to my attention, Victim64. I missed them in this thread, but I read what he had to say in the thread Eric posted.
Quick question for you VeeTec. Do you think your driving habits had anything to do with why your flex section failed so quickly? In other words, did you race your Maxima or drive it very aggressively after you installed the Y-pipe?
Has Brian addressed this at all?
I have no idea what this problem is ... can someone post a pic of what I should be looking at and for? Or at lease a schematic or conceptually explain it in words?
Tkx!
Tkx!
Originally posted by y2kse
YIKES!
YIKES!
I am getting one soon, but leaning heavily toward WSP.
He had it at the track shortly there after, so I would say yes. But isn't the Y-pipe a performance mod, so aren't most people that get them going to see how well it performs??
Even if driving habits DO have an effect on the flex....it's irrelevant....aftermarket y-pipes are RACING exhaust pieces...which means they should stand up to the kind of abuse that racing and agressive driving doles out.
Think about it this way...if you are going to spend money to get more hp out of your car...are you going to drive it like an old lady all the time in fear of breaking the part that gave you the more power that you now cannot use?
I personally drive agressively and race my car...and I've had THREE...yes THREE cattman flexs go bad on me...the latest one only took 2 weeks!!!!!!!
Yes I raced my car, but I didn't buy my Y-Pipe for looks.
I didn't abuse it with excessive wheel hop and my motor mounts are all fine.
I personally think its the flex pipe design. The stock Y-Pipe allows for more give and I have yet to hear of one failing, not to say that it couldn't happen, but my stock flex pipe saw a LOT more racing than the Cattman. Then there was the initial fitment issue with my Y-Pipe. That disturbed me a bit too.
The Cattman appears to have the best design for flow and power, but the flex pipe is obviously not up to the standards of the Y-Pipe itself.
I hope the problem is resolved soon.
Question 1: If you race your Maxima or drive it aggressively, have you experienced problems with the flex section of your Cattman Y-pipe?
Now, if I could only get my wheel bearings to stop going out...
Thanks MaxedBandit, VeeTec and BriGuyMax. I'm glad you guys decided to post your comments.
BriGuyMax, once again I'm not arguing your point. I agree that an aftermarket Y-pipe is designed for racing and should be able to withstand the kinds of stress racing imposes. But that doesn't answer my question. All I'm trying to determine at this point is whether stress is a factor in Cattman Y-pipe flex section failures.
VeeTec, obviously there's something wrong with the flex section. But it may have NOTHING to do with its design. Perhaps it's a flaw in the materials used in the liner or the construction of the liner itself. Frankly, I hope that turns out to be the case. I suspect it would be easier to correct a defect in materials and workmanship than a flaw in the design.
MaxedBandit, I'm very interested in hearing the results of your inspection. It sounds like you put a lot of stress on your Y-pipe. If your flex section shows no signs of detioration, then Brian may be correct and the failures may be random as he suggests. Please keep us posted.
Now here's an idea nobody seems to have thought of. I notice that the Cefiro Y-pipe referred to in another thread has two flex sections. I wonder what would happen if you cut the Cattman Y-pipe and added an additional flex section to it. Would it eliminate the problem? And how much noise would the additional flex section generate?
Originally posted by MAX2000JP
I havent inspected the inside of the flex section yet. If I get a chance this weekend I will. I got a lot of modding to do this weekend. Helping my brother put a UDP and H&Rs on his 99' SE-L and I am also helping BriGuyMax put KYB-AGX's/Sprints on his car.
What do you think about my wheel hop theory? Pesonally I think that the problem might involve a couple of variables such as the length of the flex, engine mounts, and wheel hop. I wish I could load the vid i took of my runs at the track. You can see my exhaust bouncing up and down violently.
Originally posted by skeelo34
I was told by a muffler/exhaust shop that wheel hop and bad motor mounts can break a flex section in a ypipe.
I am all for supporting Cattman, but for now I am going with a WSP Y-pipe. It gives the same amount of performance increase, but I haven't heard of near as many problems with it? Good Luck to everyone and I hope this issue is resolved.
Originally posted by ohboiya
guys .. help me out ... what's the flex section n e ways?
http://www.stevetek.com/R-DIY_Exhaust.html
Read the section under "Procedure".
I wouldn't quibble about it being a month or two out of warranty, we'll fix your pipe.
An order of great new lined flexes are on the way and should be here on or about the 26th. We can start installing them immediately.
No reason not to send it in, and I an very confident about the durability of the new flexes.
Brian C. Catts
Cattman Performance
Brian C. Catts
Cattman Performance
Originally posted by BriGuyMax
I purchased a Cattman y-pipe February 2001, I had the flex replaced becuase of leakage by Cattman UNDER warrenty in Sept 2001. I realized a power loss in November 2001...I found the crumpled lining in my flex section in February 2002....I bought another use cattman y-pipe off a local member for really cheap...it had been used for 3K miles..and the flex was fine....last night after less that 1K miles on my car I disconnected the cat...and the y-pipe (took 5 minutes) and peered inside....and guess what I found......you got it...my NEW Cattman y-pipe was having the SAME problem as my old one!!!!!!! So I now have TWO busted Cattman y-pipes sitting in my garage....and my stock y-pipe on my car....boy does my life suck right now...
Cattman flex update
I've been too busy to follow this of late, but let me make some things clear.
The problem is entirely the result of a particular flex section design because a different type used in some pipes does not have any failure pattern.
Two basic types have been used in Cattman pipes (I find out now, though they were from the same supplier, same part number so we can't know the proportions of each). In one type, the braided liner is held in place just inside either end with a metal ring/band that is spot welded to the materials underneath. Looking in the end you can see the edge of the braid under the metal ring. In some pipes, the spot welds holding the ring in place have broken and the liner has come loose on the inlet end and gotten bunched up like a sock as its driven inwards by the exhaust. Simple as that, its a defective design.
Obviously with a weak design, the failure rate will be higher/quicker the 1) the harder the car is driven and 2) the worse the condition of the motor mounts. I'll make it absolutely clear, that the flex should not fail simply because the car is driven hard, but if the mounts are really shot, that is asking too much of any flex over long periods of time.
Ask any Nissan-specific master mechanic, the Maxima mounts are relatively weak, and will fail anywhere between 30k and 100k, depending entirely on how the car is driven. A car like mine, a 97 5-speed, with 70k+ miles, driven "robustly" throughout its life, will certainly have shot original motor mounts, its a fact of life. And, they're shot long before you can see they're shot, there's not visual evidence unless they're so bad that they've torn or the fluid is leaking out of the liquid-filled versions.
I'm not making excuses for my flexes failing -- once again, its the result of a crappy design -- but you cannot overlook the extreme stress put on any flex section by shot motor mounts on a transverse-mounted engine and, if driven hard with those, the resultant extreme wheelhop is absolutely deadly to flexes.
Back to the second "correct" flex design. Now we see that some of the Cattman pipes have been made with the proper flex design, where the flex lining is tucked under a double-walled endcap and welded into place. The edges of the braided lining are not visible at all. There is no funky ring to come loose. There has been no indication that any of these have failed.
What we're doing about it... We'll begin fixing pipes as soon as the new flexes come in, due on about the 26th. We've ordered longer 8" flexes (includes an inch-long cap at each end) made in the US by a real solid company with an excellent reputation. Even though this firm sells a braided-lining flex that would work well, we're upgrading to a spiral stainless steel interlock lining that's like the flexible metal casing that protects the handset cord on a payphone.
Its pretty basic -- the new flex, whether installed in new pipes or used to replace a defective flex, is of superior quality and will not suffer the pattern of problems that the flexes that have the bad design.
For those wondering what I'm doing about fixing the bad flexes, there is a semi-permanent post on this forum that explains the return policy. We'll first fix the pipes still under 1-year warranty (with a little flexibility on the warranty term). Then we'll deal with any older ones that have flex issues, though there will have to be some modest cost recovery on those.
A couple of people have written to say they cannot return the pipe for whatever reason and asked me to send them a loose flex for local installation. I don't really advocate this approach but if the owner wants to assume responsibility for the local work (please insist on TIG welding), I'll send the flex and $20 to cover or help with labor (that's what I pay to fix each one here). When someone wants a flex to be sent without returning the old pipe I require a photo depicting the interior of the failed flex, with something identifying the owner visible in the picture like a business card.
ASo far I've heard from perhaps 12-15 people. Combined with the ones fixed previously, I'd say about 20 flexes have failed and notified me. Based on the customer base out there, that represents between 2 and 3 percent. More than I'd like, but not an epidemic.
We are also in the process of changing to a new fabricator of y-pipes, a great ISO9000-certified machine shop here in Tucson that does a lot of aerospace and medical device work and will raise Y-pipe fabrication to a new standard. They're making up a very sophisticated fabrication fixture that will turn out a more consistant product than has ever been accomplished before.
Obviously we'll be using the new flexes. All tubing steel will remain T-304 stainless with over-thick fully CNC machined mild steel flanges. The tubing is from the Rath Mill and mandrel bending will be done by Burns Stainless; I understand this is meaningless to most, but to those who know, Rath makes the best s/s tubing and Burns is legendary in racing exhausts -- design, fabrication and materials.
Oh yes, the new ones will not only be better, they'll be available at a new, lower retail price!
Really long, but this has turned into a complex subject, fraught with conjecture. I hope that this information is useful and puts some rumors and misimpressions to rest.
We've obviously taken a hit with this flex issue, but you learn from your mistakes and as far as I'm concerned the future is bright with our new y-pipe fabrication and improved subcomponents.
Brian C. Catts
Cattman Performance
Brian C. Catts
Cattman Performance
Brian C. Catts
Cattman Performance
Brian C. Catts
Cattman Performance
Thanks for addressing the issue. I paid 400 bucks for the AGX's when I bought them from you, and I did so because I believed in your name/reputation. I have your y-pipe installed on my 99 Max and I am not experiencing any problems so far (KOW). My receipt from you is dated 6-22-01. Please keep us updated on your 4th gen catback. Thank you for your continued support.
Originally posted by ljl10
Brian,
Brian,
As far as I'm concerned, Cattman continues to earn my confidence.
PS: Brian, I'd recommend that you take your last post in this thread and add it to the sticky thread so that everyone knows what you discovered and how you're addressing it.
chalk one up on the ok for now side. See photo at link:
Cattman flex - 8K - 2k maxima
Violator
Sep 9, 2015 10:14 AM
