Transgo Transmission Shift Kits?
Old Apr 11, 2002 | 12:13 AM
catman316's Avatar
Anybody have experience with this kits, they have one for ours car but Im not sure about if it works.
here its the link
http://www.txchange.com/transgo.htm
Old Apr 11, 2002 | 12:29 AM
sbslacker's Avatar
Re: Transgo Transmission Shift Kits?
here its the link
check these threads.... http://forums.maxima.org/search.php?...der=descending
Old Apr 12, 2002 | 01:32 AM
bernie2000se's Avatar
It' s for domestic cars fords, chrysler... I did not see anything for Nissan there.
Old Apr 12, 2002 | 05:57 AM
DanNY's Avatar
Ad·min·is·tra·tor
you're not very good on the internet enh?
PICK YOUR TRANNY!
SK® RE4F04A
Nissan Quest Altima Maxima DOHC RE4R01A
Mercury Villager 4F20E 4 speed
Corrects/Prevents/Reduces:
prevents direct clutch blowout caused by runaway line pressure; Burned 3rd clutches; No 2nd; No 3rd after 3-2 or 4-2 kickdown
Direct clutch inner seal leaks, wears or opens due to rotating force; Corrects soft 1-2 and 2-3
SK® RE4R01A
Nissan RE4R01A, RL4R01A Mazda R4AX-EL Subaru 4 speed ECAT Nissan, Infinity, Truck, SUV V8 RE4R03A Isuzu Diesel JR403
1988up 4 speed with or without lockup
Planetary burnup; 3rd clutch failure; forward clutch burnup Soft 1-2 shift; 2-3 cutloose; Band burnout and low lube flow causing overheating and total burnup
SK® RE4F02A
Maxima 85-96, Pulsar 88-90 Stanza 86-90 4 speed
RE4F02A & RL4F02A
Falls out of gear at a stop when hot, delayed forward engagement, no 3rd after a 3-2 or 4-2 kickdown, 4-3 or 4-2 kickdown runaway, 3-4 clutch burnup, direct clutch inner seal leak, soft 1-2 and 2-3 shift. High-Temp/Low Shrink rings assure quality shifts and extend durability
Old Apr 12, 2002 | 08:14 AM
JAIMECBR900's Avatar
It still not all that. I have the kit in my car and it's no where near as aggressive as I had imagined. From what I have read, Don's VB mod is much better. The transgo is probably much better than nothing but that's about it. If you are looking for a VB mod, spend the money and get Don's I wish I had done it while I had my tranny out. My .02 cents.
Old Apr 12, 2002 | 08:25 AM
DanNY's Avatar
Ad·min·is·tra·tor
transgo kit is a "shift improver"...it's in NO WAY a shift kit.
it makes the tranny slightly more reliable and makes the shifts a **little** (i stress little) faster. don't think you'll get the neck snapping action with this kit.
Old Apr 12, 2002 | 08:30 AM
Exactly, you certainly don't have a big change at all.
Old Apr 12, 2002 | 10:15 AM
DA-MAX's Avatar
Eat, sleep, and sh*t 2JZ
Dons current VB mod won't work on his car...the early VGs used the 2A series not the 4A.....
Old Apr 12, 2002 | 10:24 AM
catman316's Avatar
Exactly!!!!
The Don´s stuff dont fit my car the only way to go its the level ten VB recalibration that is too expensive!!! and the transgo stuff.
So I will go the transgo its better than nothing and will make my tranny last longer and gain a little time between gears.
Old Apr 12, 2002 | 10:27 AM
DA-MAX's Avatar
I know Don had considered making a kit for the 2A a long while back, but I never saw the final result, maybe its still in the works????
Old Apr 12, 2002 | 10:34 AM
mtrai760's Avatar
'Trynna' is not a word
I had the Transgo on my last tranny, and I wasnt very impressed. It works, but I'm sure Don's is better...
Old Apr 12, 2002 | 02:13 PM
eric93SE's Avatar
I'm using the transgo shift kit, and I like it. It makes first and second shift faster. It'll lead to longer tranny life. Also used Royal purple ATF and a tranny cooler. There is some stuff with the kit that you cannot install unless the tranny is out but no biggie. Overall its a very good tranny upgrade.
James92SE
142
Jan 2, 2024 09:23 AM
Mar 12, 2020 12:06 AM
KabirUTA13
19
Oct 17, 2015 02:15 AM
