New type of injection for Maxima's to boost hp possibly...
Old Apr 11, 2002 | 06:34 AM
jgadlage's Avatar
Found this on the Supra board- Propane injection. Anyone heard of doing this? Might be something good to try out if it is a better alternative to water or N20 injection.
http://www.supraforums.com/showthrea...ighlight=movie
A company that sells these kits is http://www.dynamicracing.com/
Just thought that I would throw that out there and see what people thought.
Old Apr 11, 2002 | 06:38 AM
soundmike's Avatar
Very sound, Mike
Re: New type of injection for Maxima's to boost hp possibly...
Propane? Isn't that Hank Hill sells?
Old Apr 11, 2002 | 08:11 AM
Justin, there is something similar in Korea, in a few of the "Express Cabs." It's not exactly propane, but its very similar in design and use. The trade off is higher maintenance cost, and costly rebuilds.
It is an idea, thats been used before, but on a Maxima, only god knows what will happen.
Soundmike, LoL indeed he does.
Old Apr 11, 2002 | 09:22 AM
1MAX2NV's Avatar
Why don't we just inject pure oxygen?
Old Apr 11, 2002 | 09:34 AM
Jeff92se's Avatar
I'm needing a caw
That would be a very good way to burn a hole in the piston or weld the rings to the cylinder wall.
ie.. gas welders. when you want to heat the flame up SUPER high to cut though thick metal, you turn on the oxygen and the heat/intensity of the flame goes though the roof.
Old Apr 11, 2002 | 09:39 AM
soundmike's Avatar
Very sound, Mike
i thought Acetylene (+ Oxygen) was used in gas welders?
Old Apr 11, 2002 | 09:53 AM
Jeff92se's Avatar
I'm needing a caw
You are correct. The 02 is added.
Old Apr 11, 2002 | 10:37 AM
B 0 0 M
Old Apr 11, 2002 | 12:13 PM
1MAX2NV's Avatar
I was kidding It's illegal to transport O2 without a permit. O2 will work if you have enough fuel to burn.
Old Apr 11, 2002 | 07:49 PM
OK, so is someone gonna turn me in, but ocifer its for my shop.
Old Apr 12, 2002 | 08:35 AM
JAIMECBR900's Avatar
Oxygen reacts very violently with aluminum. Absolutely correct, if you pump O2 into the engine it will go BOOM. The solid rocket booster in the space shuttle use aluminum as the "solid" part and we all know what happens when it's mixed in with fuel and O2.
Old Apr 12, 2002 | 08:47 AM
timby01's Avatar
Re: Re: New type of injection for Maxima's to boost hp possibly...
propane and propane accessories
Old Apr 12, 2002 | 08:54 AM
ru4real's Avatar
Re: Re: Re: New type of injection for Maxima's to boost hp possibly...
Accurate.
Old Apr 12, 2002 | 09:14 AM
OriginalMadMax's Avatar
This is kind of what I was talking about on the CAI vs. Popcharger thread, that whatever the air temp at the intake filter, the heat of the manifold would seem to be an issue that isn't really addressed. This stuff comes out of the bottle at -45º, which will certainly cool things down! Sounds intriguing, and according to them the C5 people and others have quietly been running this for some time.
Old Apr 12, 2002 | 10:41 AM
I don't know that propane is going to have the same effect as N2O because N2O adds 33% oxygen to the mix to make for a more efficient fuel burn. Additional fuel is what makes for the additional power not the N2O itself. All that to say that even if the propane "cooled" off anything (manifold, intake, etc.) it would not do much as a power adder like the N2O does. Know what I mean? I may have just confused myself ....
Old Apr 12, 2002 | 04:16 PM
dmbmaxima2k2's Avatar
Maxima.org Sponsor and Donating Maxima.org Member
i know diesel trucks get some good hp gains off that propane injection.
dank4us
34
Jun 10, 2024 03:45 AM
Quickgtp
Apr 13, 2017 03:30 PM
Finkle
Sep 27, 2015 09:53 PM
cheftoo
Aug 20, 2015 05:17 AM
wingnut2006
Aug 15, 2015 04:16 PM
