mechanic told me to un-plug something for faster shifts??
Old Apr 12, 2002 | 09:09 AM
TN-Max's Avatar
i was getting something installed on my car yesterday, and the mechanic said if i wanted it to shift faster (i was discussing don's vb mod with him) then i should unplug this..he pointed to a plug on the driver's side of engine compartment right behind the air intake, is this true will i get better performance by unplugging this?? what is this??
Old Apr 12, 2002 | 09:16 AM
Vinipux's Avatar
Re: mechanic told me to un-plug something for faster shifts??
you really have to be more specific then this, at least take a picture and have a pointer point at what you're talking about
or, you can do what your mechanic says and see if it works
Vinipux
Old Apr 12, 2002 | 09:25 AM
theMax's Avatar
Search...there is some folks that have done it but it may damage your tranny.
Not worth it, get the VB mod if you want harder shifts.
Old Apr 12, 2002 | 09:26 AM
mzmtg's Avatar
Minister of Silly Walks
I've had mine hooked up to a switch for over a year now.
Pretty much useless, therefore not worth the potential to damage your trans.
Get a VB mod.
Old Apr 12, 2002 | 09:36 AM
TN-Max's Avatar
k this is pretty much what i assumed, thanks guys
Old Apr 12, 2002 | 10:00 AM
pocketrocket's Avatar
Yeah, don't kill your tranny.
It's the dropping resistor, you can do a search on this and you'll find it's been discussed before.
Old Apr 12, 2002 | 10:11 AM
JAIMECBR900's Avatar
I keep saying this (as do most others here); Just do the real VB mod. I have the Transgo and it's basically useless. Save your money and do Don's VB mod and be happy from the start w/o killing your tranny or being dissapointed.
Old Apr 12, 2002 | 02:49 PM
BSwithTF's Avatar
Or....
Get the VB mod, then put the switch on so you can turn it on and off, and get prepared for some rock hard shifts. I only use the switch at the track though cause it's rather uncomfortable for everyday driving. Not sure if it helps time-wise but it feels cool. With the VB mod and the switch it shifts HARD!
Old Apr 12, 2002 | 04:13 PM
dmbmaxima2k2's Avatar
Maxima.org Sponsor and Donating Maxima.org Member
the concept behind it is ok, the resistor ups your tranny line pressure to it's max and that means harder shifts. a VB mod will up the line pressure AMONG other things. when i was runnign my 100shot on stock VB that was the only way i think i saved my tranny. it makes the tranny shift a lot harder, off boost i don't think it helped that much but i could chirp second. on boost if i didn't use it my tranny screamed and what not. i had it rigged to a switch that i only used for 1/4 miles passes and nos runs with my friends. i really think it saved my tranny but i would only use it in conjunction with a tranny cooler. get a tranny cooler anyway.
-steve
Old Apr 12, 2002 | 07:49 PM
darksands's Avatar
I did this just to see what it was about and it does give you quick shifts. I actually chirped going to second but it feels like my tranny is going through alot of wear and tear. I wouldnt risk messing up the tranny just for that.
Old Apr 13, 2002 | 12:44 AM
like i said, on NOS it's a bad situation anyway and this is the lesser of the two evils. i'm sure of that.
Old Apr 13, 2002 | 02:24 PM
nc00max
The guy at Level 10 pointed out the same thing to me when I had my VB done up there. I tried it once, and while it shifted even harder than the VB mod, it felt like the tranny was taking a serious ***-kicking from it, and the minute difference between that and the VB wasn't worth it to me. Get the VB mod done as well as a tranny cooler and you'll be about as set as you can be with an auto, minus the HSTC.
Unclejunebug
Apr 2, 2016 05:42 AM
hayne
Oct 5, 2015 11:53 AM
DC_Juggernaut
Sep 28, 2015 04:07 PM
Noela
Sep 26, 2015 08:22 AM
