Bosch +4 wear results are in
Old Apr 12, 2002 | 11:13 AM
deezo's Avatar
In all of the prior experiences from other members in dealing with the Bosch +4's, I decided to remove them from my car to see what I'd find. Most of the results in using the Bosch +4's have been very negative. Things like the electrodes being completely burned away kind of had me concerned.
Truely, I couldn't understand what people were talking about because I've run the plugs for about 25,000 miles and this is what my plugs look like:
The third one looks kind of dark but nothing I'd be concerned about. While running these plugs, I was able to achieve 15.6 in the 1/4 mile stock. The slight low end loss is gone now that I switched back to the NGK's therefore I'm curious to see what times I could get with the new plugs.
Although I don't have many bad things to say for the Bosch +4's, they held up well in my car especially with all of the abuse I've put them thru in the last year.
Old Apr 12, 2002 | 11:35 AM
redmaxpa007's Avatar
i SeE what you did therE
i am glad you had no problems with them..
thanks for the feedback!!
Old Apr 12, 2002 | 01:16 PM
deezo's Avatar
No prob!
Old Apr 12, 2002 | 01:29 PM
carnal_c30's Avatar
Former Sponsor
Thanks deezo its time for me to get new plugs this came at the right time
Old Apr 12, 2002 | 01:39 PM
deezo's Avatar
I'm really curious about the driving styles of the people that had problems. I figure that I was really abusing these plugs when running with the MA/CT Crew to meets in NJ, DC and in NYC. Plus I've run back and forth to the Pike and NYC numerous times and these plugs still look decent.
Old Apr 12, 2002 | 05:42 PM
shumax's Avatar
woooah!
I am not so sure. I mean, they look Ok. But that last plug should be telling you a story. Unless you dropped it in the mud, you have a different buring pattern going within one of your cylinders. I'd check that out!
SHUMAX
Old Apr 12, 2002 | 05:50 PM
deezo's Avatar
Re: woooah!
SHUMAX
I'm guessing that when I put them in, I added a little more lube to it than the others. I'd really be concerned if he spark area was covered in oil.
Old Apr 14, 2002 | 08:30 AM
Victim64's Avatar
Originally posted by deezo
bump
??? bump?? So are you really going to recommend the Bosh +4's to other members when there has been results that our cars run better with the NGK's in it, and that the +4's have actually caused problems before??
I had the Bosch +4's in my old Maxima, and even though I didn't have any major problems I did not put them in a second time, and I took them out with only 25k on them. When they first went in though I got some very weird feed back from my radio for some reason?? After 30 min of driving though that went away and never came back, but was very disturbing at the time.
Aw well, bump again
Old Apr 14, 2002 | 08:33 AM
Sprint's Avatar
Bosch don't work well for me.. but then my driving style will kill any plug
Old Apr 15, 2002 | 05:27 AM
njmaxseltd's Avatar
Those plugs look pretty good deezo. The plugs I pulled out of the Infiniti after 12K miles had absolutely no electrode left. Just a got where it once stood. Amazing how one car can burn them up in no time, and yet another one runs well with these.
Old Apr 15, 2002 | 06:41 AM
dwapenyi's Avatar
Nice write up and PIC. I came to similar conclusion with my Tokicos as you have with your BOSCH. Even though yours were fine, there have been many troublesome reports. My Tokico Blues are fine, but there are lots of war stories about those too.
DW
Old Apr 15, 2002 | 03:25 PM
deezo's Avatar
Aw well, bump again
Nah, I'm not selling people on putting them into the Max. From my experience, I wouldn't recommend them because of the power loss under 3K. My car ran good with them but others haven't but I'll tell you this, the NGK's can't be beat.
Old Apr 15, 2002 | 03:38 PM
deezo's Avatar
Well, after you had that issue, I needed to get them out to see if the same was happening to mine.
Apr 16, 2020 05:15 AM
mkaresh
Mar 12, 2018 06:48 PM
Sep 27, 2015 08:37 AM
