Alternator output
Alternator output
Ok, I am over at altimas.net, and I looking for some help. I am have just fried my 7th, yes, 7th alternator in since Sept. 2000. I have used lifetime warranty ones from Autozone, and the most recent one is an OEM alternator. Not a huge system in the car, and I even have a 1 farad cap on there. Also, when I get above about 3000 RPM, both battery and brake lights go off.....under 3000, they both come back on.
What is the output of a Maxima alternator? The Altima alt is an 80 amp alternator, and if the Maxima one puts out more and fits, I may just try one of them. Thanks
Originally posted by DJSassan
Well, its not the battery......but an 80 amp alternator just is not cutting it. 110 amp is better than 80, or paying $400+ for a new high output alternator.
Thanks for the info guys.
Hey thanks......I think a new battery is definitely in order. A yellow top for sure, but I have found them much cheaper than $180! I was just wondering if maybe the alternators would fit, because I have lifetime warranty on mine, and I can also switch it out with an alternator from another car if I wanted. Thanks for the replies!
Also, if anyone know NissanLunatic on here, and knows about Southwest Autoworks.....I have become a member of the family, and I have started Concept Autoworks. Some parts, same low price, same quality service, just in Columbus instead of Phoenix. www.conceptparts.com
Give me a call or shoot over an e-mail for anything!
Is it me or have people still not figured out that batteries are for starting a car and not running one? If you have charging or loss of power problems while the car is running, the alternator or a wiring problem is normally to blame. Having a better battery is good as a whole, but will only help in starting the car and power for key off time.
Originally posted by TheNip73
Batteries are for a heck of a lot more than starting the car. They provide reserved energy for accessories and the like. Do not think that it only starts the car. That is naive. Read my previous post.
I could go on and on, but I'll let you do the research to find out that what I'm saying is correct and not the other way around.
couldnt have said it better!...red for daily use...Yellow is a true "deep cycle" batter..so you can totally drain it..and re-charge it without damaging the internals. For sound and other high drain applications use Yellow! But if you just want a better day-to-day battery...the red top is the way to go..it actually starts your car faster due to lesser internal resistance.
JAIMECBR900, I never made claim of the battery powering the car. I made the claim it is recharged faster, or in other words, MORE EFFICIENT. I also said it powers accesories. I was reffering to if your blowing alternators, your alternator can't keep up and power WILL be drawn from the battery. I'm not out to start a fight, but it seems to me you think a battery is a battery and only comes into play when you car is off and the engine not running. Well, that is not the case in high draw applications where current draw exceeds current output from the alternator (which applies to this thread). If a battery is a battery, as you claim, then why does almost any car audio enthusiasts put a yellow top Optima in their car -- Because it is BETTER for their situation. Your claim that
is true, yet ridiculous. I don't know many people who go out to thier cars and just bump thier systems when they aren't driving. Give me a break. As I said before I had issues with this problem and my dealer told me what was up. I had a -15 amp draw of current in my car with the AC, headlights and stereo at a moderate level on. I was burning up alternators and the dealer told me to get an Optima battery for the reasons I mention. It WORKED. No more toasted alternators. I speak from experience, which to me is far more important than anything else. Also, your right on everything about how the battery works. Just to make it clear, it appears we only differ in the fact that the battery can have some impact when the vechile is running. Everything else I agree with you. Also, your viewpoint is right for MOST vechicles (probally 90 % on the road). I'm not out to chop ya down, just argue a small greivance I have in your logic. Reply back if you like. This is a good discussion. Hopefully others will get in on it too.
[Optima Yellow Top Batteries are] Great for stereo systems that are played for prolonged periods w/the car off
OK, with all that is said......
This battery that is on the car now, its been charged a two times in the last 6 months because of all the alternator problems. What I am thinking is, is it possible the battery is damaged because of all the times the alternator has not charged it completely, thus killing it? And then I throw on a new alternator, and it struggles to charge the battery, thus killing it????
Or did that not make sense?
Would you care to explain why my light dimming went down immensely when I replaced my stock battery with an optima yellowtop? Much more noticeable than the 1 farad cap I have. There's more to it than what you're saying, and it's pretty obvious you aren't powering a large stereo system.
Yellow tops recharge quicker, with less power. This means they suck off less power from the alternator, and give out more power in return.
IE, LESS DIMMING.
IE, LESS DIMMING.
I'm not going to keep arguing with you guys about something that I KNOW is correct. I was a mechanic for the largest of all battery dealers (Sears) for 7 years. I went to school (sears paid for it) to be able to diagnose problems exactly as this. I thoroughly understand how a main electrical system and charging system in our cars and others.
Both of you guys are not understanding what I'm trying to explain to you. Understand it from this analogy; an electrical current travels from the source to the load, along the way it may travel thru a in-line fuse, before reaching the final destination. Does that mean the fuse or the source is powering it? This is a pretty 1+1 analogy. It's obvious the fuse is NOT powering anything since current just travels thru it. Now follow this: The alternator is the source and stereo, accesories, or whatever you want is the load. The alternator does send power to the battery first, but once fully charged, the alternator continues to power the rest of your demands;NOT the battery. Once again, name one accesory that will NOT function when the car is on.
Bottom line, buying an Optima battery is a good step to strengthen your electrical system by supplying very quick recharging and discharging cycles, extremely high total number of cycles, and deep-cell capabilities. As the very first initial posts asks, what should he do if he keeps burning up alternators?...Buy better alternator (autozone alternators are notoriously not consistent from batch to batch), Use better wiring for the large demand stereo (i.e. bigger awg cable or truer connections), or do not exceed the capacity of a "good" alternator.
BTW, I do know a little about high power stereo systems. I had a competition vehicle that pulled close to 80 amps, put out 1600w RMS (a pair of Orion 250 HCCA's), and was powered by a Streetwires 200 amp dual pole alternator and never once did I have lights go dim or had electrical problems.
Hi gang,
Lets look at it this way. If a vehicle is cycling a battery, then, the total amperage being utilized during operation is higher than the alternator can provide. The simple solution is to calculate the required amps and upgrade the alternator accordingly.
If that is not an option for some reason, upgrading the battery to a yellow top will allow the battery to be discharged/recharged without any ill effects. As long as the owner allows "quiet time" with the vehicle where the total amperage draw is less than the amperage of the alternator, thus, allowing the battery to regain full charge.
Unfortunately, what some people do, is replace their factory spec battery (say, 850cca) with a higher capacity battery (1000cca) without thought to the added drain on the alternator to attempt to charge a battery that is larger. Adding caps to a system will assist in transients, but, will not resolve an issue of a overpowered system with an underpowered alternator.
Make sense? Just trying to explain it in a different way...
Originally posted by Audtatious
Hi gang,
Hi gang,
granturissimus
93
Jul 22, 2018 08:21 PM
