NEED HELP: "MSD" Rpm Window Switch install
Old Apr 22, 2002 | 03:00 PM
My 4DSC
Where do I tap in for the RPM signal for the switch?
THANKS IN ADVANCE!
Adam
Old Apr 22, 2002 | 03:11 PM
Keven97SE
Re: NEED HELP: "MSD" Rpm Window Switch install
Errr, uhhh, ...
you want your windows to automatically roll up at a certain rpm?
THANKS IN ADVANCE!
Adam
Old Apr 22, 2002 | 03:18 PM
ejj's Avatar
ejj
Re: Re: NEED HELP: "MSD" Rpm Window Switch install
Originally posted by Keven97SE
Errr, uhhh, ...
Old Apr 22, 2002 | 03:22 PM
DA-MAX's Avatar
Eat, sleep, and sh*t 2JZ
Errr, uhhh, ...
BWAHAHAHAHAHA....thats classic!!!!
Chunger's Avatar
My other car is a Hybrid
THANKS IN ADVANCE!
Adam
Go to www.maximadriver.com HOW2 and look up shift light installation...
Old Apr 22, 2002 | 03:38 PM
celica's Avatar
Errr, uhhh, ...
Old Apr 22, 2002 | 04:30 PM
Colonel's Avatar
Old Fuddy Duddy
THANKS IN ADVANCE!
Adam
Check IceY2k1 page as well. On a 2K1 I believe it is the left dash connector and a WHITE with GREEN stripe wire which is to the left of the green with silver dashes and to the right of the red wire.
And it will roll up your windows when you want too!
Is it for NOS or other top secret project?
Old Apr 22, 2002 | 05:32 PM
My 4DSC
huh?
what is a "left dash connector" & where is it located?
yes it is for NOS...
ME??...top secret projects??
Old Apr 22, 2002 | 09:13 PM
Colonel's Avatar
Old Fuddy Duddy
Re: Re: Re: NEED HELP: "MSD" Rpm Window Switch install
huh?
When you remove the dash trim and CAREFULLY tip the gauge cluster over, you will see THREE connectors at the back of the cluster (1 white 2 brown). As you are sitting in the seat looking at the cluster, its the connector on the left side.
Check out this weblink courtesy of IceY2k1:
Ice's Shift light install pictures
Old Apr 23, 2002 | 08:19 AM
My 4DSC
Re: Re: Re: Re: NEED HELP: "MSD" Rpm Window Switch install
Thank You.
Old Apr 23, 2002 | 09:08 AM
1MAX2NV's Avatar
Is it modified by MSD for one cylinder application? If not, it's not going to work. Easiest way to get the tach wire is from the ignition signal at the coil pack. There are three wires to each of the coil pack. It's the wire (color with stripe) that shows .01V -.1V when the ignition switch is at the on position and the car is not running. The other wire is ~+12V(red) and the other one is ground(black).
vingodine
45
May 21, 2016 12:46 PM
mpbclutch33
Aug 21, 2015 06:09 AM
MaximaDrvr
Aug 19, 2015 08:20 PM
shaunkey1
Aug 18, 2015 10:09 PM
kjm900r
Aug 5, 2015 07:14 AM
