installing strut tower braces Qs
Old Nov 27, 2000 | 08:36 AM
tclee's Avatar
I know of one way to install them, was told to do so in another method by a friend...need advice here.
my way;
seat the car on the ground...meaning no jacking up of car or anything, then loosen the strut tower nuts, slap on tower braces and tighten nuts back on....then enjoy!
friend's way who said this is "preloading"
jack car up till wheels are off the ground and shocks / struts are extended...then loosen strut tower nuts and slap on the brace...tighten nuts as much as possible with the car still on the ground then lower it and tighten it even more!
so which is which...whose right / wrong, what is the correct way to install and preload strut tower braces?
thanks for all help
Old Nov 27, 2000 | 08:51 AM
Rit's Avatar
Rit
My guess is that when you have the car
jacked up, the allignment will not be correct, and then you will be "fixing" the car in a non-correct allignment. I would think it would be best to do it with the car packed on a level surface.
Old Nov 27, 2000 | 09:15 AM
Shingles's Avatar
The missing moderator
Install it with the car sitting on the ground. "Preloading" I donno actually does anything.
-Shing
my way;
thanks for all help
Old Nov 27, 2000 | 09:17 AM
AndyXXL's Avatar
Do it your way, dude.
nm
Old Nov 27, 2000 | 10:04 AM
cyclemax's Avatar
The manufacturer of mine (Courtesy)
instructs to install on the ground.
Old Nov 27, 2000 | 10:05 AM
JimW
One thing "preloading" will do--->
my way;
thanks for all help
Is put way too much stress on the studs that hold your upper strut mount to the strut tower. They are meant to be withhold tension (the tightening of the bolts to the tower) not shear strength (the <--- --->) force. You are asking for trouble by putting horizontal force against these relatively weak studs. If you torque them to approx. 80 ft. lbs they will snap. Think about it.
Otherwise, what good will it do by putting force on them and then tightening them down? The entire idea behind the strut tower brace is to Triangulate the front suspension. Eliminating the strut towers from moving (flexing) in relation to the suspension. If you eliminate all flexing, you will break something, more than likely the studs or the strut mount. Do it your way, tell your friend he's wrong.
Old Nov 27, 2000 | 10:13 AM
cyclemax's Avatar
JimW
Jim:
I agree with your recc for installation, but aren't the studs going to be under shear loads during normal function of the bar? I thought that was how they worked.
I suppose these could be insignificant in comparison to what's applied after he lets his car down.
Just a thought.....
matts95max
Apr 23, 2025 10:44 AM
MaxLife17
Jun 27, 2019 01:37 PM
BkGreen97
Apr 2, 2016 05:47 AM
dvcamp
Sep 18, 2015 10:17 AM
Johnny9595
Sep 3, 2015 05:18 AM
