ground controls question
Old Apr 27, 2002 | 11:24 PM
vinny1978's Avatar
question: can't get rear thread sleeve over the split sleeve. should i use some kind of lubrication? or just keep trying to push the thread sleeve over it?
Old Apr 28, 2002 | 07:44 AM
Re: ground controls question
Use white lithium grease or permatex industries "Teflon grease"
Lube the rubber gasket, and make sure you notice the inner notch must face down so the GC sleeve(red) fits over the lower "hump" of the shock.
After lubing the gasket, slide the sleeve over, here is a small trick I learned installing these: Get a hose clamp and clamp the bottom part of the gasket.(You'll see why later.)
Get the sleeve on as much as you can by hand.
You will need a rubber mallet for the next step, you have to start hammerring down the sleeve, evenly. The sleeve will go down, very slowly. When you get to the point of almost hitting the bottom hose clamp, take a sharp razor, and cut around the rubber gasket, then take off the hose clamp, hammer down the sleeve and rubber gasket.
Tricky part. Once you install these on the car, the car will settle, and you will have to get under there again to re-adjust them up. Its hard to say at this point what amount of drop you want, so I leave that up to you. Just remember to take stock hieght measurements.
If you have any further questions, feel free to email me.
-Peace
Matt93SE
May 24, 2019 02:58 PM
Johnny9595
Sep 3, 2015 05:18 AM
95Maxi
35
Sep 2, 2015 10:37 AM
doobadoo
Aug 15, 2015 06:43 PM
