Help plz with some ECU codes
Old May 5, 2002 | 12:14 PM
nismomaxse97's Avatar
Help plz
My check engine light came on:
Here are the codes
04 03 Throttle position sensor
11 04 Improper shifting to 2nd Gear
11 05 Improper shifting to 3rd Gear
12 06 Throttle position sensor (Automatic Transmission)
I have a 97 SE Auto, and it is running and shifting fine.
Has anyone ever gotten this set of codes?
Thx for any help
Old May 5, 2002 | 08:29 PM
Re: Help plz
Old May 5, 2002 | 08:39 PM
Bags's Avatar
VG Ridah's Biatch Hoe
reset your ecu and see if the codes come back...
it would seem to me that your Throttle postion and the time when your automatic changes gears do not match.your Transmisson Control Unit has set shift points for set RPM's.. they may not be matching right now.
Reset your ecu and see if they come back in a few days
Old May 7, 2002 | 03:19 PM
I will do that,
Old May 7, 2002 | 03:22 PM
bill99gxe's Avatar
Evil Administrator - "The Problem"
DTC 0403
Diagnostic Trouble Code 0403 points to a problem with the Throttle Position Sensor. The TPS responds to the
accelerator pedal movement. This sensor is a kind of potentiometer which transforms the throttle position into
output voltage, and emits the voltage signal to the Engine Control Module. In addition, the sensor detects the
opening and closing speed of the throttle valve and feeds the voltage signal to the ECM.
This malfunction may be detected in three different circumstances.
A) An excessively low or high voltage from the sensor is sent to the ECM. In this situation the ECM enters
fail-safe mode (acceleration will be poor) and turns on the Malfunction Indicator Lamp.
Possible causes include ...
- Harness or connectors (the throttle position sensor is open or shorted.)
- faulty Throttle Position Sensor
B) A high voltage from the sensor is sent to the ECM under light load driving conditions.
- fuel injector(s)
- Camshaft Position Sensor
- Mass Air Flow Sensor
C) A low voltage from the sensor is sent to the ECM under heavy load driving conditions.
- intake air leaks
Old May 7, 2002 | 03:23 PM
bill99gxe's Avatar
DTC 1206
Diagnostic Trouble Code 1206 points to a problem with the TPS.
The Throttle Position Sensor detects the throttle valve position and sends a signal to the Transmission Control
Module. The Throttle Position Switch consists of a Wide Open Throttle position switch and a closed throttle position
switch. The WOT switch sends a signal to the TCM when the throttle is open at least 1/2 of the WOT position.
The closed throttle position switch sends a signal to the TCM when the throttle is fully closed. The Sensor and
Switch are integrated into one unit designated TPS.
This malfunction may be detected when the TCM receives an excessively low or high voltage from the sensor.
- faulty Throttle Position Switch
Old May 7, 2002 | 03:26 PM
bill99gxe's Avatar
The Throttle Position Sensor seems to be the culprit and the common thread, which could be causing your 1104 and 1105 codes. Those in particular are rare enough to have never been covered on the dot org database.
Old May 7, 2002 | 03:28 PM
xHypex's Avatar
Hey Bill since no one ever read my ECU thread can you tell me what any of the 14xx codes are? Aparrently they are only on '99s and aren't very common. They also are NOT in the ECU decoder so searching doesn't help.
http://forums.maxima.org/showthread....=sensor+ground
-hype
Old May 7, 2002 | 03:48 PM
bill99gxe's Avatar
-hype
Hype,
Sorry, I have yet to find them. It would be nice to have a '99 FSM right now........
cyclemax had a similar problem, so you may want to PM him.
http://forums.maxima.org/showthread....highlight=1405
Old May 7, 2002 | 03:56 PM
xHypex's Avatar
Hype,
Bill, I emailed him to see if he ever figured out the problem. Also do you know where in the FSM it lists the codes? I'm not all that familiar with the FSM and I haven't bought one yet. I was waiting to see if it was going to be available on CD like the 5th gens.
Maybe I'll just break down and buy a FSM when I get back to Dallas.
Thanks again
-hype
Old May 7, 2002 | 04:00 PM
bill99gxe's Avatar
Thanks again
-hype
My collective research is the result of Daniel B. Martin's hard work and his reference to the '99 FSM. Almost all my ECU knowledge has come from his posts on these forums and are usually easily searchable by number.
If I knew I was keeping my 99, I would get a FSM. It will run you anywhere from $100 to $125, though......and it's only in book form.
Old May 9, 2002 | 06:36 AM
Thanks Bill
gigabyte
Jan 6, 2017 06:05 PM
maxinout93
Oct 31, 2015 02:04 AM
Kyle Lee Cleveland
Sep 28, 2015 09:01 PM
dshinn
Sep 26, 2015 08:07 PM
