Opinions on installed SMC shifter from you guys?
any of you guys that have installed the SMC shifter wanna give some feedback?.. Did this help the shifting any?.. or just make it rougher? (I've heard the throws are shorter.. but the shifting gets rougher).. I'm debating whether to keep mine or not.. I don't drag race.. I don't street race (that much).. I really don't see much of a need for it for me.... ok convince me to keep it fellas
The throws are noticeably shorter, at least where I have it adjusted (at ~2/3rd minimum throw). Notchier also, but not much. Installation is the MOST important thing...it affects feel sooo much...you HAVE to pound out the cat heat shield to eliminate rubbing with the bottom of the shifter, or the shifting will be way more difficult.
The shifter doesn't wobble around like a stick in jello anymore. The action is firmer and more defined than before. I like it very much.
I honestly don't think there's ANY real difference in throw times, though, at least nothing that would significantly decrease acceleration times. It's a mod that should be done solely to improve shifting feel and sportiness...really won't do a thing from a performance standpoint...at least that's my opinion.
Yes, that too. Not a huge difference, but must be ~1.5" or so shorter as well. Not nearly as short as on Miatas and BMWs, but still looks better. Not a huge diff, tho.
Originally posted by CKNY
Looks alot better too right? I still haven't had time to put mine in but I love the look of a short shifter much better than the stock frontier... i mean maxima shifter.
Chris
Chris
I love it! I installed it on its shortest setting and replaced the tranny fluid with Redline at the same time.
Shifting was stiff for about a week, but now I couldn't do without it!
Here are some pics to illustrate the height difference:
Stock shifter:
http://www.rit.edu/~ejj5875/maxima/img/center.jpg
SMC shifter:
http://www.rit.edu/~ejj5875/maxima/img/shifter_2.jpg
http://www.rit.edu/~ejj5875/maxima/img/shifter_3.jpg
http://www.rit.edu/~ejj5875/maxima/img/shifter_4.jpg
http://www.rit.edu/~ejj5875/maxima/img/shifter_5.jpg
Stock shifter:
SMC shifter:
Nice wheels ejj5875.
I've got mine set at about 2/3 length. Should have set it short as possible. It's going to be a pain in the *** to take it out and put it in again.
Also what kind of dash cleaner do you use. It looks good.
[Edited by nismomax on 11-29-2000 at 08:34 PM]
Re: Nice wheels ejj5875.
I decided to go with the shortest setting because, well, I figured that if I spent the $$$ for a SHORT throw, I should get my money's worth! I love it.
As for dash cleaner....I don't really. I Armor-All every couple of weeks, but other than that I keep a box of swiffers under my seat. My dash doesn't really get dirty, just dusty, and they work great.
Re: Re: Nice wheels ejj5875.
Mine was installed at 2/3, but there is rubbing against the cat shield in 2nd and reverse. I'm going to bang some dents in it this weekend. It takes about 1 - 3 days to get used to, but it feels and looks alot better. The guys ruined my aftermarket **** when installing it. For some reason they tried to unscrew it with a wrench. It's all scratched. But I ordered at new momo **** and boot. Currently my **** does not feel that secure on the shifter.
A couple questions:
(1) How does the cat shield come off? Is it just a couple of screws?
(2) Will I know where do bang out the dents in the cat shield just by looking. What should I bang with? Will a hammer work?
Any other tips are appreciated too.
A couple questions:
Re: Re: Re: Nice wheels ejj5875.
A couple questions:
A couple questions:
(2) - That's how I did it. Trial and error too. Its nice if you have someone else. That way you can lay under the car and hold the heat shield up and have them run through the gears. I used a rubber mallet. All it takes is a couple of good whacks.
I would suggest taking the cat off when you work on the shifter. I just left it hanging and it really got in the way. Its not that hard to remove, and I think it would be well worth it!
Re: Re: Re: Re: Re: Nice wheels ejj5875.
Did you jack up the car at all or just sneak under there?
vingodine
45
05-21-2016 12:46 PM
Fakie J Farkerton
10-14-2015 06:25 PM
