Maxima Driver needs help with Ford bronco 1995
Old May 13, 2002 | 11:56 AM
chinaonnitrous1's Avatar
hey everyone..i know this is OT..but I need some help...my shop at best buy...has a 1995 ford bronco in the shop..we did a full system...deck..4 speakers...3 amps..2 subs..capacitor..etc. But anyway...after we get done...the door locks wont function..we hit unlock..and the parking lights come on....Seems like theres a factory alarm or something because we hear relays that we havent seen before. So we fix the door locks...by addding new relays. But we find out the dome light isnt working..neither is the digital odometer. So whatever..he rolls out of the shop..and drives home..Today.. *ring ring* and i guess theres a couple other problems...his ABS light is flashing along with his O/D (overdrive). His transmission wont go into overdrive...and it shifts..and jerks the whole car. Were having the guy unplug his battery to "reset the computer". Its almost as if something in the vehicle isnt turning on. Like a blown fuse or relay somewhere. We've checked all the fuzes under the dash and under the hood but nothing. Any help would be appreciated. If you have any in depth ideas..please e-mail me directly at Chinaonnitrous1@aol.com or if you can..call 925-829-7041 Ext. 2240 ask for Larry or Steve..just mention that you have ford bronco info. Thanks for the support!
Old May 13, 2002 | 12:05 PM
Or if someone could post this on a Ford bronco forum..
Old May 13, 2002 | 01:01 PM
njmaxseltd's Avatar
Go over your entire install. Take the dash apart again and look at every connection. Make sure it's correct. The last thing you did to the car was install the system, so thats where your problem is.
A plug isn't plugged in, a wire connected wrong, a ground could be missing. Find the ECU and check all around it for something that isn't plugged in or lose. Look at every connector around your work area.
Old May 13, 2002 | 06:54 PM
krzymax's Avatar
Maxima owner since 2000
a little *bump* doesn't hurt...
halfpol
Oct 17, 2022 12:16 PM
jchronis2552
Aug 13, 2015 07:48 AM
Team STILLEN
Aug 10, 2015 04:29 PM
halfpol
Aug 5, 2015 08:24 PM
