Easy Question: How to take off bolts
Old May 13, 2002 | 01:50 PM
BBaker025's Avatar
On certain parts of my car, such as the metal part of the valve cover there are about 6 huge bolts. They look to tightly screwed in to take off w/ a socket wrench. What power tool do you use to take it off, im gonna polish it up sometime. Do they have attachments to drills that can take off a bolt? Whats the best brand, the most for the money is always best, where can i get 1?
Old May 13, 2002 | 02:13 PM
BBaker025's Avatar
How do all you people take off the bolts on your car???
Old May 13, 2002 | 02:17 PM
Jeff92se's Avatar
I'm needing a caw
Leftie=loosey Righty=tighty
Use a socket wrench or open/boxed ended wrenches.
If you are asking this type of question, I don't recommend power tools. Too easy too strip or break a bolt/nut
Old May 13, 2002 | 03:52 PM
mAdD MAX's Avatar
The hardest part about working on cars is taking out the bolts!!
The task could be done in much less time if only the bolts would come out like planned. Another problem is never having the right tool to do the job.
I'm curious about removing the valve cover as well. I don't seem to have any sockets that fit in those bolts.
Old May 13, 2002 | 05:12 PM
turbomax97's Avatar
I couldn't fix your brakes, so I made your horn louder
allan wrench
Old May 13, 2002 | 09:09 PM
FJC's Avatar
FJC
Re: Easy Question: How to take off bolts
Go to Sears and get Craftsman. They are the best tools for the money and they have a lifetime warranty.
To break big and tight bolts, use a "breaker bar". It will depend on the size of the bolt. If it's a valve cover, a 3/8ths will do. If you are working on suspension, use 1/2".
Get a Craftsman portable tool set for around 130.00 and buy the breaker bars seperate...
Here's a link to what I have for a portable set... Craftsman 159pc tool set
Sorry for ****in ya' off homie.... No hard feelings...
Old May 13, 2002 | 09:13 PM
FJC's Avatar
FJC
Also, they do have attachments for drills... DO NOT use them to break bolts, only to draw the nut off after breaking it. You will burn out your drill. I have a Dewalt 18V portable power drill and even that won't break a tight bolt. Always use a breaker bar/ratchet first.
litch
123
Jan 4, 2024 07:01 PM
Apr 16, 2020 05:15 AM
RealityCheck
Oct 2, 2015 06:34 PM
