removing all the stickers off my car!
Old May 13, 2002 | 07:05 PM
1HOTMAX's Avatar
i was trying to remove vynal stickers that are probably 1 years old and having a hard time, THEY ARE CRACKING AS A PEEL!
I'M USING MY NAIL and it's not very good right now/ i'm trying to get it off with out scratching the paint.
any tricks will be helpful. thanks.
well after i get the vynal sticker off, it's easy to remove the glue with goo off. the hard part is geting the plastic vynal off.
Old May 13, 2002 | 07:08 PM
DanNY's Avatar
Ad·min·is·tra·tor
hair dryer to warm it up..that helps. shoot some WD-40 in there to help get the goo off.
Old May 13, 2002 | 07:09 PM
Vyrus's Avatar
You shouldn't have put stickers on your car, much less your paint.
But I know you didn't want to here that so I'll try to help. Make sure you heat them up with a blow-dryer first so they're easy to peel off. It does make a difference. Try pulling them off slowly and pull them from the bottom up (against gravity). If they leave goo that's easily removable with a Bug & Tar remover, just make sure you don't scratch the paint (that's most important). But as always when removing stickers, take your time!
-Cyrus
clee130's Avatar
If it's on the glass, use a razor. Just lay a razor flat against the glass and push the sticker and it should come right off. Then wipe clean.
If it's on the paint ... well ... you could use the same tactic, just take it reeeeeeal slow.
Old May 13, 2002 | 08:16 PM
1MAX2NV's Avatar
Heat gun.
Old May 13, 2002 | 08:57 PM
JoesMAX's Avatar
dont forget to take off the NOS sticker
Old May 14, 2002 | 05:53 AM
2DMax's Avatar
Re: removing all the stickers off my car!
Go to the auto store....GooGone or UnDu are great products....
Lakersallday24
Jun 16, 2019 01:35 AM
stromm
Aug 27, 2015 04:13 PM
MAXSE5SPD
Aug 23, 2015 12:06 PM
kirkhilles
Aug 8, 2015 10:53 AM
yat70458
Aug 3, 2015 01:16 PM
