odometer off?
Old May 14, 2002 | 06:56 PM
maximaracer28's Avatar
odometer off?
I recently put new 17 inch wheels on my car, with a size of 215/40/17...now I know my odometer is off but how do I mesaure by how much? I searched but nothing, thanks,
Mik
Old May 14, 2002 | 08:08 PM
Newman's Avatar
Re: odometer off?
Mik
http://www.miata.net/garage/tirecalc.html
Old May 14, 2002 | 09:04 PM
fsumax's Avatar
Did you order a wheel/tire combo off the net? That sounds like one of the standard sizes I see on combos in magazines and stuff. Seems like it was for a honda or smaller car.
Old May 14, 2002 | 09:52 PM
JDwyer2821's Avatar
Damm it mike how many times do I have to tell u that the tire size is 205/40/ZR17
Old May 15, 2002 | 04:39 AM
redmaxpa007's Avatar
i SeE what you did therE
Old May 15, 2002 | 07:14 AM
once again red maximas are ghey....:::
Old May 15, 2002 | 07:36 AM
once again.. it sounds like maxima envy...
Old May 15, 2002 | 07:48 AM
I still own joo....and your automatic
Old May 15, 2002 | 08:09 AM
i honestly think i can get my leg between your wheel and the fender..
you are my 4 x 4 car of the year!!
Old May 15, 2002 | 08:25 AM
Haha I think I can fit my foot up somehwere else haha, anyways you try riding with 40 series rubber bands on wheels with stock suspension...all good though sprints or coilovers are coming asap...
Old May 15, 2002 | 10:35 AM
JDwyer2821's Avatar
7+ inches of wheel gap Its quite scary
Old May 15, 2002 | 04:11 PM
JAY25's Avatar
Re: odometer off?
Mik
Not to make you mad but you have been hanging here long enough to know that 215/40 is very very small wheel overall wheel diameter. Heck I just got my wife some wheels, recommended size is 215/40 17 I went to the Konig website recommended size was 215/45 and tire was still the same price. If this Post does not convince anyone else dont buy a 17x7 wheel, get a 17x8 with a 235/45 17. Your speedometer is reading as if your speeding and your not and your putting more miles then you should on your car. Sorry I can t help you convert that with the math part, but you can get the overall tire diameters from the tire Manufacturer and it will break down how many rotations will it take to one mile to each tire size and see etc....
Old May 15, 2002 | 04:46 PM
I got 7.5 not 7, and can i fix the odometer thing by putting different tires on? Or have the odometer re-calibrated? I dont want to put that many more miles on it?
Old May 15, 2002 | 05:14 PM
Newman's Avatar
what size are the stock tires?
yeah, difference size tires can correct any speedometer error (or most of it)
Old May 19, 2002 | 08:21 AM
DRVLKEuSTOLEiT's Avatar
Im in the same boat with the 205-40-17s
Being a Po-Boy Modifier myself, I have the econo grade 17x7 primax 10 spoke tuners for now, but sure beats the stock 15" cookie cutters. The deal was to tempting to resist regardless of the set backs it created.
As for the spedo its consistantly off 5mph all way around and God knows how many xtra miles I accumulated on the odometer since the install. Thats the least of the worries, with the low profiles 2 of my side walls are bubbling and it is unsafe because of the wheel-tire weight ratio throwing off my stock suspension. Also, it is causing tremendous chasis vibration at high speeds 55mph+ resulting in poor alignment of wheels and brakes as well as poor handling.
However, granted my brother is Mechanical Engineer and was on SAE Formula Suspension team at WVU, he was able to figure what tire size I need to get back to the stock diameter.
235 or 225-45-17
With those and the install of Eibach Pro Kit Springs and Tockico with courtesy of Delios (Sleeper), I should be out of harms way very shortly.
Play it safe, and listen to Michelin "cause so much is riding on your tires"
~PDP
Old May 19, 2002 | 03:52 PM
maxxed's Avatar
The maxima has a digital speedometer, there should be an adjustment somewhere somewhere behind the instrument gauge. Maybe someone who had had their gauge set out to replace a light bulb, or install indiglo gauges can tell is where it is.
Maxboy23
55
May 1, 2025 06:09 PM
litch
123
Jan 4, 2024 07:01 PM
mkaresh
Mar 12, 2018 06:48 PM
Djsmaxima
Sep 14, 2015 11:58 PM
