got camber adjustments?
Old Nov 30, 2000 | 10:04 PM
mrloyd
I thought it wasn't an issue, but maybe it is. So, just how many of you guys who have springs, have camber bolts or plates, and if not, do your tires wear even?
Old Dec 1, 2000 | 04:29 AM
Micah95GLE's Avatar
I don't, and my tires wear evenly.
Old Dec 1, 2000 | 05:32 AM
cyclemax's Avatar
I put H&R's in about 5 mo ago. At last rotation, I noticed very slight irreg wear (inside edge of fronts). I've been meaning to get it aligned, but haven't yet. I expect the camber is out slightly and can be corrected with the bolts, but won't be sure till it's measured. I believe the bolts allow adjustment from -1 to 1 degree, so I plan to install them first myself.
I spoke to a friend who is an alignment technician. He said that most places won't bother with setting the camber unless it's way out, like after an accident. They'll just do the "toe and go".
Old Dec 1, 2000 | 11:17 AM
focker2889's Avatar
based on my current knowledge on car lowering, camber plates are not necessary unless you lower the car for more 2" (a general rule of thumb). according to my H&R catalog, the stage 2 spring only lowers the car 1.4" in the front. I would rather not to have a camber plate because it may transfer more road noise. (Direct contact with the body without any cushioning)
Looks like people with Eibach Pro do not have the same problem of less lowering.
Old Dec 1, 2000 | 11:38 AM
cyclemax's Avatar
Focker:
I agree. I don't think that camber plates will be necc for a 1.5" drop. It is, however, a significant change in ride height, and I believe ANY change in height will affect camber. It may still be w/in spec, but I'd bet the farm it has changed. Some cars come from the factory in need of camber adjustment (bolts, usually).
Old Jun 15, 2002 | 06:26 AM
jasonz
I dropped 3 inches and im goin through tires quick lookg for plates now
Old Jun 15, 2002 | 07:40 AM
Larry's Avatar
cyclemax,
I have a 2002 Camry as well as my Maxima and let me tell you the Camry camber was way off. The rear was -1.0 and -1.4 camber. You could see the tires leaving in at the top with this much negative camber. I installed the camber bolts myself and used my level to adjust it vertical. I took my level to the dealer and measured 4 or 5 Camrys and they all have leaning tires. This can't be right. My level's bubble is perfectly centered on my Maxima front and rear. With weight in the Camry it even gets worse so that is not the reason. No more Toyota's for me!
Old Jun 15, 2002 | 11:17 AM
MetaOrbit's Avatar
Got Projectors?
Maybe Toyota intended for it to be that way? I know I've heard people say that some BMW's come from the factory with negative camber on the rear wheels (supposedly to help with high speed cornering?).
Dunno, just a thought.
John
Old Jun 15, 2002 | 11:59 AM
Larry's Avatar
MetaOrbit,
You may be right but I don't do any high speed cornering with this little 4 banger Camry and I do want the tires to last. I have never owned a car that had this much negative camber. I'm just afraid to leave it this way. The front is -.7 and -.8. I'm considering changing the front to no more than -.5. I just couldn't imagine the tires not wearing out prematurely with this much negative camber.
tarun900
19
Dec 20, 2021 06:57 PM
aw11power
Oct 10, 2021 04:57 AM
Apr 16, 2020 05:15 AM
leatherneck
Sep 30, 2015 09:16 PM
