Steering is off-centered...help?
Old May 25, 2002 | 01:08 PM
Kevin Wong's Avatar
So, I got into my first incident about a month ago. I got cut-off big time and had to take the lane the jerk changed from. To my surprise, there was road construction. I locked my brakes, then tried to get back into the other lane after the jerk passed me, but it was too late. The end result was me plowing over 5 big orange cones and bonking the curb at 20MPH with the wheel turned the left. I got my wheels re-aligned but now my steering is slightly off. Anyone know an effective and inexpensive way to correct this?
thanks
Old May 25, 2002 | 01:10 PM
Chunger's Avatar
My other car is a Hybrid
Re: Steering is off-centered...help?
thanks
The tie rods on both sides... the alignment shop should have done this for you...
Old May 25, 2002 | 05:33 PM
Kevin Wong's Avatar
Great, thanks a lot Chunger
I guess this isn't covered by the wheel alignment, but I'm glad it can be corrected. Thanks again Chunger, you've always been a good voice for answers and ideas.
Old May 25, 2002 | 07:45 PM
Chunger's Avatar
Re: Great, thanks a lot Chunger
It should be correctly set with the alignment but you CAN do it yourself...
Turn the tie rod on one side one way, the tie rod on the the other side the other way (equal) until the steering is centered. If you don't adjust both sides equally, you'll mess up your toe adjustment. I would take it back to the shop if it hasn't been too long. They should have done it correctly the first time.
Old May 25, 2002 | 08:32 PM
Kevin Wong's Avatar
The beauty of this is
I have a lifetime wheel alignment deal. I bought it the first time I needed an alignment and have used it 4 times already. Paid $120 from a Goodyear Center, though I heard a lot of shops upped their prices.
Old May 26, 2002 | 12:13 AM
Nismo's Avatar
Re: Re: Great, thanks a lot Chunger
you can do that but if you ever done that before, you will be amazed about how much just a little turn can do to your toe. When I alligned my front end on the lasers, Even tightening the jam nut together was enough to knock it back out of spec again.
Fbana41
Aug 29, 2016 12:18 PM
worldwiderecognized
Sep 30, 2015 01:16 PM
DC_Juggernaut
Sep 28, 2015 04:07 PM
