SC Adjustable?
Old May 28, 2002 | 12:07 AM
iansw's Avatar
SC Adjustable?
Is the boost on a V1 SC in any way adjustable?
I'm loking at my SuperCharger and see a hex bolt on top that almost looks like an adjusting bolt...
Thanks!
IanS
Old May 28, 2002 | 04:29 AM
Ramius83
The only way to change the boost levels on a supercharger is to change the pulley size......
Old May 28, 2002 | 05:49 AM
MaximaRider's Avatar
Ian i am sooo jealous, you have the VI and FI now...b@stard! Have fun Boosting
Old May 28, 2002 | 07:42 AM
iansw's Avatar
OK, cool...better to ask a stupid question than do a stupid thing.
IanS
Old May 28, 2002 | 08:24 AM
BlackCat's Avatar
RIP '98 Maxima SE
Ian, what are you planning for the BOV? Are you going to use the plastic Bosch bov that comes with the kit or are you going aftermarket? With the Blitz that I have it is adjustable and this affects your boost. I read in earlier posts about getting the ppphhhssst noise and adjusted it so that it happens easier. The trade-off I found that boost was weakened because the blow-off level was set too low.. Now I have it set that it blows off at a higher level and thus holds the boost longer. I may be wrong on this but this is my observations so far.
Old May 28, 2002 | 10:03 AM
iansw's Avatar
The Blitz came with my kit.
IanS
Old May 28, 2002 | 11:57 AM
jhans114's Avatar
IanS
Pulley Sizes and Boost:
3.60 = stock boost 5.5-6psi/safe
3.48 = 6-7 psi/safe
3.33 = 7-8 psi/safe
3.25 = 8-9 psi/pushin safe
3.125 = 9-10 psi / be cautios
2.87 = 10-11 psi / have some internals
2.62 = 11-12 psi / have a spare engine
Old May 28, 2002 | 11:59 AM
MaxedBandit's Avatar
3.48 = 6-7 psi/safe
3.33 = 7-8 psi/safe
Hrmm, I've heard the pulleys can put out different boost depending on whether the blower is a V1 or V2.
Old May 28, 2002 | 12:39 PM
jhans114's Avatar
The PSI settings I stated were for the V2, and to my ignorance I just noticed he got the V1 Well the boost is similar in that range. THanks for the correction.
tarun900
19
Dec 20, 2021 06:57 PM
aw11power
Oct 10, 2021 04:57 AM
Apr 16, 2020 05:15 AM
leatherneck
Sep 30, 2015 09:16 PM
