steering wheel shakes, help!
Old Dec 1, 2000 | 06:55 PM
TexMaximum's Avatar
Especially around 60mph. I’ll check wheel alignment first as that is the cheapest. Any other ideas?
This car is honestly starting to drive me crazy. O-rings or gasket might need to be changed as a little oil leaks in some of the spark plug sockets. Worse, my engine light says the speed senor/speedometer is bad though the sensor works and the gauge is $300 to replace and appears to work fine also. At 60K the extended warranty people are also a pain, and I purchased the Maxima as this was to be a very reliable, long lasting car. Of course the test drive was impresive for a "family/sport sedan". I suppose the mods didn’t help, but they’ve only been on for the last 8 to 10K miles. Any one else past the 60K and worry free?
Old Dec 1, 2000 | 06:58 PM
ßaller's Avatar
Alignment, balance and rotation it should help
If that doesn't help then it is something else.
Old Dec 1, 2000 | 07:00 PM
TexMaximum's Avatar
Thanks. Balance and rotation already done, and new tires. Allignment I have not yet done. I'm just grumpy as everything is going bad at once I guess.
Old Dec 1, 2000 | 08:09 PM
cyclemax's Avatar
Wheel Balance
Take a look at your wheel balance weights. There should be some on the innermost edge of the wheel and more either on the outer edge or just behind the spokes. Some places don't know how to properly balance a wheel with hidden weights so they just do a "static" balance, leaving the likelyhood of a dynamic imbalance (I won't get into it).
If you have a dynamic imbalance, it may cause a "shimmy" in your strg wheel.
Could be your rotors, too. I wouldn't waste $$ on an alignment in search of this problem.
Good Luck
Old Dec 1, 2000 | 08:29 PM
GarthG's Avatar
Mine did the same thing and it went away after an alignment. . . I am pretty sure this is what fixed it.
Old Dec 1, 2000 | 09:05 PM
Zprime's Avatar
yup yup
you gotta recheck your balance....
then maybe you can go with the alignment and umm did you change your rims?
there is something called a rim spacer...or something
anyhow...that is all I know.....
hope that helps...
Old Dec 1, 2000 | 09:39 PM
TexMaximum's Avatar
alignment is that much, and it it solves it, then great. I hope its nothing like a CV joint.
Old Dec 2, 2000 | 12:36 AM
Matt93SE's Avatar
STFU n00b!
Have you had to do anything with the CV joints yet?
I wrecked my car a couple years ago, and it drove great until I had to have a tranny seal replaced (because the !@#!@ at the body shop messed it up when they repaired my car)..
well, since they have to remove the axle/CV joint to do that, the place that replaced the seal didn't get it back in correctly and my car had a terrible shimmy for almost a year. I replaced wheels, struts, springs, sway bars, more wheels, 3 sets of tires...
none of them fixed it..
Well, finally a few months ago, I blew a CV boot while I was on a trip to visit family.. so I decided to change the boot while I was there instead of risk driving the 300 miles home on a torn boot.
when I got everything put back together, the shimmy was GONE. completely, totally gone. I'd been fighting this for a year, and even accused the guy that sold me my rims of selling me bent rims.. (which I have since sold to someone else and he had no probs)..
Soooo, my whole point is if you had any work done on your CV joints or axles or anything, that could be the problem. just yank the axle otu of the tranny, give it a 1/2 turn either direction, and bolt everything back together. it's 20 min job if you know what you're doing with the right tools.
Old Dec 2, 2000 | 03:17 AM
buss95max's Avatar
my steering wheel shaked after 60mph. after i got an alignment it was gone. now its shaking again, but this time its cuz i need an alignment(again cuz i lowered my car) and cuz my front right strut is str8 dead.
Old Dec 2, 2000 | 05:37 AM
bullseye's Avatar
I had a *slightly* bent wheel that caused similar symptoms. Darn bump-ridden Memphis streets!
Old Dec 2, 2000 | 07:09 AM
Micah95GLE's Avatar
It could be 3 things: Balancing the wheels, tires out-of-round (in which case they must be replaced, probably under a warranty), bent wheel. I've had all 3, and they all cause vibrations when on the front wheels, so look for all possibilities.
Old Dec 3, 2000 | 03:18 PM
TexMaximum's Avatar
cyclemax , I went and got an alloy 2 "dynamic" blance on each wheel, and an alignment. It just had a static. The problem is now gone!
Now I nee to rid my stupid engine light. Says 0104, speed sensor. Had the sensor checked and its fine, they claim its my guages, but they work!? Its a $300 repaid, and not covered in my warrenty Other then that, fix the paint a little and I'll enjoy the ride a lil longer I hope.
[Edited by TexMaximum on 12-03-2000 at 07:57 PM]
Old Dec 3, 2000 | 05:30 PM
NYCe MaXiMa's Avatar
suggestion:
I had this problem on my stock 15's before I replaced them.
It can be the things others have stated, out of shape tire, bent rim, poor wheel balance. I am not sure how alignment can cause vibration, I thought with a poor alignment the car would pull to the side, but who knows.
I suggest you take one of the front wheels and throw it on the back, take it up to 60 see if the problem continues, if yes, then do the same with the other front wheel, that way you might isolate the one wheel that is giving you problems and go check its balance/tire shape/rim shape.
hope this helps
Old Dec 3, 2000 | 05:58 PM
TexMaximum's Avatar
Hey, NYCe MaXiMa....but if you read the post above yours, I got it solved yesterday. Now I have a few more problems to look into, as listed
JoshG
51
Sep 21, 2015 10:41 PM
Bonka
Sep 14, 2015 11:18 PM
2kmaximel
Sep 10, 2015 08:13 AM
SusieQQ
Sep 9, 2015 12:14 PM
coasterswim
Sep 2, 2015 07:43 AM
