clutch pedal problem??
Old Jun 2, 2002 | 09:33 AM
maxdrvr847's Avatar
ok my clutch is finally in, just went with stock nissan one. thanks to brian (briguymax) and greg ( dustyroads ) its in!!!
but now for the question, my clutch pedal is extremely soft, it shifts fine but real soft pushing it in. we bled the system quite a bit. anyone know how to fix this?
Old Jun 2, 2002 | 09:42 AM
BriGuyMax's Avatar
Re: clutch pedal problem??
hey dude...I was reading up last night...and we didn't bleed the system from BOTH bleeder valves...that would probably help
Old Jun 2, 2002 | 11:25 AM
maxdrvr847's Avatar
ah man, where is the other one at?
Old Jun 2, 2002 | 03:25 PM
MAXINXS's Avatar
This sight has been quite helpful for me. It will show you were the bleeders are, and explain the bleeding process. The only difference I found, is you don't just have someone hold the clutch in and open the bleeder valve. The clutch must be pumped several times, then held in. THEN you open the bleeder valves.
http://www.motorvate.ca/
Mar 12, 2020 12:06 AM
Lilfatz301
Sep 18, 2015 08:06 AM
Maxxx10
Sep 13, 2015 03:16 PM
ef9
Sep 10, 2015 10:35 PM
slowlifer
Sep 8, 2015 05:53 AM
