where to go through fire wall?
Old Jun 3, 2002 | 12:27 PM
venompwr2's Avatar
I need to run some wiring through the fire wall,( I have a '95 maxima gxe) and there really arent any exsisting spots to go through, and i cant make a hole through it either. does anyone know where i can run these through to get into the interior??
Old Jun 3, 2002 | 01:04 PM
ptatohed's Avatar
Licensed to Spell
:o)
You have two choices. One, go through the driver side fender.
Read step #39:
http://www.cardomain.com/member_page...=181995&page=8
The other method is using the existing hole on the fire wall. It is on the driver side above the fuel filter. You'll see it if you look carefully. Good luck.
Old Jun 3, 2002 | 01:43 PM
Vyrus's Avatar
Re: :o)
I found this to be the easiest way. Do youself a favor and search around and you'll find many posts about it.
-Cyrus
Old Jun 3, 2002 | 07:01 PM
ny96max's Avatar
look for the clutch plate, its a few inches to the left of the brake pedal behind a cut out in the firewall padding
Ant
TKHanson
Nov 24, 2018 01:39 AM
RinconI30
Nov 10, 2015 10:55 PM
salty318
Sep 29, 2015 01:21 PM
salty318
Sep 28, 2015 07:22 PM
