can i adjust my pacestter STS without...
Old Aug 21, 2000 | 01:21 PM
removing any parts from underneath the car, i had just had my STS installed but i want to adjust the throe, thanks
Old Aug 21, 2000 | 01:28 PM
Keven97SE
Nope. Gotta remove it completely. n/m
Old Aug 21, 2000 | 02:35 PM
Matt_P
Originally posted by doug
how much did cost to install it.. and where did you take it..
Do the install yourself. This one is not too bad.
Old Aug 21, 2000 | 04:02 PM
Chebosto's Avatar
RIceD OuT moDErAtor
sorry bro, you gotta take it off..
remember to screw the ball on semi tightly..
when i first put it on, i didn't really tighten it.. and after a year of shifting the freakin' ball moved down the shaft. hahaha. so i had to remove it and readjust it..
it's simple..
besure to clean it throughly when you adjust it and to relube with some silicone grease...
Old Aug 22, 2000 | 12:26 PM
i tried to..but i can't remove the cat back bolts....
anysuggestion on how to get those suckers off? its really mad tight.
Old Aug 22, 2000 | 12:36 PM
Re: i tried to..but i can't remove the cat back bolts....
you could take off all of the exhaust hangers and pull it over, the flex pipe should let you bring it over enough to get off the heat shield and get at the bolts. maybe...
Old Aug 23, 2000 | 11:14 AM
Chebosto's Avatar
RIceD OuT moDErAtor
spray liquid wrench. then pound the sucka with a long wrench to get enuf torque..
maybe use your foot to kick it.. that's what i did..
Old Aug 23, 2000 | 11:37 AM
i'm kinds worried thought thst the whole exhaust will break...
if i apply to much pressure
tarun900
19
Dec 20, 2021 06:57 PM
aw11power
Oct 10, 2021 04:57 AM
Apr 16, 2020 05:15 AM
leatherneck
Sep 30, 2015 09:16 PM
