help
Old Sep 4, 2000 | 04:06 PM
00 black max's Avatar
I got a oo max its got 11,000 miles(demo model) i put on the stillen intake bout a month ago yesterday my check engine light came on. What gives? and since i put the intake on i cant throw into neutral right after i get on it decently hard it stalls out i was thinkin its from the 0 2 sensors
Old Sep 4, 2000 | 06:22 PM
sleeper's Avatar
intake
there is a thing that goes into the air tube.air sensor thing.when this is unplugged and plugged back in it will cause the check light to come on. unplug the battery over night. and /or wait for about 30 or so starts and the computer should reset itself. always disconnect the battery when unplugging stuff.then reconnect stuff, and when done everything, connect battery again, when finished. also u can turn up ur idle a bit . i had to do this, cause my rpm's where going low at stops and almost stalling. the screw is located on top of the throttle body, a black plastic flat head, turn counterclockwise a little while ur car is running ,to about 700-800rpm's.mine was 550 stock. i hope this helps. i have a 98 though.
Old Sep 4, 2000 | 11:45 PM
mingo's Avatar
air flow sensor
put it somwhere else... do u still have the ram air part of your stock intake left? if so then drill three holes to match it up witht hte sensor and just mount it there.
