My new reverse indiglo guages
Here's my new guages. I had to turn the brightness all the way up to even get the pictures to look semi decient.
Install went well too, I didn't run into any blunders anywhere. They came from Pro Car Parts, but not the website, I found them cheaper on Ebay. You can get them with shipping what it lists on the website for the price.
use the instructions on the maximadriver.com website and you will be fine. The only thing i did different was tap into a different wire for the power source so I didn't have to take the wire down to the dimer switch. I used one of the harnesses for the cluster which had illumination in it, you just have to look at where the circuit board is labeled and follow where it goes.
i have the same gauge's the only problem i noticed was that the fuel and temp gauges are not easy to see if you remove the 194 bulb from behind them, the needles aren't illuminated enough by the gauges.
Originally posted by guido_sst
Until you run out of gas because you can't see the gauge.
.I can tell where the needle is though cause the needle reaches the line which lights up adn you can see a dark spot which is where the needle is.
James92SE
142
Jan 2, 2024 09:23 AM
lrb6805
Sep 17, 2015 04:49 PM
