what size are the bolts on the y-pip?
i am getting ready to install my y-pipe and since they are rusty as hell im sure i'll break one or all of them. so what size are they? i want to go buy them ahead of time.
Re: what size are the bolts on the y-pip?
Here are some general instructions
anyone know how to get to the famous nut in the middle of the
ypipe??...that one nut that's in the back and out of reach
i've used those elbow joints or watever they're called
and still can't get to it
i am installing a ypipe on my bro's 97 i30 and need help
i got the o2 sensors off and the other nuts are easy to get
off except for that "one"
thanks
thanks
thanks
thanks
Originally posted by ericdwong
M10x1.25 IIRC. If that isnt it, its M12x1.25. I actually replaced all the studs on my cat with new bolts, and all the manifold nuts replaced as well.
yeah, i got ALL the bolts off fine EXCEPT the ones on the d@mn cat. i couldn't get them off for nothing. so in fear of stripping them i gave up. im gonna wait til our meet next saturday. man i was ****ed....
Trevor
Trevor
Trevor
Trevor
Dave
I used a torch (road flare actually) to heat the flange on the cat to expand it and then vice gripped the stud off. The nuts were so seized onto the stud in the other cases that brute force seperated the stud from the cat when using air impact or breaker bar. I actually would not suggest using home depot bolts. They are not grade 10.9 metric bolts (the equiv. of grade 8 for SAE) and will break easily, especially for a high heat application like the cat.
I got all my hardware from pep boys. Oh yeah, be sure to anti seize the F outta all the threaded bolts for easy removal.
Trevor
You just spray some Liquid wrench work on all the other 14MM nuts and come back and loosen that one nut thats impossible to get to. Is not that bad I dont know why people make a big deal out of that. Universal joint, 1/2 inch 14MM deep socket, Long extension, and if all possible instead of a small socket use a breaker bar with a adapter to fit 1/2 socket. Thats what I used to put remove and put my Ypipe back on.
Ypipe is an easy thing to do. To me the key is the breaker bar and Universal Socket joint.
right after i posted the question about taking out that nut
my bro already took it off....only problem w/the new
pipe is vibration and lots of it...gonna check that out tomoro
litch
123
Jan 4, 2024 07:01 PM
knight_yyz
Nov 1, 2015 01:34 PM
RealityCheck
Oct 2, 2015 06:34 PM
