2k2 Audio Installation
Old Jun 16, 2002 | 09:47 PM
MiniRX7's Avatar
I am installing a huge system into my 2k2 as well as a nokia car kit..
I got the metra dash kit, wiring and diversity antenna.
Are there any how tos or other FAQS or anything to take apart the 2k2 dash and doors... Any URL'S
Also i am goign to install my 2k2 deck into the 99 max, so if i can get how toos on the dash for the 99 too..
Thanks..
Also does anybody know the wiring schematics for both the 99 and 2k2s??
ED
Old Jun 16, 2002 | 10:25 PM
Stereodude's Avatar
2k2
For the doors: Undo the screw at the bottom of the tray in the door (under the cap). Then pop off the trim piece around the door handle (may require some effort with a few screwdrivers). Then pop off the round plug looking thing up by the mirror (on the inside). Undo that screw. Finally, find the notch in the bottom, insert hand and pull really hard. The door pad will come off.
[WARNING]There is no way to run your own speaker wire into the front doors. The rubber boot that goes into the front doors has a connector (with pins and all that jazz). You will have to get creative (or drill a few holes).[/WARNING]
For the dash: Yank out the vents (again pull really, really hard) You'll see two screws at the top. Take out the liner of your ashtray. Undo the screw at the bottom of it. You should be able to pop the lower peice with the flashers and lighter loose now. You'll see two more screws. Undo all four screws (upper and lower) then you can take out the whole console. Unhook the wires from the back and you should be good to go.
Stereodude
Old Jun 16, 2002 | 11:34 PM
MiniRX7's Avatar
Thank you so much..
Will start this weekend when i have time... I hope i don't break anything !!!
ED
Originally posted by Stereodude
2k2
Stereodude
Excalibur23
Oct 13, 2015 04:33 PM
2kmaximel
Sep 16, 2015 03:19 PM
popdedop
Sep 11, 2015 11:17 AM
