Artical In HCI about Boosted Maxs
If you are thinking about getting a SC then read this months issue of HCI (Hot Compacts and Imports). It has about 2 pages of a 2k2 maxima with stillen sc! It had dyno reports and all! Im just happy that the magazines are finally relizing the maximas power!
-Brian
-Brian
Re: Artical In HCI about Boosted Maxs
-Brian
-Brian
it's a fat article. Read it about 2 weeks ago... the max had a DIFFERENT SC put on it. It was a stealin but NOT the regular SC for our cars.
The max looked good to..looked like 1 I have seen on here..still looking to se if I can find it.
Originally posted by dmbmaxima88
where where where, i don't care who's SC it was i want it. NOW NOW NOW. i have an open race invite with a M5 and i want to keep up.
-steve
-steve
you should race your car with your intake against an m5 with an intake..
Originally posted by thebigsadler
so you can boast you beat a stock car? race a dinan charged m5 with your charged 2k2.. that would be something to brag about..
Originally posted by Chris91SE
what do you mean by different? non-vortech? roots type?
steve has the m5 you are talking about run 1/4?
unless you push like 12-16 lbs of boost i doubt the max stands a chance..but good luck
no he hasn't should be 13.0~13.2 i think. i should be at that with 9psi. i should have about 275hp now and on a good day run a 13.99. from a roll where traction weon't be as much of an issue if i have 400hp and he has 420 and i weight much less it should be close. i just want to hang, it will surprise the hell out of him..
Theres an alpine white E46 M3 w/ imola interior in my neighborhood now...
- M
"...This pair of lengthy inlet tubes running to and form the SC represented a major restriction to airflow, both in and out of the SC. The fix was to eliminate the pair of tubes and replace them with a single and larger inlet tube. Eliminating the twin-tube setup required switching the system over from a draw-through to a blow-through system, with respect to the factory MAF. The Vortech now was free to draw air through a larger air filter and produce the necessary boost pressure through a larger, single discharge tube..."
(This made me wonder if the SC kit for the 4th gen is a better breathing method.)
They incorporated a custom Powertrain Dynamics air-to-air intercooler and moved the MAF in front of the blower.
Originally posted by Y2KevSE
Sounds like they're talking about the 2k-2k1 Stillen SC kit. We have two tubes... intake (before SC) and charged (after SC). I actually regained 1 psi by switching to a CAI setup (dropped the intake tube).
Yep you're correct, Y2KevSE...the 4th gen kit has just one tube after the SC. As the K&N filter is directly attached to the blower I'm wondering why Stillen changed it to a two tube system? Was it to get cooler air from the bottom of the car?
Yes, supposedly it draws cooler air... but the downside is air restriction.
litch
123
Jan 4, 2024 07:01 PM
magiconthetire
Oct 26, 2015 09:03 PM
publix is the south
