rubbing in u turns with 245 series tires
well i put on my 19's and daymmmmmm i he11a rub bad making u turn is there any way to get rid of this?.? also my rims came with 4 spacers and i suppose to put these on ???
Re: rubbing in u turns with 245 series tires
maybe try putting the spacers on, but find out where it is rubbing, either on the outside wheel well where the fender comes over the wheel or if it is inside on the inner fender.
inner fender - use the spacers
outer wheel well - roll your fender up (it's probably just the screw in the middle at the top that is rubbing on your tires.
also what rims did you get?
Re: Re: Re: Re: rubbing in u turns with 245 series tires
Originally posted by thebigsadler
i mean i understand and all.. but really.. can't we just say.. "i rub bad" or "my tires are rubbing like sh*t"
Well the only think I can think of this the offset on those wheels are not correct. If you got the correct offset it should not rub at all. Plenty of people have 19s and couple even have 20s and they dont rub. You have to compensate evenly on the offset.
Dixit
Dixit
Dixit
Dixit
there 40mm offset the only offset the rims have, there 8.5 wide . it is rubbing in the inner fender well that leads toward the engine on both sides, every time i make wide turns my tires rub. the rims came with 4 black circles 2mm wide and 4 very thin metal pieces that are a u shape are these the spacers?
MR2 T'd
Jul 9, 2021 05:06 AM
