Sounds from WR Coil-overs!
Old Jun 26, 2002 | 08:45 PM
98_Maxima's Avatar
When ever I turn my steering wheel i get this awful creaking sound from the front springs. Is this suppose to happen? How do I fix it.
Old Jun 26, 2002 | 08:57 PM
gtr_rider's Avatar
192.168.1.1
try this.. www.vqpower.com/noiserem.htm
Old Jun 26, 2002 | 08:58 PM
max'n out's Avatar
Spring perch set screw?
Old Jun 26, 2002 | 10:26 PM
thebigsadler's Avatar
welcome to the club.. you see you have a metal threaded sleeve on a metal purch and when you turn it turns and clunks and creaks and there isnt a damn thing you can do about it.. just enjoy the nice low drop and the crappy ride.
you should weld your purches lower in the front to get a 4" drop in front..
Old Jun 27, 2002 | 09:15 AM
_DRU_'s Avatar
good deal, i will try that when i swap my struts, but... what if im too lazy to cut the tubing? can i just find a similarly sized one that will slide pring will slide into? shouldnt be a problem right?
Old Jun 27, 2002 | 09:35 AM
you wont notice a difference in sound with spring wrap.. just fyi. the springs dont rub, the coil cups do.
Old Jun 27, 2002 | 12:03 PM
gtr_rider's Avatar
192.168.1.1
Old Jun 27, 2002 | 12:19 PM
_DRU_'s Avatar
i thought it all clunks together when you hit bumps, wont this help the clunking?
Old Jun 27, 2002 | 12:50 PM
max'n out's Avatar
It really comes down to what is truley making the noise...across the net none of us know for sure.
But if the coils are hitting (fully compressed)alot, he needs better shocks first of all but a some spring isolaters could help, its the little rubber thing that goes around 2 coils.
If the spring is to little it could "jump" ever so slight to bang aganst the perch.
If it's a click, it could be the perch set screw when he turns.
So much stuff to check.
Mahmuth
Aug 16, 2024 08:23 PM
Miket2006
Mar 1, 2021 03:55 AM
AaronL
Aug 8, 2020 10:31 AM
Need help
23
Oct 2, 2015 08:56 AM
DC_Juggernaut
Sep 28, 2015 04:07 PM
