Rewire Blinker to stay on! And yes I searched
Old Jun 29, 2002 | 01:31 PM
NYBlakMaxx's Avatar
I just rewired my bumper lights so that they alternate blinking when lights are on and blink togethere when off. I want to know how to keep the part that blink on all the time when lights are on. I searched and found something about changing the socket from the corner bulb to the bumper but don't know how to go about this. A little assistance would be appreciated.
Old Jun 29, 2002 | 01:39 PM
turbomax97's Avatar
I couldn't fix your brakes, so I made your horn louder
Re: Rewire Blinker to stay on! And yes I searched
talk 2 sxr7 ( thomas) hes done it and it looks badass
Old Jun 29, 2002 | 01:45 PM
//M5'ver
i must be a genious when it comes to searching
http://forums.maxima.org/showthread....rnering+lights
Old Jun 29, 2002 | 01:51 PM
gtr_rider's Avatar
192.168.1.1
Rewire Blinkers
Old Jun 29, 2002 | 03:21 PM
NightRider's Avatar
Re: Re: Rewire Blinker to stay on! And yes I searched
I did it first.
Go to Pepboys or Autozone and get a dual filiment socket. (1157) It has three wires, one pos. and two grounds. Connect the the positive and one ground to the blinker, and connect the other ground to the sidemarker ground. Plug in an 1157 bulb and it'll work.
Old Jun 29, 2002 | 04:40 PM
TurDz's Avatar
I tried this mod before, and follow directions from a very informative website with pics and everything. BUT, I kept blowing fuses...and even the rear blinker fuses started to blow. So...I just put it back to stock and I have no problem anymore.
I'm still wondering though...is it possible to combine both blinker mods? Having the alternating feature while retaining the "always on" front signal bulb?
Old Jun 29, 2002 | 05:06 PM
NYBlakMaxx's Avatar
Re: Re: Re: Rewire Blinker to stay on! And yes I searched
Originally posted by NightRider
I did it first.
Thanks NightRider. I did use the search and it goes to show that the search function did not work that well cuz u both gave me the wrong info. I said that i have the alternate blinking and need the info for the blinker to stay on.
And what do you mean you blew a fuse all the time. I don't want that headache if I do this.
Old Jun 29, 2002 | 05:13 PM
//M5'ver
you want it to stay on.. its simple..
buy a dual filament socket
tap one power off the parking light that is to the corner of the bumper.. and tap one to the regular wire power wire for the indicator..
ensure that when you do it.. make sure if you have the light staying on on the bright power on one side.. do it on the other side.. and you will ahve to put in a 10 amp fuse because you are now overloading the car's lighting and power system.. so you have to trick it with the fuse
Old Jun 29, 2002 | 05:28 PM
NYBlakMaxx's Avatar
Cool! I had to up the fuse when i rewired my corner lights too. The fuse blew when i did them.
Old Jun 29, 2002 | 07:24 PM
MaximaPower's Avatar
so does ur light now blink and stay on all the time when u turn the lights on? cus i've made my signals stay on when the lights are on and blink when i turn on the signal..but i can't get it to stay on and get the sidemarker to alternate blinking...anyone know wat i mean??
Old Jun 30, 2002 | 03:14 AM
//M5'ver
if you one up the fuse already.. only up again if you run into the same prob
litch
123
Jan 4, 2024 07:01 PM
Miket2006
Mar 1, 2021 03:55 AM
JakeOfAllTrades
Oct 5, 2015 10:40 AM
leatherneck
Sep 30, 2015 09:16 PM
