Dissapointing Dyno results...
Old Jul 7, 2002 | 06:29 PM
BLKMAX's Avatar
Last weekend I went to a grand opening of this import tuner shop and had my car dyno-ed (it was a $15 promo) I was dissappointed.
I only did one run but the car did 121.9Hp @~ 5300 rpm, Tq was 144.0@ 4200 rpm. I have a CAI, UDP, Lightweight flywheel and Y-pipe. These numbers were dissappointing. This was the second time I had my car dyno-ed the first time my car had no mods the numbers were roughly ~113Hp and ~132 ft-lbs of tq -I couldn't find my old print-out but these numbers are close +/-. I live in colorado and have the VG engine new distributor, injectors and timing belt. Could altitude have this big of an effect on performance or is my car in need of some work?
Old Jul 7, 2002 | 06:38 PM
ILoveMyMax's Avatar
holy time for some tuneups and sensors to be replaced...clean the tb and see if u have leaks....thats all i can say.
Old Jul 7, 2002 | 06:59 PM
BLKMAX's Avatar
Thanks I'll take a look. I do have a fairly new O2 Sensor but I think my vacume lines are pretty old. But, to make my self feel better my brother has about 5k+ into his Focus and he dynoed at only 123 hp and 133 tq (not dyno tuned yet).
Old Jul 7, 2002 | 07:20 PM
arrow96's Avatar
Altitude is a factor..........
Altitude, temperature and barometric pressure have a big affect on any NA engine performance. Ask the dyno shop to correct their readings for the above and you should see some better numbers. Also I have seen wide variations from dyno to dyno on readings. So it does no good to compare numbers from different dynos..
Old Jul 7, 2002 | 07:21 PM
BrianV's Avatar
Maybe their dyno needs some breaking in? Also, it might be a clayton dyno which report REALLY low compared to the dynojet you're more accustommed to seeing, but the Clayton's tend to be more accurate.
Old Jul 7, 2002 | 07:26 PM
BLKMAX's Avatar
The temp here has been on average 95 and it was close to that when I got my car dyno-ed, and the elevation is 5003 ft. Mybe I'll shell out the $60 and get dyno-ed on a shop with a good reputation after I put in a set of new plugs.
Old Jul 7, 2002 | 07:30 PM
DA-MAX's Avatar
Eat, sleep, and sh*t 2JZ
definently get your car tuned up and re-do the dyno....an old member Hojo dynoed his VG auto(only mods were 2.5" catback and intake) and he dynoed ~127hp.....so you should definently be in the mid/high 130's or low 140s plus you're a 5spd!!!
DEFINENTLY TRY IT AGAIN!!!
Old Jul 7, 2002 | 08:52 PM
Nismo87SE's Avatar
Re: Dissapointing Dyno results...
I think altitude has made a big difference. But then again I also seen a 5spd VG with intake, Y pipe dyno 117whp/44wtq ? Never the less that person was very upset .
Old Jul 7, 2002 | 09:56 PM
AznWontonboy's Avatar
Re: Re: Dissapointing Dyno results...
44 tq?! did you mean 144?
Old Jul 7, 2002 | 10:06 PM
BrianV's Avatar
what's the elev there?
Old Jul 7, 2002 | 11:12 PM
Nealoc187's Avatar
SLOW
Its the elevation that made your numbers so low. People many times don't realize this.
Mr. Cranman dynod his 5spd VQ with JWT ECU, Variable Intake, and all the other basic bolt ons at 155hp. Corrected, his numbers work out to upwards of 195hp at the wheels. He is in New Mexico at 5500 feet, similar to the elevation in Denver.
Old Jul 8, 2002 | 08:02 AM
BrianV's Avatar
Yeah I have **** power at anything over 4000 feet.
I think they say something like 10% power for every 2000 feet.
Old Jul 8, 2002 | 08:17 AM
pro's Avatar
pro
Where in New Mexico is he, I am also from there. Blkmax, it is propably the elevation. Also what year is your max?
Good Luck,
Paul
Old Jul 8, 2002 | 12:02 PM
Dave B's Avatar
Not DAVEB the parts guy
Any reputable shop using a true Dynojet 248 should have the program in house that takes elevation into consideration when calculating the dyno results. There should be a "CF" Correction factor on the printout.
Dave
Ben2003GLE
31
Jul 17, 2016 08:13 AM
MaximaRaj
27
Oct 2, 2015 07:31 AM
MaximaDrvr
Aug 19, 2015 08:20 PM
mailalan
Nov 6, 2000 12:12 PM
Nismo87SE
Oct 23, 2000 08:15 AM
