AAHHH... I'm stumped, FP problems!!!!!
Old Jul 8, 2002 | 03:01 PM
mtrai760's Avatar
'Trynna' is not a word
Okay, I just reconnected my stock FPR, and I'm still getting fluctuations at partial 1/4-1/2 throttle!!!. The only thing I can think of is that maybe the length of the hose (I connected the stock FPR to the hose I had run to the AEM FPR) is flexing and causing the fluctuations. I'm pulling everything apart right now and checking it all again, and I'm going to put the FPR back in it's stock location and see if this makes any difference. If not, I really have no idea what to do next...
Old Jul 8, 2002 | 03:34 PM
1MAX2NV's Avatar
Are you using high pressure fuel injection rubber lines?
Old Jul 8, 2002 | 03:42 PM
mtrai760's Avatar
Yep, super expensive FI hose.
Old Jul 8, 2002 | 03:51 PM
Ramius83
So, you are not running N20 anymore and you reconnect the stock FPR. Try zip tying all the lines at the connections. You probably have a vacuum leak under one of those.......
Old Jul 8, 2002 | 03:53 PM
mtrai760's Avatar
Ive vacuum tested my system, no leaks...
Old Jul 8, 2002 | 03:55 PM
Ramius83
Dang, what about the fuel pump, what set-up do you have? Also, check your fuel filter as well.....
Old Jul 8, 2002 | 03:56 PM
Jeff92se's Avatar
I'm needing a caw
How is your stock fpr?
Old Jul 8, 2002 | 03:57 PM
mtrai760's Avatar
Walborro 255lph fuel pump, new fuel filter about 5k miles ago...
Old Jul 8, 2002 | 03:58 PM
Ramius83
And this also may be an odd question, but are any of your lines pinched at all?.....
Old Jul 8, 2002 | 04:02 PM
mtrai760's Avatar
Nope, checked that as well...
user 11122324
42
Jul 18, 2022 03:35 PM
gavin68
Sep 18, 2021 12:36 PM
HerpDerp1919
Sep 29, 2015 02:02 PM
zmcneely13
Sep 26, 2015 02:26 PM
homewrecker
Sep 24, 2015 07:01 PM
