ZEX Nitrous Kits, 2F2F Blow Out
Old Jun 8, 2003 | 02:32 PM
aggressivemport's Avatar
ZEX Wet Kits...
$525 shipped
(Either 55-75hp jets or 75-125hp jets)
ZEX Dry Kits...
$485 Shipped
Zex Kits Include the following:
ZEX™ Nitrous Management Unit (Part #82007), U.S. Patent #5,967,099
The NMU is the brain of the nitrous kit. It hides the senosrs and solenoids to keep your engine compartment looking good.
ZEX™ 15amp Power Arming Switch With Cover (Part #82002)
Protective cover prevents accidental system arming
High quality steel toggle switch allows many years of trouble-free service
Available assembled or as individual parts
Switch cover only - Part #NS6545
Switch only, no cover - Part #NS655
ZEX™ Nitrous Supply Bottle And Control Head (Part #82000)
Chrome bottle valve
Chrome bottle nut
10 lbs. purple nitrous bottle
-4AN Bottle valve fitting
Teflon bottle valve seal
Siphon tube
ZEX™ Nitrous Nozzle (Part #NS6550)
Precision CNC machined aircraft quality aluminum construction
Simple installation, screws into air intake tube behind mass air flow sensor
Three flow jet sets are included for your choice of 55hp, 65hp, or 75hp
Unique design provides perfect atomization of nitrous with intake air supply
ZEX™ Nitrous System Brackets, Hoses, & Hardware
Bottle brackets
Bracket, tall - (1)
Bracket, short - (1)
Nitrous delivery lines
-3AN stainless steel braided line, two feet long - (1)
-4AN stainless steel braided line, fifteen feet long - (1)
Vacuum hoses
Rubber hose, twenty-four inches long, 3/16 SAE30R/KY - (2)
3/16 inch hose clamps - (4)
Other hardware
Nozzle bulkhead fitting - (1)
Tap for cutting threads into the air intake - (1)
Wire taps - (2)
Barrel connector - (1)
Spade connector - (1)
Ring Terminal - (1)
Black cable ties - (10)
Grommets - (2)
Printed installation manual with pictures - (1)
All mounting screws, bolts, nuts, & washers
tarun900
19
Dec 20, 2021 06:57 PM
Pied
Sep 26, 2015 03:29 PM
Noela
Sep 26, 2015 08:22 AM
