Cattman-Progress Coilover Suspension - Intro group deal
Old Oct 15, 2003 | 10:17 AM
  #41
Cattman's Avatar
Maxima.org Sponsor
Originally Posted by speedemn
Wow thanks for all the detailed responses Brian.
I have a 5-spd and I actually had to have a new tranny put in just a month and a half ago. I broke my other one at the track. I actually have a US model SE... so my big hiked up stock suspension is not from Canada.
In any case, I ended up getting the same tranny as before - non-LSD but I did get the ACT stage 1 clutch and the UR flywheel.
I was looking into motor mounts when I kept blowing exhaust gaskets but cut that project short when I stopped blowing gaskets. The problem was with the cheap Budget Exhaust gaskets.... as soon as I put Nissan ones in there, I've never had a problem since.
Back to the coilovers, are you suggesting that I do not need to have adjustability in the struts to go from drag to street - only spring rates matter? If I have 850lb rear springs and regular 400lb front springs, I can see the possibility of there being massive oversteer in case of any 'situations' on the street. Could I hypothetically run 850lb springs in the front and 800lb springs in the rear, thus taking away oversteer... and still having the stiffness for the track? I know that it would greatly change daily driving by making it harsher... but I might not mind it all that much... will have to try and see... if it is a possibility to run those spring rates all the time to avoid swapping back and fourth.
Hypothetically you could run 850lb springs in the front and 800lb springs in the rear, but in reality this would not be a good choice. The optimal setup for the drag strip is not optimal anywhere else; you must swap the rear springs before and after you go to the track (not that big of a deal, expecially since there are no alignment issues on the rear axle).
If you owned your Maxima solely to drag race, then yes, you'd want to change the damping on your struts (by changing valve rates), but that setting plus the heavy springs is not what you'd want on the street at all.
Brian C Catts
Cattman Performance
Old Oct 15, 2003 | 11:14 AM
  #42
speedemn's Avatar
Maybe I am not able to visualize here... and I am going to go ahead and ask a n00b question. I've never owned or seen real coilovers. Would I need a spring compressor to swap the springs when I go to drag/leave the drag strip?
I would need a hydraulic jack at least, and a 10mm wrench... but anything else major? How long might it take?
Old Oct 15, 2003 | 11:37 AM
  #43
1MAX2NV's Avatar
Brian,
With the front struts? It looks like I need to reuse the OEM strut plate? Is this correct??
Old Oct 15, 2003 | 12:13 PM
  #44
matty's Avatar
what is the heigth adjustablity on these Coilovers ???
Do they plug right in or will i need anything from my stock setup ?
-matt
Old Oct 15, 2003 | 12:59 PM
  #45
Cattman's Avatar
Maxima.org Sponsor
I'm not sure about the springs compressor, and the reason for that is that you may be able to screw the spring perch down all the way and take the pressure off the spring so that the compressor is not necessary.
Brian C Catts
Cattman Performance
Old Oct 15, 2003 | 01:02 PM
  #46
Cattman's Avatar
Maxima.org Sponsor
Originally Posted by 1MAX2NV
Brian,
I'm not quite sure about the terminology, but the only parts you would re-use would be 1) the upper strut mount, i.e. the black piece that the threaded end of the strut rod sticks through, that bolts (3) into the strut tower opening (rear mounts are completely replaced by coilover parts) and 2) the little strut bearing piece that goes directly underneath the upper strut mount.
Brian C Catts
Cattman Performance
Old Oct 15, 2003 | 01:04 PM
  #47
Cattman's Avatar
Maxima.org Sponsor
-matt
Oh sure, there's height adjustability, just a matter of screwing the spring perches up and down. Maximum height would be about an inch lower than stock, but you can lower them about 2.5-3.0".
Brian C Catts
Cattman Performance
Old Oct 15, 2003 | 01:29 PM
  #48
Cattman's Avatar
Maxima.org Sponsor
-matt
The only stock parts that carry over (and this is explained in the installation instructions) are the front strut mounts and the little strut bearing pieces that go underneath them. Otherwise, the kit is complete unless you choose to use camber bolts.
Brian C Catts
Cattman Performance
Old Oct 15, 2003 | 06:48 PM
  #49
speedemn's Avatar
Brian C Catts
Cattman Performance
Lowering it any more than about 1.5" or 1.75" will also require caster and/or camber kit? Am I correct here? Do you provide something to supplement that?
Old Oct 15, 2003 | 08:47 PM
  #50
AltiMAX's Avatar
Q of the day
How many people have actually placed an order to qualify for the GD pricing ??
Old Oct 15, 2003 | 09:21 PM
  #51
gkstar's Avatar
I took some pictures of the coilovers installed, I don't have a way of hosting them and are probably to big to just post. If anyone wants to see them PM me.
Old Oct 16, 2003 | 05:36 AM
  #52
speedemn's Avatar
I can help you host them if you wanna e-mail them to anish.ghosh@rogers.com
Old Oct 17, 2003 | 09:03 AM
  #53
Kevin Wong's Avatar
I would also like to know. I'm interested, but my future actions will be according to the number of those committed. In other words, I'd like to join in if the price is right.
Old Oct 17, 2003 | 10:18 AM
  #54
Cattman's Avatar
Maxima.org Sponsor
You can place orders without concern that the minimum group deal limits will be met. We'll have at least five orders (qualifying for the $1075 price), but I don't expect there to be 10.
Our order line is open till 5pm MST, 800.759.9920.
Brian C Catts
Cattman Performance
Old Oct 17, 2003 | 10:23 AM
  #55
Cattman's Avatar
Maxima.org Sponsor
Going much lower than that will require more camber (not caster) adjustment, though dropping 1-5" - 1.75" won't. We offer the Progress camber adjustment kit, consisting of two camber bolts for each front strut. These allow far more camber adjustment than camberplates do because they are limited by the small opening in the top of the strut tower. They are also the source of much of the noise that coilovers are famous for -- Progress's coilover system (made for many cars) intentionally avoids that whole camber plate headache.
Brian C Catts
Cattman Performance
Old Oct 17, 2003 | 10:43 AM
  #56
matty's Avatar
Brian C Catts
Cattman Performance
Brian,
Do these Coilovers make any noise ???
-matt
Old Oct 17, 2003 | 05:47 PM
  #57
Cattman's Avatar
Maxima.org Sponsor
Brian,
-matt
There's probably no such thing as a coilover set that never makes any noise, but these are the quietest that I've ever operated. The absence of camber plates is a key reason, and those metal-on-metal problem areas are eliminated in this design, but its still necessary lubricate the tops of the spring assemblies with white lithium grease.
Brian C Catts
Cattman Performance
Old Oct 17, 2003 | 06:12 PM
  #58
matty's Avatar
Brian C Catts
Cattman Performance
So this is still considered a "True Coilover Setup" ??
Whould Isolator sleeves from Nissan possibly work ?? maybe cut a little section for the top, just to quiet the top spring assembly...
-matt
Old Oct 17, 2003 | 08:24 PM
  #59
Cattman's Avatar
Maxima.org Sponsor
-matt
I'm not sure what would suggest otherwise, but yes, this suspension is the essence of a true coilover setup!
There is no particular noise issue about the top spring assembly. Its just a matter of lubrication during installation, I'm not talking about doing anything unusual or damping it with a ton of grease.
Bottom line, these are extremely quiet coilovers and I have an extensive frame of reference to base that on, what more can I say?
Brian C Catts
Cattman Performance
Old Oct 18, 2003 | 12:26 AM
  #60
matty's Avatar
Good deal..ill wait for them in the mail
-matt
Old Oct 18, 2003 | 03:07 PM
  #61
Max4Speed's Avatar
www.autotalk.com
So any pics of this setup?
Old Oct 18, 2003 | 09:04 PM
  #62
matty's Avatar
ya, whats happenen with them pictures ??
-matt
Old Oct 19, 2003 | 07:04 PM
  #63
gkstar's Avatar
-matt
I sent speedemn an email couple days ago. I'm planning on making a cardomain site some time tonite and will put the pics on them. The lithium grease is a TOTAL necessity. Mine are similar in NOISE LEVEL(don't want to have any, confusions this time) to stock.
Old Oct 19, 2003 | 07:08 PM
  #64
matty's Avatar
Stock doesnt make ANY noise at all...well at least mine didnt...Do these Coilovers get annoying there soo loud...or would you call them QUIET ??
-matt
Old Oct 19, 2003 | 07:18 PM
  #65
gkstar's Avatar
quiet, after the lithium grease. i have a few squeaks here and there, but had those on stock suspension too, nothing annoying though. fairly infrequent
Old Oct 21, 2003 | 03:44 PM
  #66
gkstar's Avatar
i finally have a cardomain page up with some basic pics of the coilovers installed on a 5th gen.
Old Oct 21, 2003 | 04:26 PM
  #67
Max4Speed's Avatar
www.autotalk.com
Is it me or the car is lower in the front?
Old Oct 21, 2003 | 04:32 PM
  #68
gkstar's Avatar
just went outside and measured, the front is 1/8" lower then the back. the roof rack makes in look more because it is sloping down. just realized profile is of first height detup site will have pic of new profile(sorry about a little foiliage in the way)
Old Oct 21, 2003 | 04:59 PM
  #69
BEJAY1's Avatar
Conecarver
How many got in the GD?
So Brian, how many orders did you get? I assume 5-9.
Old Oct 26, 2003 | 10:47 AM
  #70
rob van dam's Avatar
So how much are these?...i want some new coilovers...i want these or thr JIC's....
  #71
matty's Avatar
Brian,
When will all the orders be shipped out ??
-matt
Old Oct 26, 2003 | 11:54 AM
  #72
BEJAY1's Avatar
Conecarver
Old Oct 26, 2003 | 01:05 PM
  #73
Originally Posted by BEJAY1
what's that supposed to mean??...
Old Oct 26, 2003 | 01:32 PM
  #74
BEJAY1's Avatar
Conecarver
You asked how much these are. It's a group deal thread with pricing on page 1.
Old Oct 26, 2003 | 01:42 PM
  #75
...woopsie....
Old Oct 26, 2003 | 04:48 PM
  #76
MyownNismo's Avatar
Future Camaro SS owner
...woopsie....
Yeah but the GD is over...Also info was on front page. I want to know if he will start it up again.
Old Oct 26, 2003 | 08:31 PM
  #77
Cattman's Avatar
Maxima.org Sponsor
Brian,
-matt
I'm pretty sure that everything that's been paid for has been shipped out already.
We carried the y-pipe group deal over till Monday, 27 October, and I'm happy to do the same with the coilovers, but that's it. Price will go back up to $1250, which is still the intro price (regular price will be $1350).
Brian C Catts
Cattman Performance
Old Oct 26, 2003 | 08:32 PM
  #78
Cattman's Avatar
Maxima.org Sponsor
We cleared 5, though not by much.
Brian C Catts
Cattman Performance
Old Oct 26, 2003 | 08:38 PM
  #79
MyownNismo's Avatar
Brian C Catts
Cattman Performance
I meant later down the road when I have money.
Old Oct 26, 2003 | 09:42 PM
  #80
Brian C Catts
Cattman Performance
I have my groudn cotnrols all the way down up front and i still have like 2 fingers....I want one or maybe less then one finger....will i be able to slam LOW with these coilovers?...
