I'm about to place an order for remote start units. Does anyone have any interest in purchasing a unit?
Depending upon the amount of people purchasing that'll determine the final price for each unit.
Figure about 45 - 55 per unit + shipping
not sure yet,
Any preferences?
check my linecard for what I handle most make a basic remote start unit. I just need it all to be one brand
Any preferences?
I heard Rattler are a pretty good brand. But doesnt the remote starter effect the starter? I have heard from past experiences the starter goes dead after a while!!
Quote:
Total Poppycock! Your car / starter can't tell the difference between you turning the key and a relay tripping the circuit.Originally Posted by tightblue89
They may have had other problems on the car that caused the starter to fail because of excessive cranking.
A number of the brands come with remote start while some others have it on a higher level (more xpensive) unit
my wife's remote start is more of a keyless entry than anything. push left button for lock, right button for unlock, and both buttons for start.
can't be much simpler than that.
wsh I could remember what brand it was... paid about $100 for it from the local stereo shop and installed myself. took about 2 hours. not bad at all.
I'd be interested in a couple remote starts one has to be for manual and one for automatic.
But I've had my best luck with DirectStart models so if you carry those or can get them count me in.
www.12voltshop.com is the link for the directstart remote starts.
my work sells rattler remote starts which are made by DEI which makes viper and alot of other alarms. they seem to be pretty good from my expieriance with them and you could install them yourself with a test light and a wire diagram which i bielive is on craig braces site.
if you dont program the TACHOMETER wire or use the voltage sensor for the remote starter it can fry your starter because the remote starter wont know when to disingage it and it could still spin for a few seconds while the engine is running
Very interesed!!! I was just actually looking for an alarm with a remote start unit. I've got the little door keypad joint that I don't know the code for. I'd much rather have a remote anyway! Let me know what you come up with.
Quote:
Any preferences?
Well, I've personally had EXCELLENT experiences with Crimestopper remote starts, alarms, and keyless entry systems. I've been installing them locally for the past 3 years, and sold/installed them when I was in college at Tampa, and have only had 2 returns as a result of product failure (which I think is a pretty good ratio). Originally Posted by internetautomar
not sure yet, Any preferences?
Their install instructions are straight-forward, uncomplicated with outboard relays (for the remote start units), and compact. And their tech support people know their stuff.
I've also sold/installed DEI as well as Avital (before they got 'absorbed' by DEI) products, and because the R&D person for DEI trained me and was my proctor for my MECP exam, I've got VERY good inside info on both those systems.
If you want to go with Crimestopper, you can virtually lock me in for all my future purchases. I've got their top-of-the-line 2way remote start/alarm installed on my Max and can advise as necessary.
subs1000w - Most, if not all, 'logic' circuits in the better quality remote starts are designed to either recognize tach programming OR voltage sense. That's the beauty of the ones I install - if you don't program the tach, it "defaults" to voltage sense.
But tach programming IS the least problematic....
I'd probably be interested as well... I'd like something with a keyless entry as well tho...
Matt - you say it only took you 2 hrs? Did it come with Maxima-specific directions, or are the universal directions enough?
Matt, if you had a decent pic of the remote, I might be able to tell you...Originally Posted by Matt93SE
my wife's remote start is more of a keyless entry than anything. push left button for lock, right button for unlock, and both buttons for start.can't be much simpler than that.
(finally a subject I'm intimately familiar with...)
ive got the fm paging remote with lcd display. unit is alarm and remote start with keyless entry. got it off ebay and love it !
yes...a remote starter can be nice. i rather push a button than walk outside in frigid weather to start my car up.
gowirelessnj - I've installed one of those before. That remote is a bit smaller than mine, but it does the same thing as mine. Their instructions were a bit ghey, though. But still a nice system.
NWP Engineering.com
i would only be interested in keyless entry and truck release. If it had any other options on top of that, then no problem.
But count me in if you have the stuff i mentioned above.
But count me in if you have the stuff i mentioned above.mine has trunk release, door lock/unlock, parking light flash, one lcd paging remote and one standard remote, loud a$$ siren, remote start on/off, and accessory of my choice. all in all its a great system. plus shock sensor, remote window rollup, starter kill, fuel kill, motion sensor hood and trunk pins and the obvious red led to top it off.
frigid in Houston?
I'd recommend a DEI product (dont know about all the others) because they come with lifetime warranty (at least the viper does) and are very easy to redeem with them if anything at all goes wrong. I have a dei remote start/keyless and reinstallation initially took me about 3hrs without soldering. Oh and one touch windows on all sides is sweet too, so internetautomar, you can look into getting the windows modules too.
oh and i believe most starter problems are caused by excessive /over cranking.
I'd recommend a DEI product (dont know about all the others) because they come with lifetime warranty (at least the viper does) and are very easy to redeem with them if anything at all goes wrong. I have a dei remote start/keyless and reinstallation initially took me about 3hrs without soldering. Oh and one touch windows on all sides is sweet too, so internetautomar, you can look into getting the windows modules too.oh and i believe most starter problems are caused by excessive /over cranking.
Quote:
Quote:
Originally Posted by lophix
frigid in Houston?
once it gets below 40 degrees i consider it cold. it got down to 30 degrees last week!
i know it doesn't get as cold as northern regions of the state though
Directstart appears to be their own in-house brand. so I'd have to try to setup an account with them to buy it.Originally Posted by Nozama
I'd be interested in a couple remote starts one has to be for manual and one for automatic.But I've had my best luck with DirectStart models so if you carry those or can get them count me in.
It looks like I'll probably be going with the crimestopper RS900
http://crimestopper.com/remotestart03.html
I'll have to double check the price on monday because I left the psheets at my day job
yeah there were some mornings down in houston that my windshield was iced up. Still i'd take houston anyday than dreary dreay kansas over the winter.
i don't know who actually "makes" a remote start system for manuals apart from compustar. Does Direcstart?
Yes directstart does make remote starts for manuals, the activation procedure means you won't start the car in gear.
More info available on their site.
I have a manual in my car and it's the remote start we use for our ford diesel 6-speed tow truck, thats why I was interested.
Sorry for the hijack
I also like Crimestopper stuff. I've used many of there remote starts and keyless entrys on a bunch of maximas, a camry, accord, 2 preludes
I have the RS900IV and am very happy with it. Installed it myself on my 5spd and made it so it wont start in gear
I work at circuit city as a roadshop installer, I'd definately go with the DEI alarms. BTW If you have a 99+ model, you'll also need a transponder + give up a key for it.
Quote:
Not any more you don't. They now make a transponder bypass that does NOT require you to get the customer to give up that expensive @$$ key (which I'm sure they will appreciate). Not DEI, as they still use the 555U, but I know Crimestopper makes it.Originally Posted by talisman311
...If you have a 99+ model, you'll also need a transponder + give up a key for it.
internetautomar - You'll like the RS 900 series. They are now on the series VI, which has a little better-looking remote (for those of us with this indiglo fetish) and a different programming method for their tach. But otherwise, it's straightforward and easy to understand.
And the beauty of Crimestopper (as opposed to DEI) is that you don't have to be an authorized sales/installation store in order to have your customers apply for the company's lifetime warranty, unlike DEI. Just have the customer send in the warranty card and they are IN!
But if you need any tech info on their stuff, they have a guy there named Jesus that no speakie dee engrish well (no offense to my Hispanic brothas and sistas), but knows his SugarHoneyIceTea!!
So who's in?
$60 + ship RS900VI
for manual trans cars
$60 for an Ultra start unit specifically for manual trans cars.
Both units have keyless entry as well.
I'm hoping to get this done by the end of the week.
$60 + ship RS900VI
I'm in if I can get a system that includes keyless entry/alarm as well. I currently own a '95 GXE, withOUT keyless entry. Is this a problem?
-email sent as well-
Keyless entry is included, alarm I'd have to get a different unit for you. Which is actually not a big deal.
This particular vendor has:
Avital
Crimestopper
Marksman
Ultrastart
Valet/Hornet/Python (DEI)
Haven't recieved an e-mail
Also I CAN mix and match units for pricing
Avital
Crimestopper
Marksman
Ultrastart
Avital
Crimestopper
Marksman
Ultrastart
Would this effect the factory alarm?? Although mine is disconnected right now because of a bad sensor. I am in if you can get the good deal.Originally Posted by internetautomar
Keyless entry is included, alarm I'd have to get a different unit for you. Which is actually not a big deal.This particular vendor has:
Avital
Crimestopper
Marksman
Ultrastart
most have the ouputs to bypass the factory alarms.
Or if you're already disconnected just wire it normal as if it never had an alarm
