Someone in the 4th Gen forum said PB Blaster (walmart, autozone, pepboys...) works much better than wd40. I'm going to pick up a can and start spraying my bolts a few days before I install.
Sometimes its easier just to torch the bolts to get them loose. When you un-bolt the front cat converter bolts just torch'em instead of using PB blaster or WD-40. Also get the biggest breaker bar you can get and a 14mm 6 point deep socket. Ive never had any problems with the 6 header bolts, just the two cat converter bolts were the biggest PITA until I torched them. Ive done a few Y pipe installs there not that tough if you have the right tools.
Oh and if anyone in the Massachusetts area is having a tough time with the install bring'em to me and I can do them.
FYI bring money for beer.
Quote:
By torching do you just mean heating them up with a blow torch? How hot do you need to get them? You're not cutting them are you? Hot metal expands...does this soften them or melt/break the rust?Originally Posted by 98SEBlackMax
Matt
Quote:
Matt
I heat them up with a propane torch for a few mins. I think the heating and cooling helps break the rust seal. If I had acteylene It could be done in a matter of seconds but propane takes a while longer.Originally Posted by budha56
By torching do you just mean heating them up with a blow torch? How hot do you need to get them? You're not cutting them are you? Hot metal expands...does this soften them or melt/break the rust?Matt
this has to be the biggest group deal EVER!!!
10 cool points to warpspeed for giving such a great price. I paid 215 shipped for mine 2 years ago. this is a sick price.
easiest way for a new car bought from nissan..every car has that piece of paper attached to the rear passenger window..with the description of the car and everything..there itll tell you if its cali or fed spec emissions. that piece of paper is still in my glove compartment after 4+ years
or do wut mm was writing about..if the car model # has 12 characters..it is cali spec?
Quote:
four sensors in front of valve cover = CaliOriginally Posted by PearlWhtMaX2000
ok quick question, how can iu tell if my car is cali, or fed spec?
two sensors in front of valve cover = Fed
wow i must be cluless, i still cant tell
right behind the radiator cap. you see the two injectors. one is green and the other is tan. if you have 4 of those you are cali, if you have two like the picture then you are fed.
Quote:
You didn't want in this deal did you? Cause it's closed.Originally Posted by PearlWhtMaX2000
oh ok, i have 4 green, so i guess im cali thanx alot
Quote:
technically i think the gd is done but call dallas he is a very nice and understanding man hopefully he'll just cut you some slack. good luckOriginally Posted by ghostmax
ahhh! i just saw this today. wonder if i can still get in for a 92 SE? what a deal!
The deal is closed now. If you want in you have to ask WSP. If you haven't given me ALL your info AND paid, do that ASAP.
Matt
Matt
got y-pipe installed. Its alot easier than i thought. Every1 should do this install by yourself and save money. If you have ever changed you oil, you can do this.
just called them and gave them my CC info.
she said they were shipping them out in order they recieved payment so she didnt know when mine would be shipped.
cant wait!!!!!
cant wait!!!!!
Quote:
even if you are cali spec???Originally Posted by topdog1207
my check engine light is on now. Do i need to reset the ecu? I forgot to disconnect the battery when i did the install. Guess i was to excited.
Quote:
Yes, I think you do. You'd probably get better info if you post this in one of the other forums...most of the people here including me haven't done this before.Originally Posted by topdog1207
Matt
Quote:
yes, u have to reset the ecu.Originally Posted by topdog1207
ur check light will come on if u dont disconnect the battery when u install.
Quote:
let me know how much they charge uOriginally Posted by Oblongshapes
2nd attempt. they're too rusted... looks like im going to meinke:*(
thanx
Most Perverted Member of the SE-L Club
paid today.....that woman must be one of the nicest people i've ever dealt with as far as customer service. Custommaxima.com should take a lesson.
I don't know what you guys did to her, but she must have explained six times that the pipes were being shipped in the order that payment was recieved, even though i told her everytime that i was excited, but i could wait.
Just a thought, does anyone know if there is a part number for the set of bolts? that way, i wouldn't have to worry about breaking the friggin things off.
Recieved Mine a while back buy called agian to ask about a B-pipe.
They are still hard at work packaging and shipping the Y-pipes.
120+ Pipes sold just by the Group Buy, $160.00 x 123 pipes = $19,680
Damn.
JP
Damn.
JP
Quote:
Damn.
JP
Don't forget the cats.Originally Posted by SpeedCrazie
120+ Pipes sold just by the Group Buy, $160.00 x 123 pipes = $19,680 Damn.
JP
