GD for SECOND run of replacement rear shock mounts
Old Oct 9, 2004 | 07:07 AM
  #81
Terran's Avatar
You shouldn't need to replace the rear mounts. These are not stock replacement however. They will give back some of the travel (in the rear only unfortunately) that you lose with lowering springs.
Old Oct 9, 2004 | 08:46 AM
  #82
vipervadim's Avatar
I like Maximas
Originally Posted by haysdb
You re-use the original mounts, or at least that's what *I* plan on doing today. I'm not sure why they would need to be replaced, but maybe that will become obvious when I remove mine.
I asked my Nissan parts department about the mounts, and they said they stock the bearings but not the mounts, which tells me that they don't get replaced very often.
I just put in my tokico Illuminas and H&R springs 1 month ago (i'm the 10th person on this GD)
if you want my opinion i think you will need these if you feel your back is a bit bouncy. i live in brooklyn where most roads just about suck so suspension travel is important for me (i don't want to be hiting the bumpstops every 3 mins)
I replaced the front bearings (one was blown) and the upper front mounts too. if you check the rubber bushing in the front upper mount it can be veryl flat and worn out from the XXXK miles abuse on it. mine had small rips in the middle of the bushing, once i saw that i knew i had to replace them. but every car is different so you might not need to replace yours.
-Vadim
Old Oct 9, 2004 | 03:45 PM
  #83
mzmtg's Avatar
Minister of Silly Walks
The first batch of parts arrived yesterday
I've begun shipping to those who have already ordered.
I have a few sets left for those that are interested. They are in stock right now, so I can ship them immediately.
Big thank you to everyone who participated so far.
Old Oct 9, 2004 | 04:52 PM
  #84
RA030726's Avatar
I'm nutty for Nissans
yeee haw!123
Old Oct 10, 2004 | 08:23 AM
  #85
glass88jaw's Avatar
pm sent!!!!
Old Oct 10, 2004 | 11:38 PM
  #86
96_vqmax's Avatar
Did you get a PM from spanishrice?
Old Oct 11, 2004 | 06:01 AM
  #87
mzmtg's Avatar
Yup ......
Old Oct 12, 2004 | 02:08 PM
  #88
mm347's Avatar
-Vadim
Vadim,
Do you have RSB... if so does it change things?
I just bought Illumina's from the other group deal and would probably need these mounts as well, but don't really have the $ right now (need to get springs first).
Old Oct 14, 2004 | 10:37 AM
  #89
mzmtg's Avatar
http://doug.maxima.org/showthread.php?t=345754
Old Oct 14, 2004 | 07:58 PM
  #90
GodsmackMAX's Avatar
Just got mine today!!! YAAAAAYYY!!!!
One ? though. I have KYB GR2s and Maxspeed springs, does it really matter which way the orientation of the spring/strut is? Your instructions say to mark it with a pen or something. When I installed them, I didn't even do that with the stock spring mount.
I just seated the spring in the indention at the bottom of the strut and lined up the strut with the hole on the car and put the bolt through. Was I doing this wrong?
Thanks! And extra thanks for the great GD!!! Hopefully I will be able to put them on soon and give a good review.
drew
Old Oct 15, 2004 | 05:35 AM
  #91
mzmtg's Avatar
drew
Marking everything before you take it apart just makes reassembly a little easier Once you get it all back together, it's difficult to rotate the upper mount if it's not lining up with the holes.
Old Oct 15, 2004 | 01:35 PM
  #92
SupaMaxima's Avatar
I'm interested. You still taking orders for these? Thanks
Old Oct 15, 2004 | 06:01 PM
  #93
mzmtg's Avatar
Definitely. Send me a PM or Email with your ZIP code so I can get you a shipping quote.
Old Oct 16, 2004 | 03:59 PM
  #94
Sin's Avatar
Sin
Got any pictures of these things? Kinda interested, want more info, i.e. pics.
Old Oct 16, 2004 | 06:02 PM
  #95
mzmtg's Avatar
I dont have any pics of the final production pieces, but they do have a nice black polyurethane finish
The pic in the first post of this thread gives the best illustration of how they work though.
Old Oct 16, 2004 | 07:55 PM
  #96
G20Flyer's Avatar
Can you post a pic of what these mounts look like?
Old Oct 16, 2004 | 09:06 PM
  #97
RA030726's Avatar
damn i knew i should have taken some pix
they are round and flat with 3 holes
Old Oct 17, 2004 | 09:18 AM
  #98
Mike T's Avatar
ignotum per ignotius
Any word on the development of the 5th gen mounts?
Old Oct 17, 2004 | 09:29 AM
  #99
MaximaPolak's Avatar
I'd like a 5th gen mount....
Old Oct 17, 2004 | 10:06 AM
  #100
Sin's Avatar
Sin
You mean the pic that shows up as a red x?
Old Oct 17, 2004 | 10:15 AM
  #101
G20Flyer's Avatar
I love putting red x's on my ride
Old Oct 17, 2004 | 03:14 PM
  #102
mzmtg's Avatar
PicRack.com died
Cardomain wont upload
Where should I re-host the pics?
Old Oct 18, 2004 | 10:10 AM
  #103
mzmtg's Avatar
The pic is back up:
Old Oct 18, 2004 | 02:53 PM
  #104
G20Flyer's Avatar
Sweet looks good. Do you have a pic of the actual upper mount??
Old Oct 18, 2004 | 05:02 PM
  #105
Mark97SE's Avatar
Ben, do you recommend cutting the bumpstops at all with these? If they restore most of the travel, then we should be able to leave the bumpstops alone, or do we still need to cut a little off?
Old Oct 18, 2004 | 06:59 PM
  #106
mzmtg's Avatar
I've been running cut bumpstops along with the new mounts. I got new bumpstops and cut one notch off last time I put on new shocks.
Old Oct 18, 2004 | 07:40 PM
  #107
1996blackmax's Avatar
Ben, are you using the OEM bumpstops and if so did you have to glue anything back together?
Old Oct 19, 2004 | 05:39 AM
  #108
mzmtg's Avatar
Since the OEM stops are all molded in one pice, when I cut them, I ended up with two pieces.
I cut the accordian tube part off the bumpstop part (which I shortened) and zip tied it to the strut body.
Old Oct 19, 2004 | 06:17 AM
  #109
Thanks for the information. I will do the same thing that you did with my OEM bumpstops. I received the mounts yesterday and will be installing them this weekend, can't wait .
Old Oct 19, 2004 | 01:00 PM
  #110
RA030726's Avatar
i never cut mine and i cannot get the rears to bottom out. I can drive over speed tables so fast that my spare tire gets air, but no bottoming out. so i dont think its necessary, but it cant hurt. maybe i should get some passangers and try it
Old Oct 19, 2004 | 01:12 PM
  #111
mzmtg's Avatar
've been running cut bumpstops of one variety or another ever since I got aftermarket suspension (4 different setups, 3.5 years, 90,000 miles ago). So I don't know the difference
Old Oct 21, 2004 | 05:37 AM
  #112
mzmtg's Avatar
Good news! I'm heading out to measure a 5th Gen after work today. I should have prototypes ready for road testing by tomorrow afternoon
Old Oct 21, 2004 | 07:16 AM
  #113
Mike T's Avatar
Old Oct 21, 2004 | 11:49 PM
  #114
Oblongshapes's Avatar
hmmm, My rear suspension squeeks when I hit a bump on my GC with AGX's. I tightened the bolt and it quit for a little bit, but now it is back..... You guys think this will fix my problem?>?
Old Oct 22, 2004 | 05:01 AM
  #115
mzmtg's Avatar
Just something to mention. These mounts WILL change the ride height when used with coilovers. You would need to extend the coilover almost an inch when you install these to keep your height where it was before.
Old Oct 22, 2004 | 07:15 PM
  #116
G20Flyer's Avatar
Huh...my ride looks perfect with the illumina kit and motivational rear mounts....
Old Oct 23, 2004 | 02:04 AM
  #117
Brudaddy's Avatar
How much is shipping to 39042?
Old Oct 23, 2004 | 02:55 PM
  #118
mzmtg's Avatar
You've got PM
Old Oct 23, 2004 | 02:57 PM
  #119
mzmtg's Avatar
I took apart a 5th Gen yesterday. There's good news and bad news.
The bad news, these type of mounts wont work on 5th Gens.
The good news, the 5th Gen OEM mount is set up to allow more travel anyway, so these mounts aren't really needed.
Old Oct 23, 2004 | 03:55 PM
  #120
Mike T's Avatar
That sucks... because the 5th gens are definately lacking in rear suspension travel
