HID 6000k, 7000k, 9000k, 12000k Plug & play kits Group Deal
hi there people, sorry i went to a long trip to get more hid parts to offer you so, we are ready to get orders from and i have right now in stock all the K bulbs We have the bulb type for the following housings: H1, H3, H4, H7, H11, 9004, 9005, 9006, 9007 and bixenon kits
i have right know 5000k, 6000k, 7000k, 9000k, 12000k D2S bulbs
Also i took a time to read all the past threads and i saw that i lost a good time to sell this kits, but anyway i was busy with more option (i have motocycle 21W hid kits right now). I saw there is another seller umnitza who join on this GD, good, more products, more choice and the name is market. About www.autoaccessorystore.com its easy post thread talking about everything and get down this GD but this is not the case people, we offer what we have and yes it comes with 1 year warranty and all the necessary information to make them work.
And now in English?
I'm sorry, you can't possibly sell a legitimate product over 6000K. It's just too bad, it's due to this kind of sales that gives HID products a bad name.
I don't care if you sell 1 or 10000, I don't like to see bad product sold by anyone. Anything over 6000K is COMPLETELY USELESS. Even if I wasn't a retailer, I'd say that.
i dont get your point. I just trying to show the product to this people. IF 6000k-up K is on the market it is cause there is a lot of people who want them simply of that. And remember unmitza some people want lumens, other wants color. You think that over 6000k is completely useless but other people thing different and try to let them decide by their self.
Thanks.(im not here to spend my time trying to explain if 6000k-up work or not, im here to offer what i have)
hi there, if you have stock 97 stock headlight you should go with 9004 bulbs type. Anyway it depends of what do you want in the color. The 5000K will look like bmw, jaguar, lexus with hid system, a little more blue and the lumens are good too. We are talking about 2800-/+3000 lumnes on the kit. The DC converter and inverters are amazing on this kit so you will not to worry about any bad circuit problem on your car cause the kit can support everything.
You can paypal me the money and you will get it in 4 days by fedex. This kist is completly plug and play and just take 5 min to install and couple of bath runs.
to help everyboyd i will put some information about the kits:
This kit comes with 1 year warranty directly from the factory, for any part, to give all the costumers a safe driving and protection for their money.
PRODUCT:
The "HELIOS" 35W Xenon HID Head Light can supply equivalent to 179W beam of traditional halogen lamp and 300% effciency.
The True HELIOS HID Ballast is used advanced technologic circuit character that can cope with any bad power circumstance of car.
The Xenon Bulb is used pure high quality quartz and advanced metallic material, which can make a super fair beam.
The use life of the Xenon HID Lamp is about 2500 hours is equivalent to 5 times the halogen lamp.
SPECIFICATIONS:
Normal input voltage: DC 12.8V
Allowable input voltage: DC 9V-16V
Normal input current: 3.5+/-0.5A
Normal output wattage: 3.5+/-5%
Protection of Voltage: Lv<6V Hv>18V
Operating temperature range: -40 +150C°
79mm(W) x 78mm (W) x 38mm (H)
35W BALLAST FEATURES:
Rapit Start: Reach 80% of normal state within 4 sec. at the beginning
High frequency DC-DC converter
Low frequency DC-AD inverter
Lower voltage rating power device
Control by using a CMOS IC
Increased power factor
Small size and lightweight
Easy to assemble
Short and open of protection (0.2 sec. smart start)
what is include:
1 - Pair of Bulb
· Japanese Made Koba HID Bulbs
· We only have clear bulb that emits true colors
· any K Blackbody Temperature
· Available in 9004, 9005, 9006, 9007, H1, H3, H4, H7, H11
· Also available in 5000K, 6000K, 7000K, and 12000k(Please find our other auctions) WE HAVE D2S BULBS TOO!!!!
2 - Pair of Ballast and accessories
35W Power Supply
Input - 13.2V DC Norm, 3.2A Norm. 20A Max; Output - 35W Norm
Dimensions - 3.3x3x1.25 (LxWxD); Weight - 1.8 lbs each ballast
Plug-n-Play setup for easy installation
2 x Certified Clear Koba HID Bulbs at 12000K
2 x Brackets with Screws
2 x 3M Adhesive Pads
5 x Cable Ties
Wiring and Fuses
Installation Manua - Warranty Card
What is HID?
HID stands for High Intensity Discharge lamp. Different from the conventional halogen lamp, which heats up the tungsten filament to produce light, the HID produces light by the means of high pressure gaseous discharge. Ignited by an electronic ballast using a initial voltage of over 23KV, the gases in the tubing are excited to produce a consistent arc light (gas discharge light). Gas discharge lamps are also called xenon lamps since the tubing is mostly filled with xenon gas. Dependent on the composition of gases in the lamp, its color temperature can vary from 4000K~12000K. A 6000K xenon HID lamp produces a color temperature similar to that of day light, making HID a safer and more preferable choice for vehicle head lighting during nights.
Why HID?
· The HID produces light that's 3 times more luminous than the conventional, over a longer range.
· The HID has a lifetime of 2500 hours; it lasts almost 10 times longer than the conventional halogen lamp since it no longer heats (runs down) the tungsten filament to generate light.
· A 35W HID lamp produces equal luminous light that a 170W halogen lamp produces, making it more energy efficient, consuming less electricity from your car battery = saving on fuels = less pollution.
· A 6000K HID lamp produces white light very similar to that of the noon sun. Light of such color temperature is the most comfortable to human eyes, and the clearest lighting in both nighttime and rain/fog. Driving at night can be made safer and more enjoyable.
Application:
If you want to know your bulb type go to this webpage: http://www.sylvania.com/ConsumerProd...de/default.htm
PRODUCT:
SPECIFICATIONS:
Easy to assemble
what is include:
1 - Pair of Bulb
35W Power Supply
5 x Cable Ties
Wiring and Fuses
What is HID?
Why HID?
Application:
You don't get it do you?
It's like telling people, hey, if you want Marijuana, I'll sell it to you. Even though it's not good for YOU or the people around YOU.
Don't be fooled, you'll be blinding everyone driving near you if you go well beyond 6000K in a non-projector housing.
Aside from that, our products - Xtec in particular - has been proven reliable and that's because it's been put into a variety of applications.
What's the price for 5000K in 9004? You pointed out that 5000k looks like bmw and lexus. What does the 6000k lool comparable to, and is it a better by? If so, what would be the price of that one as well? Thanks.
hi there athlon, the price for the 5000k is $260 shipped to your door and the 5000k is a little the same compare with 6000k. Let`s do it. send me a pm and we can arrange everything. Remember guys that this is GD price so you can save a lot of money. For H3 users we have the unique H3 bulbs on the market that is very small, not like normal hid kit is special made to fit any foglight.
OK, just to respond Umni and this is the last time i spend my time reply your message. Why hid blind people, easy, easy, cause the beam patter is not correct, and it doesnt depend of the Kelvin, or Lumens, it depends of the location of the filament on the headlight, that`s why te retrofit sometimes is difficult cause you should compare the stock halogen bulb with the HID bulb and try to get the same position of the filament VS. hid lightning capsule. Getting this point you will have perfect beam patter on the road and will not blind anyone.
The hid bulbs are very clear material and produce an amazing light, if not why this kit with 5k, 6k, 7k, 9k, 12k was at SEMA SHOW and was the best kit on the market. I will post some pics to explain about beam pattern.
This kit comes with rebased bulbs so they are made exactly to fit on the stock headlight for any car and get the exactly beam patter with better color, light, etc.
It`s weird that i began this thread and you posted some info to get some buyers, i saw it and i respect it, i didnt try anything. This was my GD anyway and its a very bad move to talk bad about some information that you dont know just to avoid buyers to get kits from me.
So please leave as alone and you can put your own GD and say everything there, but respect this. We are here to help people to get what they want, i have a maxima too so i know how this people is and of course we love our cars.
You still don't get it. Perhaps it's a language barrier. I apologize for that. Let me be more clear. I'm not saying HID is going to blind people.
I'm saying ANYTHING OVER 6000K is a useless light output. Selling that is just like selling Crack Cocaine, it may give you a buzz, but the long terms negative affects are horrific both on the driver's eye strain and the eye strain of the oncoming traffic. NO PROBLEM YOU SELLING OTHER KITS, but it's like I said, I don't buy from people peddling stuff that they know they shouldn't be peddling.
We were at SEMA, in fact we had a booth there. While you were getting "12K" HIDs, we were selling normal HIDs to all parts of the world
That's great. But that's NOT what I'm saying.
I only posted, if you look at my response, at the request of customers that you did not respond to. At the request of those same buyers, I was asked to create a new GD thread, I could not, if the moderators could split out my thread with yours, that would be pleasing. I would not have to be in the middle between you and your cusotmers
HIGHER KELVIN EQUALS LOWER OUTPUT IN LUMENS!
That is all.
The customer can decide on who will be around longer and who to buy from. Good luck to your sales.
Im buying the 7000k plug and play kit, I called up autoaccessory, He told me that it would cost me $350 and be here before christmas. I'll be keeping you guys up 2 date. He said that there hasnt been 10 people yet to get the deal that was already posted. I dont know about you guys but I want a new hid kit with warrenty so thats why I called.
-Smx95
-Smx95
jejejeje Men its seems like a war here. Yes i know all the hid companys at sema show: mimousa, brightstar hid, au-lite lightning inc, apexcone, mycarr, helios. So if you were there maybe we meet. And i know that more K means more Lumens, but people can see what they want, more color or more lumens and that is all.
Again please dont say anything about the kit, i respect your kit and so do you at least at the sema show was like that, everybody selling the product and didn´t try to cheat or take any bad move. And i hope this threat continue on the good way. If you can open your own thread and leave all your comments there, that will be a great action from honest person.
Everyone knows my price, the quality of the product.
ok thanks for your comment again, you can create your own thread and continue to post things there. I have high K and low K product and i will not stop to sells them cause of you.
Its weird cause i have sold more than 500 kits this last 4 months and most of the kits were 9000k and 7000k. My 5$ cents.
i think you know a lot about drugs..cause you just talk about it. Anyway please allow another people to continue in this post, is not our fault that you dont have more K bulbs than 6k.
Although i have personally not bought anything from Umnitza, i know many org members who have and i have developed a great respect for him since he understands going over 6k is worthless and his customer service is excellent and from what everyone said and he doesnt sell crap just because it sells, i look forward to be doing business with you in the future.
Ok, here's an analogy you'll understand
The PET ROCK! No one in their right minds would buy something that doesn't do ANYTHING WORTHWHILE FOR THEM.
It's a DAMNED SHAME that the pet rock worked well in the market place, it gave people the idea that any bad product would sell
ok as you want unm, men this thread make me feel boring. As i told you before i will not reply any message again cause its a waste of time, its easy to say bad product, etc..yeah bad product, just for the information, HELIOS kit is one of the best convertion kit on the market and # 1 on SEMA SHOW for lightning upgrade. IF someone says that is a bad product etc...just for have 7k, 9k, 12k bulbs...come on, give me a break it had 3 awards and 5 certificates for best quality and ISO staff.
AGAIN people some times want more lumens(less K) the perfect K is 4300k-5600K rage(hid hella product information), some other people like COLOR, more K more blue-violet color, LESS LUMENS, anyway there is one product for one person, etc. Just enjoy and let people take what they want.
Its easy to me email all my friends to post hundred of commest about my kits but is not the point, there is a lot of people who prefer K than Lumens, and vs, its part of each people to get what they want.
The product its here, if you want a kit, order, if not leave this thread as it is "GROUP DEAL" not one person opinon.
Maxima members...you have the price and any information you need.
Thanks people for PM me, your order are on the way right now.
Originally Posted by bsuccess1
Can someone in the .org post some comments on their experiences with the vendors selling hid kits on this group deal. I am considering maximabest or umnitza.
hi there people i should say thanks for your honest interest on my kits and focus in the main idea of this thread, all the users who sent the payment the kit is on your way(3-4 days) directly from the Factory.
The price still the same and right now we just have H4 bixenon cause the 9004 was out of stock very fast.
Again thanks people.
Originally Posted by meanbean
I elected to go with Umnitza in purchasing my H3 6000k HID kit. Their customer service was top notch. They provided rapid responses to my emails and lighting fast shipping. The item was actually shipped out the same day even though payment was made near close of business. (Gotta luv that!) The Xtec HID kit was received within a few days and is of very high quality. I would highly recommend Umnitza and would not hesitate in purchasing from them again.
We have more H3s and H4s in stock today.
We are out of 9004s, but again, can always special order it
Let us know.
for the Helios 9006 setup with 9000k(i recomend more than 8000k) its $285 shipped to your door.
AND: UNMITZA please open your own threat if you are honest person, it says a lot use this thread by maximabest to sells your stuff and everyone will be happy and that will means respect. Thanks
1) I cannot make any posts in the GD forum, don't know how you could, but I cannot.
2) You were unavailable for the people of this board, they requested I join into this, I didn't join without some minor pleading by them.
3) I've asked repeatedly for a moderator to step in to split this thread, maybe you missed that in the posts.
4) Finally, and most importantly, as long as this thread is open and remains unsplit, the customer can get their information in one place, there's ultimately no harm in that as long as we stay cordial to each other and don't address each other in non-factual antagonistic ways.
