All BlehmCo Toys on Special for the Holidays!
Old Dec 8, 2004 | 06:04 AM
  #41
KCMC582's Avatar
Matt, I just sent you an email askin about payment on a 5th gen stage 2 lower tie bar but I got a response saying your out of town until the 10th. I wasnt sure how you take payments....Paypal I assume. Just get back to me when you can thanks man.
Old Dec 8, 2004 | 07:45 AM
  #42
NmexMAX's Avatar
dot dot dot ...
So, by purchasing the front kit for 180, would I have to get the rotors myself for another 180 or so?
Old Dec 9, 2004 | 05:19 PM
  #43
turbo_gg's Avatar
I just got my LTB stage 2, and hyperground kit!! Very high quality stuff!! Matt, is there a link for install of the LTB and hyperground kit? Thanks in advance!!
Old Dec 9, 2004 | 05:31 PM
  #44
Dysfunctional
hey matt,
will the stage II tie bar fir for a 3rd gen with the warpspeed subframe connectors stage I and II ... just wondering cause i dont wanna get your stuff and warpspeed's then not beable to use one ... thanks
but if it is then im going to have to order some up
-Dys
Old Dec 9, 2004 | 05:44 PM
  #45
BRAN808's Avatar
Turbo, can you post pics of the install when it's completed. I want to see where and how it mounts. Thanks
Old Dec 10, 2004 | 08:20 AM
  #46
turbo_gg's Avatar
Yup, I'll take some picks when I get it installed
Old Dec 10, 2004 | 10:56 AM
  #47
Matt93SE's Avatar
STFU n00b!
LiquidVenom, you'll need the 30mm calipers. they're from a 90TT or 91NA/TT if you want the aluminum ones. The iron ones from a 92-96 will also fit fine, but they are quite a bit heavier. only difference.
Otherwise, you can see most of your other in info on my website:
http://www.mattblehm.com/300ZX_brakes.html
NmexMAX
the $180 only includes the bracket, hardware, and lines. You will need to purchase the calipers, pads, and rotors yourself.
BUT.. I think I've found a source for some '04 Max rotors and should be getting a call back later today on it.
Turbo_gg There should be a receipt in the box and the URLs for the install instructions are on it.
Dysfunctional, yes the stage II LTB fits fine with the warpspeed SFCs.. SFCs mount to the frame, mine mounts to the suspension. I have their Stage II SFCs on my car and HIGHLY recommend them as well as my lower tie bar.
Bran808, here's the install instructions for the lower tie bar on a 4th gen. the 5th gen is nearly identical to it. You should be able to get a good idea from it.
http://www.mattblehm.com/ltb_install.html
Old Dec 10, 2004 | 11:19 AM
  #48
black02's Avatar
Ship to Canada?
Hi Matt,
Do you ship to Canadian addresses?
Old Dec 10, 2004 | 12:38 PM
  #49
turbo_gg's Avatar
Duoh, my bad. Thanks Matt!! By the way, the workmanship and detailed welding on the stage 2 LTB is exceptional, as good as it gets!! The black powdercoating on it is flawless. I highly recommend everyone get this LTB at this great price!!
Old Dec 10, 2004 | 01:24 PM
  #50
TsingTsaoNYC's Avatar
So what's in this kit?
NEW OEM 12.6" 2004 Maxima Rotors
Used/Rebuilt/Remanufactured 300ZX ALUMINUM Calipers, hardware, pads, shims, etc.
Caliper relocation bracket
All hardware necessary to install (nuts, bolts, washers, etc)
Goodridge Stainless Steel brake lines, certified to D.O.T. FMVSS test 106 (many of the brake kits out there don't have this.)
Matt,
So you don't offer the calipers as part of the full BBK package no more?
Old Dec 10, 2004 | 04:12 PM
  #51
Matt93SE's Avatar
STFU n00b!
TsingTsao, I *can* get the calipers, but they're not included in the $180 sale price.
scroll down on that same page for the different rotor and caliper options when purchasing the kit...
I do have a supplier that has ONE pair of the calipers in stock, loaded with some cheap pads and such. I can get them drop shipped from him for $260+shipping for the calipers, plus the brake kit itself.
This is almost $100 less than I was previously able to get them- as you can see from the last few lines on my brakes page.
Black02 shipping to Canada will not be a problem, but the shipping costs are higher. let me know exactly what you want to purchase and your postal code and I can get you a quote on everything.
Turbo_gg Toldya you'd like it.
Old Dec 10, 2004 | 07:56 PM
  #52
Max20SE00's Avatar
Hey matt I need a grounding kit for my 00 maxima SE. Is this all setup ready to bolt on and everything with detailed installation instructions? I am not very good with electrical/wiring and would like to do this myself. Let me know.
Old Dec 11, 2004 | 09:28 AM
  #53
turbo_gg's Avatar
Hey Matt, how much for a full front BBK for my '00, including 300Zx calipers, '04 Maxima rotors, brackets, ss lines,etc. LMK asap. Thanks!!
Old Dec 12, 2004 | 07:54 AM
  #54
Matt93SE's Avatar
STFU n00b!
Max20SE00, yes the kit is very easy to install and will come with instructions. 1/2 hour install... maybe 1 hr if you don't work well with tools. minimal hand tools needed as well. If you can install an intake on your car, you can do this.
Turbo_gg, what kind of rotors do you want? I'm working on setting up an account with a Brembo rep right now, but currently the rotors I offer are from IRotors for $160/set or OEM for slightly more.. IRotors can get slotted, drilled, S&D, or blanks.. all from Centric (Formerly AutoSpecialty).
The loaded calipers are $260/set, and the rest of the kit (brackets, lines, hardware) is $180.
That puts you at $600 (plus shipping) for everything but the brake fluid, if you get the IRotors discs.
Unfortunately I can't know off the price on the rotors or calipers, as that's what I buy them for from other vendors.
Old Dec 12, 2004 | 12:07 PM
  #55
hedrinbc's Avatar
Wires
Matt,
I'll take a grounding kit in black for a 2k3 Auto.
Email me the details at ben@hedrington.com, I will pay via PayPal.
Thanks,
-Ben
Old Dec 12, 2004 | 12:39 PM
  #56
harmbone2k2's Avatar
6yrs old=36,500 miles :)
Matt I would like a grounding kit in Black. Do you have any left?
Old Dec 12, 2004 | 04:12 PM
  #57
Max20SE00's Avatar
matt I will take a grounding kit in black for a 2000 auto. Please PM me paypal info and I will paypal immediately.
Old Dec 12, 2004 | 08:56 PM
  #58
Matt93SE's Avatar
STFU n00b!
Had a long day here guys.. Stupid VGs and their timing belts
I'll get in touch with you all tomorrow when I can see straight.
Old Dec 13, 2004 | 03:36 AM
  #59
Money sent Matt. Looking forward to getting this kit.
Old Dec 13, 2004 | 08:46 AM
  #60
Matt93SE's Avatar
STFU n00b!
the 5th gen kits are $50, shipped.
my paypal account is sales@mattblehm.com
please indicate year of car, wire color, and address when you send the money via paypal.
simple as that.
Old Dec 13, 2004 | 12:11 PM
  #61
Matt93SE's Avatar
STFU n00b!
Last Day! don't miss out!
Old Dec 13, 2004 | 12:50 PM
  #62
slimer's Avatar
A couple of Blaxxx's? Lawls.
matt, i would like a ground kit in either silver or blue.
i was wondering if it could get a couple of extra wires. i have relocated my battery to the trunk and would like some more grounding in there as well.
steve
Old Dec 13, 2004 | 12:57 PM
  #63
Matt93SE's Avatar
STFU n00b!
I can do that. let me know how long you want them and what you want, and I can give you a price for the whole thing.
Old Dec 13, 2004 | 02:21 PM
  #64
JDM4LIFE's Avatar
no special on the stage 1 ltb?
Old Dec 13, 2004 | 03:51 PM
  #65
Mximus's Avatar
Hey, I need a ground wire kit for a 97 maxima. Is there any way I could get it by christmas? Its either gonna be blue or black, I'll let you know real soon. Whats the final price on that shipped to 04915?
Old Dec 13, 2004 | 04:34 PM
  #66
turbo_gg's Avatar
Get the stage 2, the benefits are much more pronounced, than the stage 1.
I got mine here on the GD, you can't beat the price.
Old Dec 13, 2004 | 04:35 PM
  #67
Matt93SE's Avatar
STFU n00b!
JDM, no specials on them since I don't keep them in stock.. it's a special run on them when I do make them and I basically lose money on it.
Mximus, I'm shipping these as soon as I can after the order.. should easily be there before christmas.
Old Dec 13, 2004 | 05:05 PM
  #68
slimer's Avatar
matt,
it is in the passenger side corner and is currently groudned to the chassis. what lengths do you think? i believe that two should be enough.
steve
ot-i should be coming out in the spring to see the birth of my nephew (austin) and to visit my cousins (nw houston). do the houston nissan enthusiasts have a lot of meets around then? i would like to meet a lot you yall.
Old Dec 13, 2004 | 05:16 PM
  #69
ecsdesignz's Avatar
Codename: Frankie
haha right after i bought the kit i saw the special > p
the relocation kit is great for the 2004 rotors, I'm happy with it so far. Too bad the 300zx calipers won't fit the HP EVO >__<
Old Dec 13, 2004 | 05:19 PM
  #70
Matt93SE's Avatar
STFU n00b!
Unfortunately, HNE is no longer officially around, but there are a bunch of us that still get together and hang out..
let me know when you're coming and I'll see if we can't schedule a meet or something for that time.. I'm sure when spring rolls around everyone will want to get together and hang out anyway!
As for the wires, shoot me a PM and let me know exactly what you're trying to do, where you're runnign the wires, etc etc etc and we'll figure something out with that.
Old Dec 13, 2004 | 07:38 PM
  #71
Mximus's Avatar
Alright, I need those ground wires. Do you have any pictures of what the different colors look like?
Old Dec 13, 2004 | 08:59 PM
  #72
Matt93SE's Avatar
STFU n00b!
here's a shot of the bottom of my box..
I have all of these colors, plus solid black for a stealth look:
Old Dec 13, 2004 | 09:00 PM
  #73
slimer's Avatar
paypal sent! thank you matt!
Old Dec 14, 2004 | 09:47 AM
  #74
greenmax95se's Avatar
hey matt, how much for those coversion brake lines for max-to-300zx caliper shipped to CT,06053?? hit me up on pm.
-rafal
Old Dec 14, 2004 | 10:06 AM
  #75
Matt93SE's Avatar
STFU n00b!
PM Sent!
890
Old Dec 14, 2004 | 04:28 PM
  #76
turbo_gg's Avatar
Hey Matt, I can't get the install links to work for the LTB stage 2, and ground kit that I bought from you. Can you email me the info. I need your help. Thanks.
Old Dec 14, 2004 | 08:57 PM
  #77
Matt93SE's Avatar
STFU n00b!
I sent them to you in PM. let me know if you have any questions
Old Dec 14, 2004 | 10:59 PM
  #78
Cheocwa's Avatar
Hey Matt,
I can't believe I missed out. I have a question though, If I put on the stage2 ltb will it take me out of street prepared? And just out of curiosity what class are you in?
Old Dec 15, 2004 | 06:26 AM
  #79
Matt93SE's Avatar
STFU n00b!
It will definitely take you out of street Touring, but I'm not sure about SP..
hmmmmmm...... I think you can still run it there as I have a friend with a B14 that's running my Stage II bar in CSP..
I run street modified myself, thanks to the subframe connectors and heim joint rear suspension.
Old Dec 15, 2004 | 11:20 AM
  #80
Mximus's Avatar
Okay...I want a set of blue ground wires, 97 maxima. Lemme know how much it would be shipped to 04915, and I'll paypal you the money :-D.
