Ksport 2005 Drift Season KickOff Special. $740 shipped!
Originally Posted by Nathan
Wei, congrats!
I'm hoping to receive my set before this weekend so I can show all the Toronto guys this Sunday at our big monthly meet. If others want them I'll send them your way.
I'm dying to buy these also, but would feel alot better once I've been able to experience them first hand.
Ksports
So what's the verdict??? All you guys that got them already.....I've heard from a few guys, but not everybody that has them. I'm ready to order. It seems like the reviews have been good so far. Anybody else care to chime in on any BAD stuff.......or are these the best thing next to sliced bread?
Originally Posted by Mr.Duck
hell i have had great customer service from ksport, and i have done a lot to get their name out there... and i think a lot of you can vouch for that one
Man, I really can't wait....!!!
Anyone willing to venture thoughts on if these are going to provide weight savings as well???????? (Compared to stock for sure, right? I would be comparing to Eibach/Koni yellows...)
Sweeeet! Thats some great news/info..
I have to figure that the eibachs are.. at least.. 8lbs per corner and the konis... maybe 15...? that would make the weight savings around 50 lbs!!! Gotta love that the handling goes way up and the unsprung weight goes down!
i will tell you this much on weight, the two front struts and springs weigh as much as all 4 coilovers... man it was disgusting... lol it def saves on some weight
Just called Courtesy Nissan. I can't tell you about the Konis, but I can tell you about the stock SE parts:
Struts = 9 lbs each
Shocks = 8 lbs each
Springs = 8 lbs each
Total Front = 35 lbs
Total Rear = 32 lbs
Grand Total = 67 lbs
Assuming the worst-case scenario, that the K-Sports weigh 45 lbs total, then they will save 22 lbs unsprung over stock!
Can't say how much Eibachs and Konis weigh, but judging by the fact that a pair of Koni Yellows for an Acura Integra weighs almost 20 lbs, the weight saving over that combo must be at least as good as it is over stock SE stuff.
Struts = 9 lbs each
Shocks = 8 lbs each
Total Rear = 32 lbs
I am glad that my service is appreciated here. I do my best to make everyone happy as I am an car tuner just like everyone here. A trusting relationship goes a long way (wei)
If anyone can think of anything else that you guys like, i will see what i can do and get the best deal for ya!
payment sent.
mr. duck, when you are finally done tuning your suspension, you gotta let me know what settings you ahve it at. i will go directly to your settings and then tune mine from there if my likings are not the same as yours
joshua
joshua
Originally Posted by nismotek
I can definitely vouch for Ksport CO's being incredible. The bouncy ride I mentioned before was taken care of after finding a bit of preload on all the springs. There still hasn't been a peep coming from the pillowballs, either. Now I can't wait for my new wheels to get rid of that 'tucked in' look.
Today I tried to install the front coilovers and I must say, it was sooo easy and effortless. Well thats also b/c I went from Ground Control coilovers to these, so no spring compressor needed.
As far as ride, they ride so smooth, controlled, decent on huge bumps and railroad crossings, and outstanding in hard corners. This was even with just the front installed and without even fiddling with the shock adjustments.
Wei, thanks again for all your help and I'm looking forward to that t-shirt in the mail!
I am new to the suspension world and I don't understand this "preload" talk. Someone please put this inlamest terms:
Can I ajust the height my car sit at with these??????
I don't want a Tein SS coil drop(2.something) I am looking for an even and moderate drop(1.5)
Thanks, I am learning as I go, sorry for the
Originally Posted by DAVE Sz
Look deep into your small brain, and think for a sec, then look at the pillowball mounts and tell me how in hell they could make any noises?
Originally Posted by Cattman
Although we believe in upgrading our products over time, you definitely won't see pillowball mounts - Progress and I have had more than enough bad experiences with them. Great example of an "innovation" that has more drawbacks than positive features. First, all that weight on such a tiny bearing surface is a predictable source of noise and rattles as soon as it wears and/or deforms a couple thousandths of an inch. Second, this kind of metal on metal, or at least solid on solid interface between the front suspension and the chassis transmits a huge amount of vibration. Third, somewhat indirectly, the types of mounting/rotational assemblies (between the top of the coil spring and the upper mount) used with a monoball-style strut mounts are frequently prone to excess noise and binding when turning at slow speeds.
mr. duck everyone would love to know your settings and some pics for reference would be amazing.
I need all the help I can get.
Originally Posted by Laly
payment sent.
joshua
joshua
Now, preload. On these coilovers, the spring is attached to a big threaded body on the outside of the shock. You adjust the ride height by turning a collar to adjust the position of this threaded body. You can also adjust where the bottom of the spring sits on the threaded body by turning another collar. This is the preload adjustment. Since the top of the spring is stationary (i.e. it's always at the top), moving the spring collar up the threaded body brings the bottom of the spring closer to the top, so it's more compressed. The spring now has preload. This means that there is now more force pushing down on the wheel, so it's more able to track irregularities in the road and stay in contact. Of course, as anyone who remembers their physics classes knows, there is also equal additional force pushing up on the car, and that means that the ride will be bouncier over rough surfaces.
The valving of the shocks in the K-Sport kits are matched to the springs the way they are, so it is highly recommended to use no preload. It's really just one of those nice-to-have things in case you find yourself wanting it at a racetrack where the surface is really smooth.
With the D2's and Tein's for other applications, the pillowballs dry out and wear into grooves. When this happens, any weight transfer will cause the pillowball assembly to 'pop'. This is what Cattman said about their Progress CO's.
You know, I read what Cattman said and it got me thinking... would it be worth it to try to fabricate a rubber washer or something to fit in there and dampen the movement and vibration?
Originally Posted by d00df00d
The spring now has preload. This means that there is now more force pushing down on the wheel, so it's more able to track irregularities in the road and stay in contact. Of course, as anyone who remembers their physics classes knows, there is also equal additional force pushing up on the car, and that means that the ride will be bouncier over rough surface .
Its not really bouncier but stiffer and more going to respond to bumps, right? Its not going to "bounce"...?
Originally Posted by Spaniard
OK I know I am going to sound like an ***, but - im a noob and I need to make sure that my understanding is not off-
Man, you guys rushed my paypal account with orders today. I am gonna work all day tomorrow to process the orders.
If anyone have quality problems, feel free to contact ksportusa first. They can help you resolve the problem faster and more effectivly. If you run into any problem just let me know and I will help you out.
Hey guys.... this GD thread is getting super-cluttered with all the tech talk, so I created a new thread for that stuff:
http://forums.maxima.org/showthread.php?t=406790
Anyone with experiences to share, we need your input. Once we have a dedicated thread for technical stuff and information exchange, it'll be easier to refer to because you won't have to sort through 11 pages of PM notifications and support inquiries. Then we can keep this thread for basic questions and purchase/support issues.
Ksports
Wei........You got paid......and PM'd. Thanks for all of your help. Wei is a great seller. He responded to all of my e-mails and helped me to resolve things! Great customer service! I'll try and wait patiently until the ending of next month.
Easy answer first: Yes, these coilovers allow you to adjust height (so do the Tein SS, actually).
.....please check your pm.
