Midway Nissan's June Special
Old Jun 7, 2005 | 08:04 AM
  #41
dantech's Avatar
Originally Posted by Army of Maxima
dantech... I asked how much (if available) are the wiring harnesses for a 2002/2003 Maxima GLE tail lights?
Yes you did. I asked back if you knew which model Maxima you had. I can tell by the VIN if you have it handy. You can contact me at shiftparts@gmail.com. Thanks
Old Jun 7, 2005 | 08:20 AM
  #42
dantech's Avatar
Originally Posted by NOCturnalI30
A valve body for a 2000 maxima? how much?
There is a upper body (31711-85X00) and a lower body (31713-85X00). You can do a factory number search for that here: http://www.trademotion.com/partlocat...24&catalogid=0
Old Jun 7, 2005 | 08:29 AM
  #43
dantech's Avatar
Originally Posted by nexgenmax
Dan, I'm thinking to replace my clutch pretty soon, do you know what parts do i need? I might need a gen 5 clutch of upgrade. Can anybody help me with this? what parts do i need? thx.
Please let me know if this post not at its place. thx.
Normally when your doing a clutch service, you should replace the disc, the pressure plate, and the release bearing. You can find all of those here: http://www.trademotion.com/partlocat...98&catalogid=1
Hope this helps.
Old Jun 7, 2005 | 10:44 AM
  #44
Snolife's Avatar
What we have here is a failure to communicate
Originally Posted by dantech
Great. Have you placed your order yet?
No I thought you were gonna give me the part number? Or am I confused?
Old Jun 7, 2005 | 11:07 AM
  #45
JiggsHall's Avatar
I've had a power steering hose leak for a while, I had someone turning the wheel while the car was running but I can't tell directly where it is coming from, and it's not leaking directly from the resourvoir. The fluid that leaked out is mostly on the frame under the radiator. I don't believe I would need the whole hose assembly. Do you have a part number and a price for the two hoses that run in front of the radiator ?
Old Jun 7, 2005 | 11:43 AM
  #46
dantech's Avatar
To add the frame to your cart, its part number "frame". Do you need the other number also?
Old Jun 7, 2005 | 11:49 AM
  #47
dantech's Avatar
The picture here is showing the cooler portion of the ps hose. You can get this entire hose asm or you can get the peices that have there own number. Hope this helps.
Old Jun 7, 2005 | 11:56 AM
  #48
Snolife's Avatar
Oh ok, I will do it tonight when I get home from work. Just make sure that I get the "Altima" frame. I will pm you the order number if you need it after I place my order, thanks again.
Old Jun 7, 2005 | 01:01 PM
  #49
JiggsHall's Avatar
Dan,
How much are 49725MC and 49725 MD ?
Old Jun 7, 2005 | 02:18 PM
  #50
kevdog's Avatar
hey dan i need a canister purge control valve i cant find one anywere its for a 95 maxima.
Old Jun 7, 2005 | 02:46 PM
  #51
NOCturnalI30's Avatar
I mean the transmition VB for a 2000 I30 im not sure what i am seeing with those part numbers
Old Jun 7, 2005 | 04:47 PM
  #52
dantech's Avatar
I get all of the internet orders and I'll make sure you get the Altima Frame. Just also mention it in the comment area of your order when you place it. Thanks.
Old Jun 7, 2005 | 04:51 PM
  #53
dantech's Avatar
Dan,
Those are number 49725-58U03 and 49725-58U04. You can do a factory number search for those here: http://www.trademotion.com/partlocat...24&catalogid=0
The look about $14 each.
Old Jun 7, 2005 | 04:54 PM
  #54
dantech's Avatar
Is that the one located right on top of the canister? If so, you'll need to get the entire canister. You can find that here: http://www.trademotion.com/partlocat...95&catalogid=1
Old Jun 7, 2005 | 05:18 PM
  #55
dantech's Avatar
Thats them. There is a upper and a lower. Heres some pics to help.
Old Jun 7, 2005 | 06:40 PM
  #56
Spaniard's Avatar
Im afraid I have some potentially annoying questions.
Ive heard that the bumpers for a 95 maxima are like 25 lbs lighter, front only!!!! (vs 96)
Can you comment on this, and if true, can let me know what I would have to buy to get the benefits of the weight reduction? If its true, and I can get 50 lbs reduction I'd be into front and rear... From what Ive heard filling with foam would be lighter than buying all the bumper parts.
Sorry to be so uninformed, your help would be majorly appreciated and you would have a fan for life.
Also, I probably need some MEVI replacement parts. Is this something you can do?
Old Jun 7, 2005 | 07:10 PM
  #57
aminus21's Avatar
I need the rubber thingy here
And the two hoses here.
Do you have part numbers?? Also, theses part numbers dont work on your website for the parts required to change exhaust studs.
http://www.4dsc.com/articles/drivetr...ld_studs.shtml
Do I need to call in??
thnx
Old Jun 7, 2005 | 09:45 PM
  #58
NYR1199's Avatar
I'm lookin to order new pads and rotors front and back for my 95. When ordering, do I need to order 2 front brake pads or just 1? I assume the rotors come as each so I would need to order 2 fronts and 2 backs.
Old Jun 8, 2005 | 07:43 AM
  #59
Army of Maxima's Avatar
Looking for a few good Maximas
dantech... it doesn't matter which model I have... I have a 2000 GLE that I am putting 2002/2003 tail lights on... the harness from the 2000 does not fit in the 2002/2003 housing, so I need the wiring harnesses (2) for a 2002/2003 Maxima (all the same)...
I've done this before, and I had two price quotes... one at $75 and one at $73... I want to see what your price is?
Old Jun 8, 2005 | 08:31 AM
  #60
dantech's Avatar
I havent actually heard that before but it does sounds like it would work. Makes sense that if you changed the bumper from steel to styrofoam you would decrease the overall vehicle weight. Id find someone who has done that before and see whats involved.
Old Jun 8, 2005 | 09:41 AM
  #61
dantech's Avatar
thnx
The part numbers for the two hoses and the bumper are 65822-01M00, 14099-85E01, and 11826-85E10. All of the numbers that you have listed on that site are available also now. You can do a factory number search for all of those here: http://www.trademotion.com/partlocat...24&catalogid=0
Old Jun 8, 2005 | 09:45 AM
  #62
dantech's Avatar
The pad kit is for both fronts and you only need to order one set. The rotors are each so you'll need to order two for the front. You can find those here: http://www.trademotion.com/partlocat...95&catalogid=1
  #63
Klutch's Avatar
Remember guys, free shipping is only until the 12th..
Old Jun 8, 2005 | 10:39 AM
  #64
dantech's Avatar
Okay the year thing. There is a listing in my Nissan catalogs for 06/01 to 12/02. That part number is 26551-5Y700. The next listing is 01/03 up and that number is 26551-7Y000. Here are a few pics to help you see what Im talking about.
Old Jun 8, 2005 | 10:49 AM
  #65
dantech's Avatar
Old Jun 8, 2005 | 12:38 PM
  #66
Spaniard's Avatar
Thanks, I would appreciate it big time!!
Also, do you sell the MEVI parts separately?
(The "arm" thing sticks- I think the rubber gasket in it is faulty (too big) and so it doesnt spring back from open, and takes too long TO open.)
Old Jun 8, 2005 | 05:23 PM
  #67
dantech's Avatar
Your gonna have to help me with "MEVI". Im not familiar with that term.
Old Jun 8, 2005 | 05:27 PM
  #68
airness_81's Avatar
anyone near by me michigan owner of maxima 4th generation know everthings on the car.Do u know any car show or maxima near in michigan.
Old Jun 8, 2005 | 05:39 PM
  #69
HNDA ETR's Avatar
Still Here... IM me for more..
Hmmm... Nissan parts guy not knowing MEVI... scary...
M iddle
E astern
V ariable
I ntake
Old Jun 8, 2005 | 06:34 PM
  #70
Spaniard's Avatar
Pardon the competitor's link-
http://www.courtesyparts.com/Merchan...duct_Code=MEVI
I need the little bronze part in the upper right.
EDIT: Actually, if you hold off on it I will get the part # for you, only fair.
Still interested in the lightweight bumpers for a 95-
Old Jun 8, 2005 | 07:47 PM
  #71
Snolife's Avatar
Dan, just placed my order, the order number is #12418590. Let me know if anything is wrong, thank once again.
Old Jun 9, 2005 | 06:52 AM
  #72
njmodi's Avatar
Do I get a tax break?
Dan - never mind - the tracking number works now... I still need to talk to you ASAP - I left a message with one of the parts guys... please call me ASAP.
Old Jun 9, 2005 | 02:38 PM
  #73
aminus21's Avatar
Placed order.. Order number 12447210
Thank you for the part numbers
Old Jun 11, 2005 | 10:55 AM
  #74
NYR1199's Avatar
Dan, I just placed the order for brake parts.
Order ID: 12445525
The shipping was $32.37 , I assume this gets refunded?
Old Jun 11, 2005 | 10:56 AM
  #75
Snolife's Avatar
Order ID: 12445525
I was gonna ask the same exact question.
Old Jun 11, 2005 | 01:55 PM
  #76
dantech... that top photo? From a 2004/2005 Maxima (!!!)
the bottom photo... from a 5th gen... but I can't tell which one.
how much for the wiring harness (2 total) for a 2003 Maxima?
thanks!
Old Jun 11, 2005 | 08:19 PM
  #77
Klutch's Avatar
thanks!
I ordered the 2 harnesses for my 02 tails and they were $14.xx per side. I went ahead and ordered the turn signal bulbs while I was at it because they were $2 I think and that'll save me a trip to Autozone. I hope I ordered the right thing because I saw your earlier post about them being $75ish!!
I ordered THIS part #8
Old Jun 12, 2005 | 05:25 PM
  #78
NashMax's Avatar
Dantech:
I am looking for the nuts that hold the rear stabilizer bar up. There are two per side for the bushings and one per side at the link. How can I go about getting these?
Old Jun 12, 2005 | 08:32 PM
  #79
Ka$hThaRipper's Avatar
Hey Dan, I just made an order, I think i beat the deadline (it's still 6/12/05)
time now: 11:50 pm eastern
Old Jun 13, 2005 | 08:19 AM
  #80
dantech's Avatar
That'd be great if you can get me a part number. I show a few different engines in my parts catalog but nothing listed as MEVI. Is that a factory option or is it an upgrade from a nother source?
