AMSOIL Synthetic Lubricants
Old Jul 10, 2010 | 01:12 PM
  #681
Haterz's Avatar
Hey Ed, just wanted to let you know that the larger EaO-20 filter fit perfectly just like if it was made for the car.
Rods03Max619, I agree with Ed about oil consumption due to design and care, with using amsoil regularly for the last 8 years I have never had to add oil between changes (once a year) in my old 2000 maxima except when I would change the oil filter (6 months) and now the EaO filters have eliminated any maintenance between changes when it comes to oil.
Old Jul 10, 2010 | 04:48 PM
  #682
Rods03Max619's Avatar
Thanks for the tips might be looking for like a 04 or 05 Maxima engine some time next year then roll the Amsoil way!!
Old Jul 11, 2010 | 11:51 AM
  #683
talkinghorse's Avatar
Maxima.org Sponsor and Donating Maxima.org Member
Great! The 0w-30 Signature Series oil and EaO filter combination you are using are great products. Glad to hear you are enjoying success with them!
Let me know when you're ready...glad to help.
Old Jul 24, 2010 | 06:11 AM
  #684
In order to give me sufficient time to process orders before the weekend, please try to finalize any orders with me no later than Thursday evening, 29 Jul. Thanks
Old Aug 1, 2010 | 07:42 PM
  #685
AMSOIL has introduced Dominator Coolant Boost. http://www.amsoil.com/StoreFront/rdcb.aspx
In addition to enhancing the effectiveness of coolant in transferring heat, Coolant Boost also contains a robust mixture of corrosion inhibitors that protect the cooling system from corrosion. Pls send PM for pricing.
Old Aug 8, 2010 | 05:42 AM
  #686
gdal's Avatar
Ed ... I sent you a PM regarding a potential order shipped to 22546.
Thanks!
Old Aug 8, 2010 | 12:36 PM
  #687
Thanks!
Got it...the products you purchased are of top quality and I am confident you will be very pleased with them. You'll be hearing from me soon with the shipping confirmation. Thanks for your order and please let me know if I can be of further assistance.
Old Aug 8, 2010 | 08:17 PM
  #688
gdal's Avatar
Thanks again for the easy transaction!!
Old Aug 10, 2010 | 05:41 PM
  #689
BORQUA79's Avatar
nycmaximas member
Hello, I need a quote for 6qt or 12qt ATF Synthetic to 11218.
Thanx
Old Aug 10, 2010 | 08:13 PM
  #690
vQmaxii's Avatar
5 quarts of 5w-30 ASLQT-EA
shipped to 32818
Old Aug 11, 2010 | 02:42 AM
  #691
Maxima-Ness's Avatar
Case of ASL 5w30 and two oil filters. I thought they were the eao-13 but it may be the eao-15. not sure. Its for a 2002. all this shipped to 40291. A repeat buyer
Old Aug 11, 2010 | 08:15 PM
  #692
PMs sent to BORQUA79, vQmaxii and Maxima-Ness. Glad to help. Thx
Old Aug 13, 2010 | 05:16 PM
  #693
DCZC's Avatar
EDsendme a quote for a gallon of auto trans fluid and a oil change kit for the yearly setup to 76691,
2000 I30,
Thanks,
DCZC
Old Aug 13, 2010 | 07:31 PM
  #694
2000 I30,
Thanks,
DCZC
How often do you intend on changing your oil, once per year? How many miles do you put on the car during that time?
Old Aug 13, 2010 | 09:12 PM
  #695
DCZC's Avatar
probably 15-20k miles/year.
Thanks!
Old Aug 14, 2010 | 06:37 AM
  #696
Thanks!
Sent you a PM with a couple options. Pls let me know if I can help. Thx!
Old Aug 28, 2010 | 11:11 PM
  #697
Stagnet04's Avatar
I want to change the transmission fluid in a 1998 max. I think I need 5 qrts, is that right? How much shipped to 92571?
Thanks....
Old Aug 31, 2010 | 06:45 AM
  #698
Thanks....
Thanks for your order...pls let me know if I can be of further assistance.
Old Aug 31, 2010 | 08:46 AM
  #699
gunmax's Avatar
payment sent for 5 qts of the gl-4
Old Aug 31, 2010 | 02:28 PM
  #700
Stagnet04's Avatar
WOW! Already got my order, Thanks for everything, will be back for more fluids. This guy is HIGHLY recommended....
Old Sep 7, 2010 | 06:34 PM
  #701
It's not too early to start thinking about the winter months ahead. Change to one of AMSOIL's premium synthetic engine oils this fall and don't worry about it again until spring or beyond. AMSOIL synthetic oils are formulated for extended drain intervals. The premium base synthetic stocks and advanced additives provide for outstanding cold flow characteristics resulting in less engine wear, faster warm-ups and less strain on the battery. Pls send PM for information and club pricing.
Old Sep 8, 2010 | 07:10 PM
  #702
gunmax's Avatar
just put the oil in yesterday.. and what a differance from regular non synthetic... thanks for this great product. will be using again once its time.
Old Sep 9, 2010 | 04:12 PM
  #703
I'm not surprised...I hear these same comments over and over! Thanks for the feedback.
Old Sep 11, 2010 | 06:23 PM
  #704
sparcobulk's Avatar
I'm planning to switch to Amsoil 0w-30, but have a few questions:
1. I have a 5.5 gen maxima with 133K, and its known to burn oil -- the oil is going to deplete before its expected oil change cycle right? Do i just keep adding oil every month?
2. I'm been on regular oil, changing it about 3K-4K intervals. Do I just make a switch or is there an intermediate step before going for amsoil full synthetic?
3. I'm in Chicago suburb, so is 0W-30 the best choice?
Lastly, a quote for 2 gallons engine oil + EaO shipped to 60101
Old Sep 14, 2010 | 05:47 PM
  #705
Thanks for contacting me...glad to help.
AMSOIL lubricants have very low volatility and can reduce oil consumption in some situations. However, it is not a cure-all for engines that are worn, leaking, or where oil consumption is caused by a design/engineering issue. I sell oil to a lot of folks with cars like yours and while they report lesser oil consumption, the nature of the engine is such that it is going to consume some amount of oil. That being the case, you would need to add oil to keep it topped off.
AMSOIL sells an engine flush that is recommended prior to your first oil change. Some people believe in these products and others say they're a waste of money. If you've been changing your oil between 3K and 4K, your engine should be pretty clean...Nissans are not typically prone to sludge. So its up to you...if you decide to skip it i would recommend you keep an eye on the oil and/or have it analyzed between 5K and 7500 mi to check for contaminants.
AMSOIL Signature Series 0w-30 is AMSOIL's top performing oil. Its the best choice, period.
Sent you a PM with pricing and delivery options. Let me know how I can help.
thx, Ed
Old Sep 15, 2010 | 04:07 PM
  #706
gunmax's Avatar
got my oil and filter within 48hrs thanks again for this great product and fast shipping
Old Sep 24, 2010 | 05:50 PM
  #707
Try a bottle of AMSOIL Performance Improver (PI) with your next order. AMSOIL P.i. is the most potent gasoline additive available today. As a concentrated detergent, it is unsurpassed in cleaning combustion chamber deposits, intake valve deposits and fuel injector deposits. AMSOIL P.i. helps maintain peak engine efficiency, fuel economy, power and drivability in newer low mileage engines. In engines with accumulated deposits, testing showed AMSOIL P.i. provided clean-up, fuel economy and emissions improvements after only one tank of gasoline. Competitively priced.
Old Sep 25, 2010 | 07:13 AM
  #708
nelledge's Avatar
"I'm just sayin'..."
@talkinghorse - I emailed you about a week ago and haven't got a response. Would you PM me with your contact info? Trying to get some MTG. Thanks.
Old Sep 25, 2010 | 07:28 AM
  #709
Sorry, but I didn't receive it. I'm pretty good at responding to inquiries. I can get you the MTG no problem. Pls drop me a PM with the amount of oil you need (or the year of your car) and I'll get back with you quickly. My direct e-mail address is contained in my original post. Pls include your zip code or state of residence so I can determine the correct tax and shipping. Thanks!
Old Oct 7, 2010 | 08:43 AM
  #710
QT1 5MT AE's Avatar
Gram Lights addict
sent u a PM but no reply. quote me for 4 quarts of 75-90 GL4 to 91316.
Old Oct 7, 2010 | 02:50 PM
  #711
Sorry, I was out of town yesterday and no internet where I was at. PM sent. I look forward to helping you.
Old Oct 8, 2010 | 03:24 PM
  #712
99greddymax's Avatar
hi!
can you quote 5 quarts, and oil filter? I want the fully syn oil. however i dont know what weight, im assuming 10w30, i have over 250k..
Old Oct 8, 2010 | 06:12 PM
  #713
Originally Posted by 99greddymax
hi!
Sent you a PM with the cost and ordering information. Pls let me know if I can help. Thx, Ed
Old Oct 10, 2010 | 06:34 AM
  #714
AMSOIL XL Synthetic Motor Oils have recently been reformulated to last longer in service and meet the more stringent ILSAC GF-5 and API SN service categories. Available in four different viscosities (5w-20, 5w-30, 10w-30 and 10w-40), XL Synthetic Motor Oils are now recommended for up to 10,000 miles or six months of service, whichever comes first, or longer when recommended in owners’ manuals or indicated by electronic oil life monitoring systems. As before, AMSOIL XL compliments AMSOIL's other extended life passenger car motor oils.
During normal engine operation, the combustion process creates acidic by-products that can lead to internal component corrosion and reduce the life expectancy of the engine oil and engine itself. Formulated with extended-drain boost technology, AMSOIL XL Synthetic Motor Oils employ high-quality synthetic base stocks and a unique additive chemistry to neutralize acids longer than conventional oils. The extra additive package effectively raises the Total Base Number (TBN), a measure of an oil’s useful service life, and provides superior protection and performance throughout the entire drain interval. AMSOIL has held pricing constant on this oil, making it an exceptional value. http://www.amsoil.com/lit/databulletins/g1404.pdf
Old Oct 11, 2010 | 01:16 PM
  #715
OnOiShNo0dl3Z's Avatar
Can i get a quote for 3 quarts of 75w90 gl4 shipped to 19145? This is what I should be using for a 6 speed 2002 maxima correct?
Old Oct 11, 2010 | 05:00 PM
  #716
PM sent with the cost and ordering information. Concerning the product, yes, this is a 75w-90 GL-4 gear oil that is formulated for manual transmissions and other applications that require a GL-4 gear oil. It is an excellent choice for your manual transmission and I sell a lot of it to our members. Pls let me know if I can help.
Old Oct 18, 2010 | 06:55 PM
  #717
petahs's Avatar
Can i get a quote for 6 quarts of 75w90 gl4 shipped to 75041?
Old Oct 18, 2010 | 06:57 PM
  #718
For those of you who have registered as Preferred Customers with me, you may have noticed the "MyAMSOILGarage™" section on AMSOIL's web site. "MyAMSOILGarage™" enabled registered users to record vehicle maintenance information on AMSOIL's web site and to receive e-mail reminders when it was time to perform service. To meet the growing demands of the users, AMSOIL has been working at expanding the system’s capabilities to provide more features. Big changes will be coming to the system beginning Thursday, October 21st.
• The ability to store information for virtually any vehicle, including motorcycles, lawn and garden equipment, heavy-duty trucks and more.
• The ability to store information for stationary equipment, including compressors, chop saws, generators and more.
• Expanded record-keeping capabilities, allowing users to track all maintenance services, such as belt changes, brake work, tire changes and more.
• Advanced email reminder capabilities.
While the service will provide easy and fast product lookups for passenger car/light truck applications, it will now become a complete vehicle and equipment maintenance software program.
Please send me a PM if you have any questions about registering for/using this service.
Old Oct 18, 2010 | 07:12 PM
  #719
Sent you a PM with the cost and ordering info...pls let me know if I can help. Thx
Old Oct 20, 2010 | 07:17 PM
  #720
cardana24's Avatar
Blown
I have a VLSD 4th gen transmission that was just re built so it is completely empty. I already have one quart left from last time when I ordered GL4 from you. How many more quarts will I need? Let me know and please send me a quote with payment instructions. Thanks.
