AMSOIL Synthetic Lubricants
Old Aug 19, 2012 | 06:04 PM
  #921
talkinghorse's Avatar
Maxima.org Sponsor and Donating Maxima.org Member
AMSOIL at MOPAR Muscle
http://www.amsoilracing.com/Blogs/Ev..._Showdown.aspx
Pls send me PM for price quote. Wholesale pricing available
Old Sep 3, 2012 | 09:25 AM
  #922
Consider trying a bottle of AMSOIL Performance Improver gasoline additive with your next order: http://www.amsoil.com/lit/databulletins/g1135.pdf
AMSOIL P.i. is the most potent gasoline additive available today. As a concentrated detergent, it is unsurpassed in cleaning combustion chamber deposits, intake valve deposits and port fuel injector deposits. AMSOIL P.i. helps maintain peak engine efficiency, fuel economy, power and drivability in newer low mileage engines. In engines with accumulated deposits, testing showed AMSOIL P.i. provided the following clean-up benefits after only one tank of gasoline:
• Improves fuel mileage an average of 2.3% and up to 5.7%
• Reduced emissions
— hydrocarbons (HC) up to 15%
— carbon monoxide (CO) up to 26%
— nitrous oxides (NOx) up to 17%
• Restored power and performance
• Reduced noise from carbon rap and pre-ignition
• Better drivability
• Smoother operation
AMSOIL P.i. works as an “emissions passer.” It is ideal for use prior to emissions inspections.
Port Fuel Injector Deposits form after the engine has been shut down and there is no gasoline flowing through the injectors. During this “hot soak” period the injectors heat up and the gasoline remaining in the injectors degrades and forms deposits. This can happen very quickly with the use of poor quality gasoline and short trip driving. Because the clearances within the injectors are extremely tight and injectors must deliver precise amounts of “atomized” fuel, even small amounts of deposits can cause injectors to malfunction. Fuel flow is reduced and spray patterns are disrupted, decreasing engine efficiency, power and fuel economy, while increasing exhaust emissions.
This is a great product. Available in individual 12 oz bottles or in a case of 12.
Pls send PM for pricing. Wholesale pricing available
AMSOIL Certified Dealer; Maxima.org sponsor and donating member
Old Sep 13, 2012 | 07:21 PM
  #923
AMSOIL Signature Series Synthetic Motor Oil delivers extraordinary lubrication in all types of automotive gasoline engines. Signature Series Synthetic Motor Oil is engineered to outperform competitive conventional and synthetic motor oils. It delivers long-lasting performance and protection.
Extends Drain Intervals, Maximizes Fuel Economy, Reduces Engine Wear, Reduces Oil Consumption and Emissions and it Excels in Extreme Temperatures.
Pls send me a PM for price quote. Wholesale pricing available.
AMSOIL Certified Direct Dealer, Maxima.org Sponor and Donating Member
Tech data sheet: http://www.amsoil.com/lit/databulletins/g2880.pdf
Old Sep 29, 2012 | 11:38 AM
  #924
Get your car and other equipment ready for fall. Pls send PM for pricing on premiere quality AMSOIL synthetic lubricants; complete line of filters by AMSOIL, Wix and Mann; NGK ignition products; Mothers; Trico and more. Wholesale pricing available on all products.
AMSOIL Certified Dealer, Maxima.org Sponsor & Donating Member.
Old Oct 7, 2012 | 05:01 PM
  #925
AMSOIL Signature Series 5w-30. Fantastic oil for even the most severe operating conditions. http://www.amsoil.com/storefront/asl.aspx?zo=232631
Pls send PM with your requirements. Wholesale pricing available
Old Oct 8, 2012 | 05:23 PM
  #926
Looking for an oil with extra amounts of ZDDP to protect your cams? AMSOIL Z-ROD™ Synthetic Motor Oil is specially engineered for classic and high-performance vehicles. It features a high-zinc formulation to prevent wear on flat-tappet camshafts and other critical engine components, along with a proprietary blend of rust and corrosion inhibitors for added protection during long-term storage. Z-ROD Synthetic Motor Oil is designed to perform on the street and protect during storage. Meets API SL and earlier specs, allowing for increased levels of anti-wear additives.
Protects Flat-Tappet Cams: The lifters and cam lobes on flat-tappet camshafts common to high performance vehicles slide rapidly against one another, producing high friction and heat. The friction between the two components can eventually wear down the cam and affect valve operation, ultimately resulting in lost engine power and reduced efficiency. In addition, these areas are splash-lubricated rather than pressure lubricated like other areas of the engine, which adds extra strain on anti-wear additives like the zinc and phosphorus in zinc dialkyldithiophosphate (ZDDP).
AMSOIL Z-ROD Synthetic Motor Oil is formulated with high levels of ZDDP to protect flat-tappet cams, lifters, rockers and other areas susceptible to wear. Its high-zinc, high-phosphorus formulation provides the extra wear protection these critical splash-lubricated components require.
Wholesale pricing available. Pls send PM and include zip code or state of residence so I can determine the correct shipping amount.
Certified AMSOIL Dealer, maxima.org Sponsor and Donating Member
Old Oct 10, 2012 | 05:52 PM
  #927
AMSOIL Ea Air Filters for stock applications and CAI systems - Wholesale Pricing Available
AMSOIL Ea Air Filters are the most efficient filters available to the car/light truck market. The synthetic nanofiber media removes 5 times more dust than traditional cellulose filter media alone and 50 times more dust than wet gauze filter media. They also have super capacity and allow better air flow without compromising efficiency: AMSOIL Ea Air Filters hold up to two and a half times more contaminants than cellulose air filters and allow over twice the air-flow of filters that use cellulose.
Easily cleaned with a shop vac or low pressure compressed air, AMSOIL Ea Air Filters have a service life of 100,000 miles or four years, whichever comes first...these are dry-type filters so there's no oiling required or special cleaning kits to purchase. Available in sizes to replace stock filter. Cone filters (and pre-filters) also available to fit CAI systems.
http://www.amsoil.com/lit/databulletins/g2175.pdf
http://www.amsoil.com/lit/databulletins/g2241.pdf
Certified AMSOIL Dealer, Maxima.org Sponsor and Donating Member
Old Oct 10, 2012 | 09:44 PM
  #928
03VQMAX's Avatar
Dang I should've gotten one of these filters instead of another HKS, oh well
Old Oct 12, 2012 | 03:46 PM
  #929
Complete line of premiere quality AMSOIL lubricants for essentially every application including Japanese and domestic cars & trucks, european vehicles, motorcycles, RVs, marine, stationary equipment, racing, diesel, two cycle, etc. Premiere quality synthetic motor oils, racing oils, specialty oils (e.g. Z-Rod); ATF, GL-4 manual trans gear oil, greases, fuel additives and much more!
I also have a complete line of premium filters from AMSOIL, WIX, Mann and Donaldson. Filters include oil, air, cabin air, transmission and fuel filters.
Premium quality Trico Wiper blades including the outstanding neoform blade; NGK plugs; and Mothers Car Care products.
Detailed description of all products, an on-line application guide and a free on-line maintenance tracker can be viewed/accessed thru my website at www.lubedealer.com/lonestarlubes
Or here's a link to a 20-page catalog that will give you an idea of the wide range of products that are available!
http://www.amsoil.com/lit/g290.pdf
Please send a PM for more information and/or pricing. Pls include your zip code or state of residence so I can calculate correct shipping. Wholesale pricing available on all products!
Certified AMSOIL dealer with over 25 years experience; Maxima.org Sponsor and Donating Member
I look forward to working with you!
Old Oct 15, 2012 | 05:34 PM
  #930
GL-4 75w-90 Manual Trans Gear Oil:
Don't use a common gear oil that's labeled as meeting GL4/ GL5 in your manual transmission. Those oils are typically designed for use in differentials with hypoid gears and the additive packages are too aggressive and will adversely affect the shift quality of your manual transmission and shorten it's life.
AMSOIL GL-4 75w-90 Manual Transmission & Transaxle oil is specifically formulated for manual transmissions/transaxles to provide proper synchromesh operation, smooth shifting and maximum gear protection. Not corrosive to yellow metals commonly used in synchromesh systems. Excellent cold-shift winter performance and outstanding protection in the most demanding high temp, high stress situations. Keeps seals pliable. I sell a ton of this oil to our members and the feedback is outstanding! http://www.amsoil.com/lit/databulletins/g2077.pdf
Please send PM or e-mail to (lonestarlubes at gmail dot com) for additional information and/or pricing. Pls include zip code and/or state of residence so I can calculate correct sales tax (if applicable) and shipping.
Certified AMSOIL Dealer with over 25 years experience; Maxima.org Sponsor and Donating Member. Hundreds of satisifed customers throughout the US and Canada!
Old Oct 21, 2012 | 07:28 AM
  #931
AMSOIL, The Company of Firsts:
FIRST API Qualified 100% synthetic motor oil
FIRST to introduce the concept of extended drain intervals with oils formulated to perform for up to 25,000 miles or 1 year
FIRST synthetic gear lube for automotive use
FIRST synthetic motor oil for diesel engines
FIRST synthetic motor oil for racing engines
FIRST sythetic motor oil for turbo-charged engines
FIRST sythetic motor oil for marine engines
FIRST 100:1 pre-mix synthetic two cycle oil
FIRST synthetic ATF for automotive use
Complete Product line, Wholesale pricing available! Please send PM or e-mail to (lonestarlubes at gmail dot com) for additional information and/or pricing. Pls include zip code and/or state of residence so I can calculate correct sales tax (if applicable) and shipping.
Certified AMSOIL Dealer with over 25 years experience; Maxima.org Sponsor and Donating Member. Outstanding feed-back, Hundreds of satisifed customers throughout the US and Canada!
Old Oct 22, 2012 | 05:57 PM
  #932
Get your car and other equipment ready for fall. Complete line of Premiere quality AMSOIL synthetic lubricants; oil, air and cabin filters by AMSOIL, Wix and Mann; NGK ignition products; Mothers; Trico and more. Wholesale pricing available on all products.
Old Oct 23, 2012 | 05:52 PM
  #933
AMSOIL Inc now offers a free on-line vehicle maintenance tracker. This service is free and available to everyone whether you use AMSOIL products or not.
Users can track maintenance for an unlimited number of vehicles and/or other equipment including motorcycles, ATV's, heavy-duty vehicles and more. The system is versatile and robust enough to track any maintenance service imaginable...oil changes, transmission service, filter changes, spark plug changes, tire rotations, wiper blade replacements...if a maintenance category doesn't exist in the dropdown menu, you can create your own customized maintenance category. Users can also establish e-mail reminder services.
Detailed Maintenance records can increase the value of your car, truck or other equipment. This system also allows the user to export their maintenance data to Exel and or print it from the site to provide to a prospective buyer
To use/explore the system, follow this link and establish your account: www.amsoil.com/whymygarage.aspx?zo=232631
Again, you do not have to use AMSOIL products in order to use this service.
Enjoy and please let me know if you have any questions
Old Oct 24, 2012 | 01:26 PM
  #934
joesae01max's Avatar
PM sent
Old Oct 24, 2012 | 04:58 PM
  #935
Originally Posted by joesae01max
PM sent
Thanks for your inquiry...sent you pricing and ordering info. Pls let me know if I can help. Thanks
Old Oct 25, 2012 | 06:40 AM
  #936
cardana24's Avatar
Blown
PM'd
Old Oct 26, 2012 | 05:07 PM
  #937
Thanks for your orders!
Old Nov 5, 2012 | 03:48 PM
  #938
Old Nov 11, 2012 | 12:48 PM
  #939
• Reduced emissions
Pls send PM for pricing. Wholesale pricing available.
AMSOIL Certified Dealer; Maxima.org sponsor and donating member, Outstanding feedback with hundreds of satisfied customers throughout the US and Canada
Old Nov 12, 2012 | 06:14 PM
  #940
Get your car and other equipment ready for fall. Premiere quality AMSOIL synthetic lubricants; complete line of filters by AMSOIL, Wix and Mann; NGK ignition products; Mothers; Trico and more. Wholesale pricing available on all products.
AMSOIL Certified Dealer, Maxima.org Sponsor & Donating Member. Outstanding feedback with hundreds of satisfied customers throughout the US and Canada. Pls send PM for customized quote
Old Nov 14, 2012 | 06:24 PM
  #941
Old Nov 17, 2012 | 06:05 AM
  #942
Looking for an oil with an higher ZDDP content? AMSOIL Z-ROD™ Synthetic Motor Oil features a high-zinc formulation to prevent wear on flat-tappet camshafts and other critical engine components, along with a proprietary blend of rust and corrosion inhibitors for added protection during long-term storage. Z-ROD Synthetic Motor Oil is designed to perform on the street and protect during storage.
Old Nov 19, 2012 | 12:47 PM
  #943
Thanks for your orders !
Old Nov 21, 2012 | 05:53 PM
  #944
Certified AMSOIL dealer with over 25 years experience; Maxima.org Sponsor and Donating Member. Hundreds of satisfied customers throughout the US and Canada. Outstanding feedback spanning a decade. Preferred Customer and/or Dealerships available - no pressure
Old Dec 7, 2012 | 06:13 PM
  #945
Get your car and other equipment ready for the cold winter months ahead. Premiere quality AMSOIL synthetic lubricants; complete line of filters by AMSOIL, Wix and Mann; NGK ignition products; Mothers; Trico and more. Wholesale pricing available on all products.
Old Dec 10, 2012 | 04:00 PM
  #946
Videos of Interest: Steve Scheuring Racing...flat-out snowmobile racing testimony to the quality of AMSOIL synthetic lubricants and underlying integrity of the company.
http://www.amsoilracing.com/RacingisResearch.aspx
In addition to oils for power sports applications, I offer a complete line of premiere quality AMSOIL lubricants for essentially every application including Japanese and domestic cars & trucks, european vehicles, motorcycles, RVs, marine, stationary equipment, racing, diesel, two cycle, etc. Premiere quality synthetic motor oils, racing oils, specialty oils (e.g. Z-Rod); ATF, GL-4 manual trans gear oil, greases, fuel additives and much more!
Pls send PM for customized quote.
Old Dec 23, 2012 | 06:55 AM
  #947
My deals don't expire. Wholesale pricing available on premiere quality AMSOIL synthetic lubricants; complete line of filters by AMSOIL, Wix and Mann; NGK ignition products; Mothers; Trico and more.
20-yr Nissan owner, 10-yr org member, AMSOIL Certified Dealer, Maxima.org Sponsor & Donating Member. Outstanding feedback with hundreds of satisfied customers throughout the US and Canada. Pls send PM for customized quote
Old Dec 25, 2012 | 06:17 AM
  #948
Happy Holidays! I look forward to serving our community in the year ahead.
Old Jan 1, 2013 | 06:07 AM
  #949
Old Jan 2, 2013 | 03:53 PM
  #950
Please send PM or e-mail direct to lonestarlubes@gmail.com for additional information and/or pricing. Pls include zip code and/or state of residence so I can calculate correct sales tax (if applicable) and shipping.
Old Jan 5, 2013 | 06:42 AM
  #951
Old Jan 14, 2013 | 05:34 PM
  #952
AMSOIL synthetic oils deliver superior performance in winter temps.
Please send PM for quote. Wholesale pricing available
Old Jan 18, 2013 | 02:42 PM
  #953
20-yr Nissan owner, >10-yr org member, AMSOIL Certified Dealer, Maxima.org Sponsor & Donating Member, Veteran-owned business. Outstanding feedback with hundreds of satisfied customers throughout the US and Canada. Pls send PM for customized quote
Old Jan 21, 2013 | 09:59 AM
  #954
RR5's Avatar
RR5
PM sent for the 10 quart container of ATF.
Old Jan 21, 2013 | 03:24 PM
  #955
Order has been processed...will send tracking number when it goes out. This is a fantastic product and I'm sure you're going to be very pleased with it.Thanks!
Old Jan 21, 2013 | 06:23 PM
  #956
Order processed today, shipped today and will be on your doorstep tomorrow! PM sent with Tracking Number.
Thanks again for your order and pls let me know if I can be of further assistance.
Old Jan 21, 2013 | 06:32 PM
  #957
Fakie J Farkerton's Avatar
Thanks for the awesome customer service so far!
Order placed!
Old Jan 22, 2013 | 05:19 PM
  #958
Order placed!
Order processed today, shipped today and will be delivered tomorrow! E-mail sent with shipping confirmation/tracking number.
Old Jan 22, 2013 | 10:19 PM
  #959
RR5's Avatar
RR5
Well there goes my plan to drag my feet for doing the ATF drain+fill. Super fast turn-around time. Thanks again!
Old Jan 29, 2013 | 06:57 PM
  #960
Interested in using a premium synthetic oil but aren't quite ready to accept extended drains? AMSOIL offers Three Tiers of premium synthetic oils, each formulated for different drain intervals:
AMSOIL "Original Equipment" (OE) oil is AMSOIL's most affordable synthetic motor oil and it's formulated to be drained in accordance with the car-makers recommendations
AMSOIL Extended Life oil (XL) is formulated for up to 10,000 miles or 6-months of protection or longer if specified by the manufacturer or if the vehicle has an oil life monitor
AMSOIL Signature Series synthetic motor oils are formulated with the most preiium base stocks and robust additive package to provide unequaled protection for up to 25,000 miles or 1-year, whichever comes first.
http://www.amsoil.com/news/2011_May_...erformance.pdf
20-yr Nissan owner, 10-yr org member, AMSOIL Certified Dealer, Maxima.org Sponsor & Donating Member. Outstanding feedback with hundreds of satisfied customers throughout the US and Canada. Pls send PM for price quote!
