Ksport Big Brake Kit Sale!
Old Jul 25, 2006 | 11:27 AM
Import Kustomz's Avatar
**I havent refunded Member money yet!!**
Ksport Big Brake Kits
Ksport big brake kits provide the ultimate in stopping power for your vehicle. Integrating new brake technology into the design of the kits allows for a kit that highly reduces brake fade and continually cools and refreshes the brake pads surface under braking. These brake systems are designed for easy installation with minimal tools required (in most applications).
The Ksport big brake kit includes:
* 8-Piston Aluminum calipers
* High quality brake pads
* Compression/Rebound adjustable
* D.O.T. Compliant Stainless steel brake lines
* Machined aluminum hats
* Carbon steel brackets
* 13 or 14 inch large ventilated discs
* Ksport SC5 street brake pads (RC1 race pads available for additional cost)
Extreme Lightweight Caliper:
Our extreme lightweight caliper comes in differential bore configuration. It is machined from aircraft quality billet, weighs just over 5lbs. each, and has machined in protection grooves for the bridge tubes. Aluminum pistons, high temperature seals, and stainless steel brake pad wear plates are also standard on each caliper design. The opposed piston caliper design greatly improves pad wear and caliper rigidity over the OEM design. The stainless steel brake lines stop expansion under pressure.
High Performance Rotor:
Most applications utilize the 2-piece floating disc assembly which reduces weight both rotating and unsprung. The floating disc also stops thermal stresses of extreme heat from warping the disc or cupping the braking surface. The unique slot design on the rotor greatly reduces braking noise and expels gas and pad debris faster than conventional slot designs. Every rotor is always heat treated and balanced before shipment for the best possible performance.
Ksport SC5 Street Pads:
These NAOC ceramic pads are designed to give you the optimal braking performance under street and occasional track conditions. Optimal operating temperatures are between 194°F - 1022°F for fast warm up under normal driving conditions. These pads reduce the amount of brake dust by 50% or more when compared to our race pads. The SC5 pads also greatly reduce the amount of noise and wear on the rotor over the race pads.
Ksport RC1 Race Pads:
These carbon metallic race pads are designed to give you the best stopping power possible under extreme track conditions. Optimal operation temperatures are between 480°F - 1472°F so it is not recommended for street use due to high temperature needed for optimal performance. Designed for the racer in mind to reduce brake fade under extreme conditions.
Applications for 95-99 and 00-03
PM Me for Pricing!!
Old Jul 25, 2006 | 11:41 AM
Bk_Maxima's Avatar
How much for a 97 Max SE without ABS?
Old Jul 25, 2006 | 11:47 AM
You got PM!
Old Jul 25, 2006 | 01:10 PM
Rick James's Avatar
Can you PM me a price for a 98 WITH abs.
Old Jul 25, 2006 | 01:13 PM
maximariceboi's Avatar
price please thanks
Old Jul 25, 2006 | 01:40 PM
MDeezy's Avatar
can you PM me a price for the BBK 13" rotors. Thanks
Old Jul 25, 2006 | 01:49 PM
sickmax's Avatar
aaron lavigne FTG
pm plz......
Old Jul 25, 2006 | 02:25 PM
Everyone's got PM!
Old Jul 25, 2006 | 03:08 PM
SPEEDY6's Avatar
Beech Man Whore Slapper
Please PM pricing for 02 3.5L max.
Thanks,
Old Jul 25, 2006 | 03:21 PM
max_speed97's Avatar
How much for a 1998 with ABS?
Old Jul 25, 2006 | 03:36 PM
MidniteMaxSE's Avatar
pm me a price please!!
Old Jul 25, 2006 | 04:03 PM
OHH NOES's Avatar
6spd Swapped
How much for a 5.5gen?
CKOTuHA's Avatar
Pm me a price plz for 02-03 gen
thanks
Old Jul 25, 2006 | 05:09 PM
86maxima96's Avatar
I Broke OT
Pm with pricing, please.
Old Jul 25, 2006 | 05:17 PM
yevrah4728's Avatar
pm please 98 without abs
Old Jul 25, 2006 | 05:18 PM
ThisMaxIsTight's Avatar
..... pm me with a price for 95-99 max, non abs ...thank you
Old Jul 25, 2006 | 05:21 PM
MAXDOUT04's Avatar
* THIS SPACE FOR RENT *
Why is price so secretive................???
Old Jul 25, 2006 | 05:28 PM
i know thats kind of annoying ... can someone who already has gotten the price pm me please !
Old Jul 25, 2006 | 06:06 PM
vsamoylov
interested in the price
Old Jul 25, 2006 | 07:25 PM
sum1punjabi's Avatar
pm me with price for 2001
Old Jul 25, 2006 | 08:27 PM
makavelisk's Avatar
price for 03 max
Old Jul 25, 2006 | 09:11 PM
The Law's Avatar
I R The Law
price for 03 maxima with abs? also why is the price so secretive?
Old Jul 25, 2006 | 09:35 PM
VIP Maxima
8 piston? PM ME price plz
Old Jul 25, 2006 | 10:02 PM
Poowill's Avatar
PM with price w/out ABS Thanks
Old Jul 25, 2006 | 10:26 PM
04silverse's Avatar
will this setup ever be available for 04-06?
Old Jul 26, 2006 | 12:07 AM
ZeroCool19's Avatar
PM me price please 97 max
Old Jul 26, 2006 | 12:11 AM
MainSource's Avatar
Hit 'em with the stun gun
PM price pleez for 97 max.
Old Jul 26, 2006 | 01:21 AM
VIP Maxima
Originally Posted by www.Ksportusa.com
Maxima 95-99 KSP-BKNS040-8331S-O $2,650.00 330mm 8 SC5 Street Orange
(Cefiro A32)
Maxima 00-03 KSP-BKNS050-8331S-O $2,650.00 330mm 8 SC5 Street Orange
(Cefiro A33)
if thats the retail price, most likely they are at about $1800 +
Old Jul 26, 2006 | 11:14 AM
Eveyone's got PM, as for listing the price, I can't do that because that would be against Ksport policy to list a price this low.
Old Jul 26, 2006 | 02:26 PM
d00df00d's Avatar
Old enuf to pick his own gears
Like the coilovers?
Also, please PM with prices for:
'95 Maxima w/ ABS, 13" rotors
'96 Integra LS w/ ABS, 13" rotors
And for those of you complaining about "secretive" pricing, Minimum Advertised Pricing (MAP) is just a fact of life. Companies require it when they sell through multiple retailers to reduce the chances that one or two retailers will just crush all the others.
Old Jul 26, 2006 | 03:48 PM
alpinestars™'s Avatar
THIS IS...
Holy sh!te! PM me teh prices for an 01 AE Max W/ABS.
Old Jul 26, 2006 | 03:52 PM
Jeff92se's Avatar
I'm needing a caw
I'd like a pm price for the 13" rotor kit. 95 maxima application will do
Old Jul 26, 2006 | 04:00 PM
86maxima96's Avatar
I Broke OT
8 piston is crazy stuff. very nice looking kit. a bit much for me, though.
Old Jul 26, 2006 | 04:04 PM
SinCityMaxPower's Avatar
Please PM me a price for the most inexpensive set-up for 2000.
Old Jul 26, 2006 | 06:29 PM
MDeezy's Avatar
I love the fact that such an application is availble to us. As we all know were not exactly the most popular Nissan for aftermarkets parts.
Thanks Ksport. Hope to see some pics of this Setup on somones car
Old Jul 26, 2006 | 06:38 PM
The Law's Avatar
I R The Law
how much is the bbk without abs? i forgot to ask
Old Jul 26, 2006 | 10:53 PM
gmax96's Avatar
me too pls
Old Jul 26, 2006 | 11:12 PM
Fr33way™'s Avatar
Wild for Width
That kit looks nice.
Please PM price for 98 w/ABS. Thanks!
Old Jul 26, 2006 | 11:15 PM
A33 VQ30DEK's Avatar
please PM me the price for 8 piston? haha is this for real.... but yah
4, 6, 8 with the 14inch rotors...
or just PM me everything thanks!
W/ ABS
Old Jul 27, 2006 | 05:58 AM
mforrest100's Avatar
Please PM the price for 95 max non ABS.
Thanks,
Mike
