GB:Ksport Big Brake Kit! $1295 Shipped!
Old Mar 30, 2007 | 11:00 AM
jinsu's Avatar
Ksport Big Brake Kits
Ksport big brake kits provide the ultimate in stopping power for your vehicle. Integrating new brake technology into the design of the kits allows for a kit that highly reduces brake fade and continually cools and refreshes the brake pads surface under braking. These brake systems are designed for easy installation with minimal tools required (in most applications).
The Ksport big brake kit includes:
* 8-Piston Aluminum calipers
* High quality brake pads
* D.O.T. Compliant Stainless steel brake lines
* Machined aluminum hats
* Carbon steel brackets
* 13 inch large ventilated discs
* Ksport SC5 street brake pads (RC1 race pads available for additional cost)
Extreme Lightweight Caliper:
Our extreme lightweight caliper comes in differential bore configuration. It is machined from aircraft quality billet, weighs just over 5lbs. each, and has machined in protection grooves for the bridge tubes. Aluminum pistons, high temperature seals, and stainless steel brake pad wear plates are also standard on each caliper design. The opposed piston caliper design greatly improves pad wear and caliper rigidity over the OEM design. The stainless steel brake lines stop expansion under pressure.
High Performance Rotor:
Most applications utilize the 2-piece floating disc assembly which reduces weight both rotating and unsprung. The floating disc also stops thermal stresses of extreme heat from warping the disc or cupping the braking surface. The unique slot design on the rotor greatly reduces braking noise and expels gas and pad debris faster than conventional slot designs. Every rotor is always heat treated and balanced before shipment for the best possible performance.
Ksport SC5 Street Pads:
These NAOC ceramic pads are designed to give you the optimal braking performance under street and occasional track conditions. Optimal operating temperatures are between 194°F - 1022°F for fast warm up under normal driving conditions. These pads reduce the amount of brake dust by 50% or more when compared to our race pads. The SC5 pads also greatly reduce the amount of noise and wear on the rotor over the race pads.
Ksport RC1 Race Pads:
These carbon metallic race pads are designed to give you the best stopping power possible under extreme track conditions. Optimal operation temperatures are between 480°F - 1472°F so it is not recommended for street use due to high temperature needed for optimal performance. Designed for the racer in mind to reduce brake fade under extreme conditions.
INTRO PRICING! $1295 shipped to 48 U.S States. for ALL NISSAN APPLICATION
Order Here!!
SUMMER SPECIAL! A32/A33 kit shipped to 48 U.S States.
Order Here!!
Application listed here-
http://www.ksportusa.com/asp/brake_kits.asp
I have installed the kit on my 03 Mazda6s two weeks ago and my feedback so far is that the brake definately bites much harder and faster. The brake pedal feel is very possitive (firm feel). Now it takes less foot pressure effort to get the same amount of brake force. The calipers are very light due to full aluminium design (even lighter than the stock caliper)
The brake will clear 17in and up rims (depends on rim spoke, mine was about 2mm too close so i am running with a set of spacer and so far very solid after 6 months)
Old Apr 1, 2007 | 04:24 AM
maxximaa's Avatar
the price is for the front only?
how much would it be for the whole car shipped to Canada?
Old Apr 1, 2007 | 10:29 AM
jinsu's Avatar
price is the same for the rear kit as well, so $1295 x2 for front and back. shipping to canada is $120 extra.
Old Apr 2, 2007 | 07:31 PM
alicious's Avatar
the org...not what it was
whoa, that's a hell of a good price...what type of warranty comes with them?
Old Apr 3, 2007 | 04:38 AM
maxximaa's Avatar
damn, i got a lot to save up...
Old Apr 3, 2007 | 06:12 AM
upstatemax's Avatar
I also doubt they will fit behind most stock rims... 6th gen brakes don't even fit behind 2000-2001 17's.
Also Jinsu, how do they work with the stock master cylinder?
Old Apr 3, 2007 | 07:26 AM
jinsu's Avatar
the kit was designed to work with stock master cylinders as they decreased the size of each piston while increasing the number of pistons per caliper in order to keep everything in balance.
Old Apr 3, 2007 | 09:05 AM
Crooklyn's Avatar
*Subscribing* also saving up.. Was gonna buy another kit, but this suits my purposes.
Old Apr 3, 2007 | 10:50 AM
Maximeltman's Avatar
uh, warranty info??
Old Apr 3, 2007 | 02:22 PM
alicious's Avatar
Originally Posted by Maximeltman
uh, warranty info??
ummm yeah, a warranty against material and/or manufacturing defects....
Old Apr 6, 2007 | 08:03 AM
A 1 year warranty? lol like the coilovers that came all defected lol
free bump
Old Apr 6, 2007 | 08:15 AM
jinsu's Avatar
hmmm... i am not sure where you getting ksport coilover are all defected from. From all the ksport coilover i have sold so far for maxima (not including all other applications) warranty work has been below 10% which is what i consider way above average in after market industry, especially on products such as full coilovers. but for this thread's sake, we should level the coilover debate out of here.
Old Apr 15, 2007 | 09:30 PM
maximariceboi's Avatar
i was considering these last year....im still debating for this bbk, z32 or rotora
Old Apr 18, 2007 | 12:48 PM
alicious's Avatar
i just need an answer about the warranty and the tax return check will be spent
Old Apr 19, 2007 | 07:59 AM
jinsu's Avatar
will let you know in a few hours.
Old Apr 19, 2007 | 09:32 AM
jinsu's Avatar
1 year limited warranty against any manufacturing defect.
Old Apr 21, 2007 | 03:23 PM
4x4Max's Avatar
Have any of these kits had any problems for any car? A warranty is nice and everything, but a braking system isn't something that i'd like to fail, so i'm making sure.
Old Apr 21, 2007 | 03:59 PM
jinsu's Avatar
i have them on my own car for over 7month and they are GREAT!
Old Apr 21, 2007 | 10:57 PM
Jess's Avatar
SHIFT_In2D
I'm subscribed. Will need to save up for these
Old Apr 22, 2007 | 08:23 PM
irish44j's Avatar
retired moderator
that's quite an intro price considering the MSRP is about $2500+...
will be interested to see if these are any good.
Old Apr 22, 2007 | 09:09 PM
LA02MAX's Avatar
Do you know how long this will be going on?
Old Apr 23, 2007 | 05:57 AM
jinsu's Avatar
whenever jinsu-power.com decide to end the promotion. so there is no defined end date.
Old Apr 23, 2007 | 01:17 PM
4x4Max's Avatar
Do you know how much the rotors weigh?
Old Apr 23, 2007 | 02:25 PM
LA02MAX's Avatar
That was going to be my next question. At first I thought it said 5 lbs. and went but then I realized that was the caliper weight -
Old Apr 24, 2007 | 06:18 AM
jinsu's Avatar
hahaha, i don't think i would use a 5lb rotor on my own car... you just can't reduce mass without reducing heat transfer capacity unless you are talking about carbon fiber rotors.... i will get you guys the weight later today.
Old Apr 24, 2007 | 11:09 AM
jinsu's Avatar
the rotors are 22lbs each. the entire kit weights in under 60lbs.
Old Apr 24, 2007 | 11:13 AM
LA02MAX's Avatar
Aw ****...that's more than my stock 12.6" one-piece rotors
Old Apr 24, 2007 | 01:02 PM
jinsu's Avatar
they are much thicker and densier than your stock rotors which is where you get all the heat capacity from, so that you don't get over heated brakes that fades under extreme use.
Old Apr 25, 2007 | 09:39 PM
RIPTIDER's Avatar
2,650 is what its listed for.
Sorry for my confusion, but the 1295 price is for BOTH the front AND rear kits??
If that's the case, then I might have to pick it up.
Old Apr 25, 2007 | 09:41 PM
maxximaa's Avatar
hope this helps
Old Apr 27, 2007 | 04:21 PM
BlackBIRDVQ's Avatar
drag racing is for wussies
To my knowledge Rotora does not make a kit for our cars. Unless you buy one for a 240SX which "should" fit.
1295 is a good deal for these brakes.... but I have a problem buying unknown brand products. 22lbs for these rotors is way too much. Baer Eardispeed weight half of that and are just as big. 2 piece rotors are supposed to be lighter. I took my Blehmco kit off because of the heavy rotors.
Old Apr 27, 2007 | 04:39 PM
irish44j's Avatar
retired moderator
you could have gotten matt's 2pc....they're nice and light
Old Apr 27, 2007 | 09:27 PM
Matt was waiting on the fabricator.... I couldn't wait any longer and ditched my brake setup. For the longest time I been trying to get a hold of Matt to see if he has any of his rotors in stock.... but he never replies to my E-mails. Jeff was kind enough to get the brackets and hub rings done for the Cobra rotors. I got a brand new set of Z32 calipers waiting to be set out for powdercoating, and then I will slap on a set of 2 piece Baer rotors under my new wheels I got
Old Apr 30, 2007 | 12:28 AM
please check again =] for a fact they make bbk for the 5th gens and they make the calipers for the 4th gens. if you are interested pm me.
Old Apr 30, 2007 | 05:21 AM
jinsu's Avatar
Off Topic Warning! Off Topic!
Old May 2, 2007 | 12:09 PM
jinsu's Avatar
okay, OFFICIAL Weight for the rotors. 18.5lbs per rotor. Just went and weighted them.
Old May 2, 2007 | 02:31 PM
LA02MAX's Avatar
That's better
We'll see what the situation is after I buy new tires and go from there
Old May 6, 2007 | 10:32 PM
VIP Maxima
how much for the 14" kit
Old May 31, 2007 | 11:55 AM
BLKLEGEND's Avatar
What is the width of the rotor, not the 330mm, but the width? What is the size of each piston on the caliper?
Thanks.
Old Jun 7, 2007 | 09:02 PM
speedstermax's Avatar
this is a great deal I wish I can get in for it but I have to wait for my other mod but good luck.
