Genuine Nissan Parts @ Big discounts!!
BOOTS
hello, front boots are 14.25 ea you pay 11.40 ea
front mounts are 40.70 ea you pay 32.56 ea
rear boots are 26.58 ea you pay 21.26 ea
rear mountas are 27.95 ea you pay 22.36
you may also need the rear rubber seats 10.88 ea you pay 8.70 ea
thanx,
matt
heQUOTE]Originally posted by GaMax97GLE
not sure if this has been asked before (35 pages to go through)...
for a 97 maxima:
dust boots / bump stops (all four)
strut mounts (all four)
thanks. [/QUOTE]
thanx,
matt
for a 97 maxima:
thanks. [/QUOTE]
LENSES
hello, yes you can buy those separately 136.55 ea you pay 109.24 ea
thanx,
matt
QUOTE]Originally posted by Raf2kMax
I have HIDS already on my 2000 maxima. I was wondering if i can purchase just the AE headlight covers (lenses) which are just smoked out? how much? thanx [/QUOTE]
thanx,
matt
Originally posted by Tustin Nissan
Hi,
Tustin Nissan carries the new Razo "Zero" bulbs, they are the whitest bulbs we have seen..$49.95/pair...we also have the APC Ultra white bulb for $29.95/pair
Thanks,
tustinnissan.com
Hi,
Thanks,
tustinnissan.com
are these the razo premium white zero bulbs ??? if so how do i order them thats a great deal the cheapest ive seen those bulbs was about $95 a pair
Re: baffled
what year are we talking about?
matt
QUOTE]Originally posted by Menacer
Hi Matt, How much for the front speaker baffles that go on the bose speakers so that i don't have to make my own?
matt
[/QUOTE]I'm sorry, it's for a 2000 Nissan Maxima. Thanks
PRICES
[hello, the pads are 65.99 you pay 52.79
stillen lip is 239.00 you pay 191.20
shipping 30.00
thanx,
mattQ
hUOTE]Originally posted by KiLIAkLoWn
Brake Pad for a '97? Shipped to 32792(orlando,FL area)
Also a stillen front lip? Thanks [/QUOTE]
shipping 30.00
thanx,
mattQ
LINES
hello, i wasn't sure if you wanted lines or hoses, so i'm giving you prices for both.
three lines 12.94 12.94 and 14.79 you pay 10.35 10.35 and 11.83
two hoses 39.36 and 11.79 you pay 31.48 and 9.43
two washers .29 ea you pay .23 ea
thanx,
matt
QUOTE]Originally posted by mtrai760
How much for clutch hydralic lines for a 4th gen?
[/QUOTE]
thanx,
matt
[/QUOTE]
Re: LINES
thanx,
matt
92 se grill and floor mats (if you have them) please.
thanx,
matt
conversion parts
u never gave me a price on parts for conversion
2 shifting rods (support rod + control rod) (acquire used w/ all the hardware)
>Return spring (connect to the 2 shifting rods (Buy this new, the stiffer the tighter your shifter feels)
>1 shifter (Acquire used to get nuts and bolts (buy with the shifter rods)
>1 shifter console piece (interior)
>1 shift consul bracket (Replaces your auto one) (interior) (dealer name plate bolt and transaxle hole cover)
>1 brake pedal
>1 clutch pedal
>1 master cylinder
>Hydraulic lines for clutch
>1 slave cylinder for clutch
>1 extra set of tranny harnesses (might come w/ 5spd tranny)
>1 18ga wire and wiretaps
>Assorted cotter pin set.
>1 Manual Fly wheel
>1 Manual motor mount
>Locking pin and clip for the clutch pedal to the master cylinder (you could bend a nail but I would go to the dealer and pay $4)
>2 nuts that fit the threads on the clutch pedal.
>1 bolt that bolts in the top of the clutch pedal (the dealer can find it's size for you)
>1 bolt that connects the control rod to the tranny (the dealer can find it's size for you)
>1 brake pedal
>1 clutch pedal
>1 master cylinder
>1 Manual Fly wheel
Re: Re: LINES
hello, it looks like you have a lot of cash, so i'm gonna raise these prices at least 500% ha ha ha
actually the grill is 96.60 you pay 77.28
mats are 68.00 you pay 54.40
thanx,
matt
[/B][/QUOTE]
thanx,
matt
Originally posted by N34JZ
Re: o2 Sensors
hello, there are three o2 sensors
front ones are 137.43 ea you pay 109.95 ea
rear one is 78.12 you pay 62.49
thanx,
QUOTE]Originally posted by Wht98SE
How much for o2 Sensors for a '98 SE w/ Automatic Trans.? [/QUOTE]
thanx,
Re: 91 gxe
[hello, are you asking me for motor mounts?
is your car manual or auto?
do you just want the ones that mount to the cross member?
matt
QUOTE]Originally posted by crazy4maxima
clcok
125mph white gauges vg think se modle will work with vg gxe 125mph
motor mounts engine and tranny [/QUOTE]
matt
clcok
Re: conversion parts
hello, brake pedal is 74.18
clutch pedal 48.27
clutch pedal bracket 57.41
clutch master 95.90
clutch slave 50.98
flywheel 243.99
hydraulic lines---- see post above
i'll give you 20% off these prices.
which motor mount do you need?
what is your interior color code?
matt
clutch pedal 48.27
clutch master 95.90
clutch slave 50.98
flywheel 243.99
matt
>1 brake pedal
>1 clutch pedal
>1 master cylinder
>1 Manual Fly wheel
>1 brake pedal
>1 clutch pedal
>1 master cylinder
>1 Manual Fly wheel
Re: 1991 GXE Auto
[hello the mounts are
97.05 you pay 77.64
64.68 you pay 51.74
80.37 you pay 64.29
75.32 you pay 60.25
clock is 201.60 you pay 161.28
temp guage is 132.79 you pay 106.32
speedometer is 196.28 you pay 157.02
tach is 256.90 you pay 205.52
thanx,
The motor mounts and tranny mounts.. there are 5 i think...front and rear... That are poly or rubber.. center Clock and cluster white faced 125 mph guages.. [/QUOTE]
97.05 you pay 77.64
64.68 you pay 51.74
80.37 you pay 64.29
75.32 you pay 60.25
thanx,
Re: Re: conversion parts
clutch pedal 48.27
clutch master 95.90
clutch slave 50.98
flywheel 243.99
matt
i need motor mount for manual transmission...i'm not sure which type but it's supposed to be for conversion...that isn't everything i asked for though...could u give me a total before and after your friendly discount?
clutch pedal 48.27
clutch master 95.90
clutch slave 50.98
flywheel 243.99
matt
Speaker / Audio ?'s
1) In the Crutchfield catalog, it says that 6 3/4" speakers can fit in the '95-'99 Maxima, yet you recommend 6 1/2" speakers, what is the correct size that will fit if I want to get speakers?
2) I have the Midlevel CD/Cassette for my '98 SE, can I still add the Bose system and if so, how much would the entire kit cost?
3) I heard that the Head Unit for the Midlevel '99 CD/Cassette produces more power & better sound, is that true and can I change my '98 Head Unit for the '99?
- Will
- Will
FOG LIGHT
[hello, the whole fog light left side is 177.42 you pay 141.93
thanx,
matt
QUOTE]Originally posted by MAXXIMIZEDMAX97
Hey Tustin...I need a price on just the Driverside fog, for a '99 Maxima SE. The whole fog light, thats it...I don't need the set,just the driverside!
Thanks Alot!
ChRiS From CT. (MPCC) [/QUOTE]
thanx,
matt
Thanks Alot!
TAIL LAMPS
hello, the outers and inners are the same price 78.42 ea you pay 62.73
ea the boot is 59.55 you pay 47.64
thanx,
matt
QUOTE]Originally posted by 1FSTMAX
Hello Tustin Nissan rep, I want to know how much are inner and outer taillights for a 97' Maxima, and also a shifter boot.
Thank you [/QUOTE]
thanx,
matt
Thank you [/QUOTE]
Re: Speaker / Audio ?'s
hello, all i can say is that the nissan ones are 6x 1/2. i don't know what will fit.
the bose unit is 1703.00 you pay 1362.40 (really)
the mid level head for the 99 is 675.00 you pay 540.00
thanx,
matt
thanx,
matt
- Will
- Will
never gave me price on ALL parts for conversion
i know you're a busy man and all but i'm trying to see which way i'm getting a better deal...getting parts new or used....hopefully if all your parts combined come out to be 500 or less, i'm better off with getting it new...here are the parts...i have to decide soon...i'm sorry for bothering u at time like this i know u worried about finals and what not...but iif you can please get me price on following:
1 brake pedal
1 clutch pedal
1 master cylinder
1 Manual Fly wheel
thanks in advance
Mecca
meccanoble
1 brake pedal
1 clutch pedal
1 master cylinder
1 Manual Fly wheel
thanks in advance
Mecca
meccanoble
