Genuine Nissan Parts @ Big discounts!!
Old May 11, 2002 | 11:27 AM
  #561
Wills98MaxSE's Avatar
1 of few unmodded 4G Maxs
Left Foglight
How much for a driver's side foglight on a '98 SE
Old May 11, 2002 | 12:33 PM
  #562
Tustin Nissan's Avatar
Re: never gave me price on ALL parts for conversion
[hello, here is some more prices
shift support rod 53.55 you pay 42.84
shift rod 96.69 you pay 77.35
misc hardware 30.00
mt trans mount 80.37 you pay 64.29
shifter parts ****, rod,trim piece.,boot 110.00 you pay 88.00
i'll be honest with you, this could be a real problem with getting all the hardware, the shipping, parts could be on backorder etc.
also if the parts are wrong you'll have to send back and wait more.
i would like to help you, it's just going to be very hard communicating via phone or net. (i wish i could show you my microfiche
it would be a lot easier.
also i have never done this kind of order. so i'm a little nervous.
matt
QUOTE]Originally posted by meccanoble
i know you're a busy man and all but i'm trying to see which way i'm getting a better deal...getting parts new or used....hopefully if all your parts combined come out to be 500 or less, i'm better off with getting it new...here are the parts...i have to decide soon...i'm sorry for bothering u at time like this i know u worried about finals and what not...but iif you can please get me price on following:
2 shifting rods (support rod + control rod) (acquire used w/ all the hardware)
Return spring (connect to the 2 shifting rods (Buy this new, the stiffer the tighter your shifter feels)
1 shifter (Acquire used to get nuts and bolts (buy with the shifter rods)
1 shifter console piece (interior)
1 shift consul bracket (Replaces your auto one) (interior) (dealer name plate bolt and transaxle hole cover)
1 brake pedal
1 clutch pedal
1 master cylinder
Hydraulic lines for clutch
1 slave cylinder for clutch
1 extra set of tranny harnesses (might come w/ 5spd tranny)
1 18ga wire and wiretaps
Assorted cotter pin set.
1 Manual Fly wheel
1 Manual motor mount
Locking pin and clip for the clutch pedal to the master cylinder (you could bend a nail but I would go to the dealer and pay $4)
2 nuts that fit the threads on the clutch pedal.
1 bolt that bolts in the top of the clutch pedal (the dealer can find it's size for you)
1 bolt that connects the control rod to the tranny (the dealer can find it's size for you)
thanks in advance
Mecca
meccanoble
[/QUOTE]
Old May 11, 2002 | 12:40 PM
  #563
Re: SE Emblem
hello, if your looking for the one on the door, it's 19.03 you pay 15.22
thanx,
matt
Originally posted by Wht98SE
how much for an SE emblem?
Old May 11, 2002 | 01:00 PM
  #564
NJMAX2KSE's Avatar
S_H_I_F_T_
can i get a price and part #
for the guage cluster bulbs for a 2000 SE black tabs/brown tabs
thanks
mm420
Old May 11, 2002 | 01:03 PM
  #565
skeelo34's Avatar
How much for a 96 maxima in pieces? J/k. How about 5spd bearings for the tranny?
Old May 11, 2002 | 01:13 PM
  #566
Re: AE Auto Shifter
hello, it seems to me that someone said that the whole assy had to be replaced to make it work.
the **** is 107.28 you pay 85.82
whole assy is 323.77 you pay 259.01
you may want to ask around to see how it's done.
thanx,
matt
Originally posted by Igor911
How much for the shift **** on an 20th AE for an Automatic?
Old May 11, 2002 | 01:16 PM
  #567
Re: Side skirts?
hello, the good news is that they come painted. the bad news is that they run 439.40 ea you pay 351.52 ea plus probably 50 bucks for the hardware.
thanx,
matt
QUOTE]Originally posted by kirzan
How much are the lower side skirts for the 2002 SE? [/QUOTE]
Old May 11, 2002 | 01:18 PM
  #568
Re: Left Foglight
hello, the fog lamp is 177.42 you pay 141.93
thanx,
matt
Old May 11, 2002 | 01:25 PM
  #569
skeelo34's Avatar
Can you get parts to rebuild a 5spd tranny? I blew my tranny, and the first thing ill probably need is the gasket that goes where the driveshaft plugs in and the bearings that commonly fail on these trannies.
Old May 11, 2002 | 02:02 PM
  #570
Re: can i get a price and part #
hello, you are not going to believe this.
14 bulbs for 13.01 ea you pay 10.40 ea
6 bulbs for 3.98 ea you pay 3.18 ea
sorry mr.420 i did not want to tell you that.
you might want to take them out of the sockets and try matching them up at a local dealer.
thanx,
matt
QUOTE]Originally posted by Mr.max420
thanks
mm420
[/QUOTE]
Old May 11, 2002 | 02:09 PM
  #571
bearings
hello, nice joke, i almost crapped myself.
4 bearings
2 main shaft bearings 34.37 and 34.21 you pay 27.49 and 27.36
2 input shaft bearings 34.32 and 39.83 you pay 27.45 and 31.86
thanx,
matt
Old May 11, 2002 | 02:25 PM
  #572
AXLE SEALS
hello, the two axle seals are about 6.00 ea
please let me know when ordering if it's limited slip or not.
thanx,
matt
Old May 11, 2002 | 05:08 PM
  #573
meccanoble's Avatar
Sports Button FTW
Re: Re: never gave me price on ALL parts for conversion
microfishe? not sure what u mean...also, i'm aware of the problems that may occur...but this is a steady process and due to ehh...skeelo's mishap, i actually have more time than before...but let me know what you need me to do to make this search easier for you....there should only be like one type of each piece for 4th gen manual....only thing u might have to worry about is if certain parts work with locking and others non locking differential...i'm going to go back and tally it all up...if some parts are on back order, how long you think it will take to come in? if only a few weeks, i'm ok with that...if a few months...then ....but please let me know what you need me to do to make this search better....
misc hardware 30.00
matt
1 brake pedal
1 clutch pedal
1 master cylinder
1 Manual Fly wheel
thanks in advance
Mecca
meccanoble
[/QUOTE]
Old May 11, 2002 | 10:26 PM
  #574
Low Washer Fluid light & sensors - pls. advise
My '98 SE doesn't have the cold package which I know comes w/ the low washer fluid light. I would like to have the light so I know when to add washer fluid instead of running the reservior dry & blind.
A few ?'s...
1) Would the dash have to be changed somehow to accomodate this light or is it already there & just not hooked up to anything yet?
2) What would have to be changed & done underhood besides the reservoir and adding the sensors?
3) How much would this run?
4) Is it worth it?
Old May 12, 2002 | 10:29 PM
  #575
mtrai760's Avatar
'Trynna' is not a word
Re: LINES
I need these, plus the block they connect to, and the hardware for the clutch bleeder. How do I order? I sent ya an email too.
hello, i wasn't sure if you wanted lines or hoses, so i'm giving you prices for both.
three lines 12.94 12.94 and 14.79 you pay 10.35 10.35 and 11.83
two hoses 39.36 and 11.79 you pay 31.48 and 9.43
two washers .29 ea you pay .23 ea
thanx,
matt
QUOTE]Originally posted by mtrai760
How much for clutch hydralic lines for a 4th gen?
[/QUOTE]
Old May 13, 2002 | 04:32 AM
  #576
dmbmaxima2k2's Avatar
Maxima.org Sponsor and Donating Maxima.org Member
a 2002 intake manifold.
Old May 14, 2002 | 12:14 PM
  #577
Re: Low Washer Fluid light & sensors - pls. advise
hello, the tank with sensor is 99.72 you pay 79.77
i don't know the other answers but i can tell you that there is only one dash so there must be a light somewhere.
thanx,
nmatt
A few ?'s...
4) Is it worth it?
Old May 14, 2002 | 12:33 PM
  #578
hello, the intake is 426.00 you pau 340.80
thanx,
matt
QUOTE]Originally posted by dmbmaxima88
a 2002 intake manifold. [/QUOTE]
Old May 15, 2002 | 11:00 AM
  #579
KiLIAkLoWn's Avatar
Car Bra for 97. If i can only get the Hood Mask part that would be best. Thanks
Old May 15, 2002 | 12:49 PM
  #580
BRA
hello, the bra is 106.00 you pay 84.80
shipping is 10.00
thanx,
matt
Old May 15, 2002 | 01:12 PM
  #581
wharper's Avatar
I need a new variable intermittent windshield wiper controller stalk for my 1999 se limited. Could you give me a price?
Also, how much for genuine nissan oil filters for my car?
Old May 15, 2002 | 02:49 PM
  #582
SWITCH
hello, the wiper switch is 56.70 you pay 45.36
oil filters are 5.83 ea you pay 4.66
thanx,
matt
QUOTE]Originally posted by wharper
[/QUOTE]
Old May 16, 2002 | 06:36 AM
  #583
maxdout92se's Avatar
wondering
theres a 3rd gen max on the org with smoked out clear lenses that he says he recieved from UK b/cause they come standard on the 3rd gens over there......i was wondering if you could get a hold of these and what they would cost???
Old May 16, 2002 | 08:36 AM
  #584
Re: wondering
hello, sorry but i can't get those.
matt
QUOTE]Originally posted by maxdout92se
theres a 3rd gen max on the org with smoked out clear lenses that he says he recieved from UK b/cause they come standard on the 3rd gens over there......i was wondering if you could get a hold of these and what they would cost??? [/QUOTE]
Old May 16, 2002 | 01:31 PM
  #585
osborn21781's Avatar
Master switch
How much would the master switch (Power lock/ Power window) cost with bezel included? I'm talking about the entire assembly that plugs into the harness. By the way, mine is a 1992 Maxima SE with black trim. Thank you in advance.
Old May 16, 2002 | 05:32 PM
  #586
Re: Master switch
[hello, your swith is 116.40 you pay 93.12
bezel is 26.38 you pay 21.10
thanx,
matt
QUOTE]Originally posted by osborn21781
How much would the master switch (Power lock/ Power window) cost with bezel included? I'm talking about the entire assembly that plugs into the harness. By the way, mine is a 1992 Maxima SE with black trim. Thank you in advance. [/QUOTE]
Old May 17, 2002 | 12:22 PM
  #587
vacation
hello everyone, i will be on vacation from 5-20 til 5-29
someone will be here, but since we will be short handed, responses may take awhile. also my website www.tustinnissan.com is being repaired. (i am not getting the orders people put in) so if you want parts or prices, just ask for them on this site.
thanx again,
matt
Old May 18, 2002 | 01:13 PM
  #588
skeelo34's Avatar
Re: vacation
thanx again,
matt
Matt, on friday I ordered some bearings for my 5spd tranny from you. Do those come with new shims? I completely took my tranny apart, and the shim on one side are cracked and chipped. I went to the dealer, and they wanted 140 dollars??? Also I need the main Differential gear. Its the biggest gear wheel in there. Its the one that i bought the bearings for. Some of the teeth have chipped off (probably when the bearing fell apart and floated in the fluid).
Thanks. SO i need the new gear wheel and a shim.
Old May 19, 2002 | 08:19 AM
  #589
remykins's Avatar
Re: vacation
Can you get the 2k2 HLSD pedals? If so how much are they and can they easily be installed on a non HLSD max?
Old May 19, 2002 | 04:44 PM
  #590
pro's Avatar
pro
Hi,
Do you have any body kits for a 97 maxima?
Thanks,
Paul
Old May 20, 2002 | 03:36 PM
  #591
Re: Re: vacation
sorry the "maxima god " is on vacation ! what does HLSD mean ?
[QUOTE]Originally posted by remykins
Can you get the 2k2 HLSD pedals? If so how much are they and can they easily be installed on a non HLSD max? [/QUOT
Old May 20, 2002 | 03:39 PM
  #592
the only one i've seen is from steve millen ?
if you like it, email me and i'll get you a price
[QUOTE]Originally posted by pro
[B]Hi,
Thanks,
Paul
Old May 20, 2002 | 05:54 PM
  #593
remykins's Avatar
Re: Re: Re: vacation
[QUOTE]Originally posted by Tustin Nissan
The 2002 maximas with the limited slip differential came with drilled alluminum pedals. Can you buy those pedals for other 2k2's like you can with the AE pedals?
Old May 21, 2002 | 10:18 AM
  #594
SpeedCrazie's Avatar
Can't you get the NGK spark plugs for my 95 SE for a good price?
SpeedCrazie
Old May 22, 2002 | 07:24 AM
  #595
Larcenist's Avatar
suspension parts.....
how much for these suspension parts for a 1997 nissan maxima.... im not sure if the part numbers are correct for my model so if u could check for me i would appreciate it... could u include the total price with shipping to maryland (zip code 20853)
(2)54034-31u01-front spring seat ("*SEAT-RU" on invoice)
(6)54034-85e10-front urethane isolator ("SEAL-RUB" on invoice)
(2)54329-39u00-front spacer ("SPACER-F" on invoice)
(2)55034-31u00-rear spring seat ("*SEAT RU on invoice)
(2)55031-33p10-rear urethane isolator("SEAL-RUB" on invoice)
(2)55338-0m000-rear spacer (*SEAL-SH" on invoice)
Old May 23, 2002 | 05:40 PM
  #596
dlee275's Avatar
shift boot
I have a 96 maxima se w/a beige interior. I am looking for the shift boot for my car. I guess it will be tan...the one I have is the wrong color for some reason. How many colors does the boot come in? Just black and tan? Thanks.
Old May 26, 2002 | 11:46 AM
  #597
Dasyce's Avatar
95-99 chrome gauge rings?
'97 front bumper cover?
Old May 27, 2002 | 09:31 AM
  #598
N34JZ's Avatar
Needs non-Maxima Friends
how
can I go about ordering a 92 SE grill, for the qoute price of 79? I need to get the grill by the end of next week
Old May 28, 2002 | 05:00 PM
  #599
Menasor's Avatar
Hi Matt,
I placed an order for rear turn signal bulbs for a 2000 Nissan Maxima, and some other stuff (plastic clips) and wanted to know my order went through. I also need a qoute for the transmission control module and the transmission solenoid valve assembly.
Old May 29, 2002 | 01:25 AM
  #600
super32's Avatar
Donating member? what the?!
What do you have for me?
Hello, I have a '91 SE.
I am interested in a
1. sway bar kit
2. strut tower brace
3. a new air intake (maybe CAI if possible)
4. or a Pop Charger
5. maybe headers (are headers the same as y-pipes or b-pipes? I have no idea what y- and b-pipes are).
Another thing is that both my front bumper and my rear bumper is starting to fade, as well as my spoiler(with third brake light). How much does a front and rear bumper cost? I have a charcol/dark gray maxima, if you needed to know
Also, would you happen to know where I get find some BG44K?
Thanks for the help.
Donald
