JD-lightings 50watts HID $145 shipped!
I have an '04 Maxima with the factory Xenon H.I.D.'s and my right side headlight is no longer working on me since this evening. Which one would be perfect for me? Keep in mind I want to match the "factory look" since my left headlight is still functional.
I was hoping you could help me out.
I have stock hid headlights. The right bulb appears to be out. It would go out then when I hit certain bumps it would come back on. But now it never comes on. I was wondering if I could simply replace the bulbs, or if you think the ballast would be good to replace too? For all I know these are the original ones. Would your bulbs work fine with a 6k temp on stock ballast? Do I need a bi-zenon bulb just for the headlight or single? How much would a 6k be shipped for 2 bulbs. Please PM me, thnx!
Great seller! Shipped 2 days ago, got today! Cali to Texas, very fast. Got them in, turns out it was just my bulbs, my stock ballasts are fine which is great news. They look much brighter than old lights, I gotta check it out later on.
I'll be taking some pics, if you need them for your site, you can use them.
H3 3000k is fine
$135 pick up
you can goto www.jdlightings.com for more informations on the kits and pictures.
Regards
jason
$135 pick up
Regards
jason
sorry for all the q's. on the relay, it connects to the battery and get a signal from the oem harness? i did the 07 conversion so i was thinking i could get the signal from the factory fogs [04 max] and splice them to ur kits harness, would that work?
our kit don't come with relay harness, you don't need it to get power from battery, all you have to is hook up the kit to your foglight harness and you are fine. No need for relay( only needed for domestic cars)
hmmm. thatll probably be an issue. do u sell them? the reason is the 04 max had the fogs [h3 or h3c] in the headlight assy. with corner lights activated with the blinker. the 07+ changed it up with the actual fogs [h11] in the bumper. any ideas?
doesn't make it a difference even if is an 2007 maxima 95-03 maxima have the fog light on the bottom until 04-06 now since 07 is back to fog ( is the same as 4 ang 5gen) the relay harness wouldn't make a difference. ( it will plug right in to your fog harness)
Regards
jason
Regards
jason
