Paradox Systems HID kits
The 3000K kits come in that color, you can get the H11 kit in 3000K.
Here's pricing:
Standard Kits ( 2 year warranty )
3000K $135 shipped
Digital Kits and Slim Kits ( 2 year warranty )
3000K $175 shipped
Here's pricing:
3000K $135 shipped
3000K $175 shipped
"Our digital ballast offers the same electrical control as does the magnetic ballast, but with the digital model the current conforms to optimal levels of performance for each specific type and wattage of lamp, possible through digital circuitry. Magnetic ballasts weigh more than do digital ones and they also run hotter than digital units. Because of the more consistent application of electrical current, the lamps last longer and function at a higher level using less power with a digital ballast than they might with a magnetic ballast. With a digital ballast, the light produced is more consistent. Magnetic ballasts, especially as they age, become more noisy when they operate, cause the HID lamps to flicker and also contribute to irregularities in the color that the lamp gives off.
This means you have a HID kit that lasts longer, runs more efficiently and eliminates any of the problems that normally would require capacitors or resistors to fix. The digital ballast is also slimmer and more compact."
i got another q, in my 04 max the fogs [h3 or h3c] are in the headlight assy. with corner lights activated on the bumper with the blinker. the 07+ changed it up with the actual fogs [h11] in the bumper. does your kit come with a relay harness? essentailly, [i am assuming] i i was planning on getting the input signal to turn on/off the fogs from the h3 connectors by splicing it. any ideas?
I'm sorry, I don't think I'm following..
Not sure if I am answering your question here but, I can get you the relay kit (+$20)..
I don't follow what you need.. Do you have an 04 w/ an 07 bumper? So you need a h11 kit and you want to splice into the h3 to turn on the fogs? You would no longer need the bulbs in the headlight then? If so, I can get you a h11 kit w/ h3 connectors so you don't need to splice.
Sorry, its not an option.
I don't have anything that specific
I believe they are 8000K
Shipping looks to be approx $23 using Priority Mail International.
That would be a 3000K Kit, the Standard kit, like Maxima112 just ordered is $135 shipped.
http://www.paradox-systems.com/produ...roducts_id=170
which is great btw. thanks!
MaxMoJo, I also have a 2004 maxima without factory HID's and would like to do the conversion. Any word on the 9012 bulb sizes yet. I know that they are very similar to a 9006, but they have a few small differences in the base and the tabs which prevents them from sealing properly. Please let me know. Thanks
You can't do a Headlight swap of a 04 with the Xenon lights?
Is it a possibility?
If I was at your place I'll probably try to go that way
Please see the site for pricing depending on what you need. (www.hidkitswarehouse.com)
Yes, you can get the budget kit with bixenon bulbs.
i don't have 5000k kits, I have 6000k which are a pure white. All my kits are 35W.
Apollo :
Stock is 4300K. Going 6000K has a blue tint in them, but still OK I guess. I personally would prefer 5000K but thats just me.
I think the regular H3 fit into the housing, I dont think you need the h3 minis.
Anyone can confirm on that?
So from what website should we buy http://www.hidkitswarehouse.com/hidshop/ or http://www.paradox-systems.com.
Or are both the same?
The Frye
Sep 2, 2021 11:03 AM
